Welcome to the North American Subaru Impreza Owners Club Monday August 31, 2015
Old 03-25-2012, 06:24 PM   #1
brysawn
Member#: 219379
Default Legacy suspension options
Hey guys, I've got a 1997 Legacy L AWD EJ22 5-speed. I'm actually looking to purchase some coilovers, but most of the companies don't seem to make a coil for my exact model.
What other models fit my car? Or what coilover companies offer a coilover for my car?
brysawn is offline   Reply With Quote
Old 03-25-2012, 08:28 PM   #2
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Anything for an 02-05 Impreza (incl WRX, but not 05 STi) if you're looking at a complete coilover setup.
Check out this thread: http://forums.nasioc.com/forums/showthread.php?t=974624
Wiscon_Mark is offline   Reply With Quote
Old 03-25-2012, 09:05 PM   #3
brysawn
Member#: 219379
Okay cool, thanks. But if I buy wrx coilovers, do I need to use my legacy tophats or anything else? Or does it go straight in? It doesn't look like that was covered in the thread
Old 03-26-2012, 09:03 PM   #4
brysawn
Member#: 219379
What is my chassis code? Is it a bk or bg?
Old 03-27-2012, 05:02 PM   #5
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
If it's a Legacy wagon and not an Outback, it's a BK. BG is the raised roof version - it has a little bit of a bump on the roof compared to the Legacy. In the US, the only BG was the 96-99 Outback.
You can always check your VIN to make sure. It should read something like "4S3BK4...."
The "BK" part is your chassis code.
As far as the tophats go, I believe you can use WRX ones, but someone who has actually done a GD suspension swap may want to chime in on that.
Old 03-28-2012, 10:43 AM   #6
granny
Member#: 283145
1997 LEGASTi Wagon
Instagram-@grannywagon
http://item.mobileweb.ebay.com/viewi...id=25397602483
Better buy it fast before someone on here sees it. The BG5 is the legacy wagon.
granny is offline   Reply With Quote
Old 04-02-2012, 05:08 PM   #7
thegonz
Member#: 180208
2008 DGM 2.5i sedan
96 leggy wagon ls
idk if this will help
but the tops hats off a wrx will work. i have04 wrx struts/hats/prodrive springs on my 96 legacy ls wagon
also the 96 legacy struts/hats will fit on a 98 forester and vis versa
everything swapped fine nothing had to be messed with other than where the brake lines mount to the struts i had to cut them off and ziptie them to the wrx struts
thegonz is offline   Reply With Quote
Old 04-04-2012, 05:18 PM   #8
Kraziken
Member#: 38629
1999 Legacy GT (STI)
I have Tein coilvers from WRX wagon. Top hats meant for a GC8 corrected the angle for my Teins.
Previously the slotted adjustment on the coilovers were canted about 45 degrees, so you really couldn't adjust it.
Kraziken is offline   Reply With Quote
'98 Outback Legacy -- Suspension options? Clarkson.is.God Brakes, Steering & Suspension 0 09-09-2009 04:09 PM
Legacy Wagon Specific Suspension Options rexorama Legacy Forum 20 06-23-2008 04:30 PM
1998 Legacy GT OEM Suspension Options MYfirst00 Legacy Forum 24 03-29-2006 08:27 PM
1998 Legacy GT OEM Suspension Options MYfirst00 Brakes, Steering & Suspension 0 03-27-2006 04:46 PM
Legacy AutoX Suspension Options whtlegacy Legacy Forum 19 02-02-2004 07:07 PM
