Welcome to the North American Subaru Impreza Owners Club Saturday July 12, 2014
Old 03-25-2012, 08:56 PM   #1
alx8283
Member#: 225024
2002 wrx
Default IC spray wiring
im planning on adding an IC spray to my 2002 wrx.
I will use a pressure activated switch with a common, normally open, and normally closed.
there will be a manual spray switch in the car.
i would also like to add in an led as an indicator when the pump is running.
im going to use the washer pump to spray the ic.
the pressure switch has this info written on it, in this order:
15.1A 1/2 hp 125, 250, 277 VAC
1/2A 125 VDC; 1/4A 250 VDC
L215 5A 125 VAC L
what im most unsure of is how and where to protect this circuit.Update: Product website says 10Amp
from the print on the switch, i think i should use a 1/2Amp inline fuse between the battery and the pressure switch. is this correct? if not, how do i determine where and how much protection is needed? i dont know the draw from the pump but its a standard subaru rear window washer pump.
here's my thought as a drawing:
Thanks!
Last edited by alx8283; 06-21-2012 at 11:24 AM. Reason: added a relay because i learned something
alx8283 is offline   Reply With Quote
Old 03-26-2012, 01:15 PM   #2
Noah
Rustle Crow
Member#: 111510
The Ark
The pump will determine how much current is being drawn. You'll to wire the switches in parallel so that when either switch activates it will turn the pump on. On my setup I used a relay, but here is a basic layout.
Noah is offline   Reply With Quote
Old 03-26-2012, 08:55 PM   #3
alx8283
Member#: 225024
2002 wrx
Thanks Noah!
If anyone has some input please post.
Additionally, if anyone reading this has any Subaru wagon/forester, please pm me the year and model with the fuse size for your rear washer pump. I've been searching, but with limited time any help is greatly appreciated!
Thanks,
Alex
Old 08-20-2012, 08:46 PM   #4
4Flat4Life
Member#: 321041
2004 WRX
I would fudging love to do this!!
4Flat4Life is offline   Reply With Quote
Old 08-21-2012, 01:05 AM   #5
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Nice. I was actually thinking of temperature controlled sprayer setup for my car. Yet I keep looking at this setup.
Old 08-21-2012, 10:50 AM   #6
alx8283
Member#: 225024
2002 wrx
Temp would be nice, but the pressure switch was only ~$13.
On a side note, I finished pnp'ing that vf30
Old 08-21-2012, 04:44 PM   #7
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
12v temp controller can be found for cheap.
Old 08-22-2012, 12:05 PM   #8
NitroTrike
Member#: 62408
2002 wrx w/ STi guts
174k miles on Mobil 1
As soon as you get stuck in traffic it will empty the tank lol
NitroTrike is offline   Reply With Quote
Old 08-23-2012, 03:37 PM   #9
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
That's what the on off switch is for
Help with IC water spray wiring markadopolus Electrical & Lighting 8 11-10-2005 09:39 PM
Wiring the IC spray to RPM Warning light/buzzer ? Extraze Electrical & Lighting 0 09-18-2004 12:05 PM
DIY IC SPray wiring help 03WRX83 Electrical & Lighting 2 11-30-2003 01:07 PM
IC Spray DIY wiring help 03WRX83 Factory 2.0L Turbo Powertrain 4 11-05-2003 12:08 PM
need wiring diagram for 02 sti ic spray switch 2superblus Electrical & Lighting 1 05-22-2003 04:25 AM
