Welcome to the North American Subaru Impreza Owners Club Monday October 24, 2016
Old 03-27-2012, 07:10 AM   #1
Member#: 311801
Default Loud knocking from A/C compressor.. 1990 Legacy
So, the A/C was completely dead on this thing. It wouldn't even come on, then I found the charge was completely gone.
I pulled a vacuum, found that it was leaking at schrader valves. Replaced shrader.
Pulled a vacuum again, charged with 850g of refrigerant 12 (spec calls 800-900g)
Now the compressor comes on but the input and output are both hot and neither pipe is getting cold. It also makes a horrendous knocking sound, like an MRI machine.
I need to hookup gauges, but I don't have the high side fitting for R12, but even then something is seriously screwed. What a freaking waste of two pounds of R12.
lolol is offline   Reply With Quote
Old 03-27-2012, 10:22 AM   #2
Member#: 198067
2009 IMPREZA 2.5i 4d
WHITE Premium
If your going to do major work on the A/C system, change to R143a.
CRAZYHAWK is offline   Reply With Quote
Old 03-27-2012, 11:10 AM   #3
Member#: 119934
2015 WRX Limited
^ He meant 134a
SilverBOXER4 is offline   Reply With Quote
ridiculously loud knock from motor 22psiSTI Southern California Impreza Club Forum -- SCIC 9 01-18-2010 07:58 PM
Power Loss and loud knock from under the hood. STIdreamer17 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-05-2009 06:34 PM
loud knock from block, all rpm range, all the time. Quix Service & Maintenance 6 07-16-2007 08:08 PM
1990 Legacy wagon with a loud, obnoxious rear end the_legacy Legacy Forum 3 11-14-2005 01:51 AM
burning oil and loud knocking sound coming from cyl. 3 ? RS2000 Normally Aspirated with bolt-on Forced Induction Powertrain 15 04-16-2002 03:07 AM
