Old 03-27-2012, 02:52 PM   #1
91011swrx
Member#: 312884
Default New WRX Break-In Period
I read that you should keep it under 4000 rpms, not use the cruise control and mix up the driving for the first 1000 miles
Unfortunately, I read that after I had taken the car over 4000 rpms a few times and set the cruise to 65mph for 15 minutes or so.
I know I haven’t ruined my car but have I degraded it's performance in any way?
91011swrx is offline   Reply With Quote
Old 03-27-2012, 02:57 PM   #2
Chris-pee
Member#: 279168
2006 WRX TR stage 2
You should be fine, just keep the rpm's varied and don't romp on it. Should not have hurt it at all.
Chris-pee is offline   Reply With Quote
Old 03-27-2012, 03:04 PM   #3
dcorn
Member#: 107573
2012 WRX hatch
Ice Silver
I drove my car 500 miles home from the dealer and used cruise control for most of it. I also got stuck in some traffic, so the 'revs were varied'. 8k miles later, its fine.
dcorn is offline   Reply With Quote
Old 03-27-2012, 03:06 PM   #4
SWP n Gold
Member#: 110783
2010 WRX
Satin White Pearl
I know I havenít ruined my car but have I degraded it's performance in any way?
Not a big deal; just break it in properly for the rest of the 1,000 miles.
SWP n Gold is offline   Reply With Quote
Old 03-27-2012, 03:16 PM   #5
redline23
Member#: 285799
2012 WRX 5-Door
First 75 miles for me were varied highway miles in a snowstorm. Before I broke 1000 last this weekend, I have certainly romped on it a few times, but only after it was warm and maybe only a very small pull in one gear. It's not like your car is magically broken in at 1001 miles and will crap itself if you give it boost at 999 miles.
My opinion is that the car is broken in 90% of the way in the first 200 miles. (made up statistics)
source: http://www.mototuneusa.com/break_in_secrets.htm
redline23 is offline   Reply With Quote
Old 03-27-2012, 03:17 PM   #6
redline23
Member#: 285799
2012 WRX 5-Door
Old 03-27-2012, 03:19 PM   #7
10splaya22
Member#: 283020
2016 Subaru
WRX Limited
Your car will be perfectly fine
10splaya22 is offline   Reply With Quote
Old 03-27-2012, 03:28 PM   #8
JRCrutc
Member#: 309978
2012 WRX hatch
Ice Silver Metallic
I would say that you are fine. The 1000 mile break in seems to be more of a safety concern from the manufacturer than anything else anymore (especially on Japanese cars). They want to make sure that if there is a failure that you are prepared for it and driving carefully/listening to your car.
The tolerances in new engines are extremely tight with modern day machining methods, and gross failures are not too common any more. That being said, if there is a defect, it should show up right away (hence the first 1000 miles).
There are all kinds of theories on this, and several hundred posts with different opinions on the topic, but it all comes down to the simple physics of the engine and having a little fun during the break in period shouldn't hurt anything.
JRCrutc is online now   Reply With Quote
Old 03-27-2012, 03:45 PM   #9
MaddMax
Member#: 9264
2012 WRX 5dr
Ice Silver
I think Subaru's procedure is a bit silly as Subaru takes motors throughout the rev range when the car is first built. Subaru has had this 1,000 mile, 4K rpm break-in for as long as I can remember. My wife's 07 Outback has it listed in the owners manual as did her 1998 Legacy GT wagon manual. Both cars were purchased used and neither have/had engine problems. There's nothing magical going on inside the motor after the motor's first warm up and break-in run which is done way in advance of you getting the car. I don't understand why Subaru sticks with this break-in procedure.
As taken from this Popular Mechanics article http://www.popularmechanics.com/cars...k-in-a-new-car
"Piston rings donít rely on their spring tension to seal against the cylinder bores. Instead, combustion gases work their way between the rings and the piston and force the rings outward. During the first few minutes of engine operation, itís important that the throttle be opened pretty far at lower rpms to provide this high pressure. Otherwise, the rings wonít burnish the cylinder walls properly, and the engine will have high volumes of blow-byówhich means excessive oil consumption and shortened engine life. If youíve ever seen the car jockeys who drive new cars off the end of the production line into the storage lot, or the transporter drivers zipping up and down the car-hauler ramps, youíll realize that this all-important step has been performed for you many times. If youíre installing a new engine, simply give it a few seconds of wide-open throttle in a high gear. For the first thousand miles, avoid constant speeds and throttle settings. If you commute in normal stop-and-go traffic, youíll be fine. I advise against cruise-controlled sojourns across Nebraska."
MaddMax is offline   Reply With Quote
Old 03-27-2012, 03:52 PM   #10
crofty
Member#: 291597
2011 5dr STI
I like the theory of "setting the rings" I always gently build up to high throttle and more than 4,000 rpm on my new cars. Never had oil consumption issues. 12,000 on my stg 2 sti and it doesn't use a drop of oil. I don't think my technique helped that but it clearly didn't harm it.
crofty is offline   Reply With Quote
Old 03-27-2012, 04:11 PM   #11
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
I can anecdotally confirm this, but be warned that ymmv. The day I picked up my WRX with an EJ20, I drove it gently for about 15 minutes, then did several WOT runs through second and to about 5K rpm in third followed by engine braking. I then drove it gently for another 10 minutes or so before going back to the dealer and finalizing the payment details. That car never burned a drop of oil in the 110k miles I had her, even using the dreaded Mobil 1 5-30.
Stanley is offline   Reply With Quote
Old 03-27-2012, 04:49 PM   #12
91011swrx
Member#: 312884
Thanks for your input. I figured there shouldn't be problem, but when it’s your new sports car hearing it from someone else is like your mother telling you things will be alright as a child.
I’m sure the engine diagnostics would show rpm, mph, min, max and duration. I wonder if a problem did occur in the first 1000 miles if Subaru might put up some grief and say it wasn't broke in properly. However, the dealer never mentioned the break in period before driving off the lot. It was in the manual but I believe on the last page along with the fact that you need to use 91 octane fuel, which wasn't mentioned at the dealer either. They did tell me to read the manual though.
Thanks again.
Old 04-08-2012, 09:07 PM   #13
JACKRBT
Member#: 305990
2012 WRX
Satin White Pearl
I'm picking up my new WRX this week and there is one salesperson at the dealer that has told me at least twice now that "these engines are broken-in at the factory so you don't need to do anything." I'm more apt to follow the 1K mile procedure outlined in the manual than believe some dufus at the dealer but I've always wondered about this. Seems this is the same recommendation that has been printed in every owners manual for every car for the past 30+ years. Either it is totally obsolete but is kept as a CYA for the manufacturer or it has some merit. I find it hard to believe that SOA would condone one of their reps openly advocating something that directly contradicts their printed documentation. I'd like to not "worry" about driving it "just so" for the first month but I guess it's probably the more conservative thing to do.
JACKRBT is offline   Reply With Quote
Old 04-08-2012, 09:13 PM   #14
2011WRXMT
Member#: 270426
2011 WRX Premium
Satin Pearl White
I have 21k on mine and i used cruise from the dealer hit 4k a few times in the 1st 1500 and all is good here.
2011WRXMT is offline   Reply With Quote
Old 04-08-2012, 10:38 PM   #15
DSRX2005
Member#: 271681
2013 WRB Subaru WRX
AJW Performance
For my break-in (now I've had to break-in couple of times...) I usually don't take it above 4 1/2K, never really go WOT, but when I do, I shift very early. At like 3-4K RPM's.
I also would like to know some other's break in advice, so keep talking!
DSRX2005 is offline   Reply With Quote
Old 04-14-2013, 09:50 PM   #16
BubbaFNSmith
Member#: 352192
2014 WRX
I've got mine at 500 miles right now. I bought it with like 5 on it. I'm sure whoever put those 5 miles on it weren't light on the pedal.
I've been slowing increasing the throttle and higher RPM's I think i've taken mine to 5.5k...
I honestly have never "broken in" an engine before and I've owned plenty of new cars with 0 problems. Just take it easy. If you feel the need to get on it, who cares!
BubbaFNSmith is offline   Reply With Quote
WRX break-in period question CletusTheDwarf Newbies & FAQs 7 01-19-2005 10:01 AM
WRX break-in period DrEaMaTriX Newbies & FAQs 6 02-19-2002 08:09 PM
BOV in a new WRX before break-in period?? View Askew Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-04-2002 04:00 PM
New Clutch Break-In Period? H5N1 Normally Aspirated Powertrain 8 07-13-2001 04:38 AM
New Impreza break-in period Xio Newbies & FAQs 10 01-30-2001 01:37 AM
