Old 09-04-2013, 01:04 PM   #151
tersplat
Member#: 337888
2003 WRX Wagon
World Rally Blue
sweet, thanks!
tersplat is offline   Reply With Quote
Old 09-05-2013, 03:54 PM   #152
rapa
Member#: 230077
Originally Posted by Hawken View Post
Rapa you're spot on.
Started first crank..
Swapping C16 to C15 is the way to go for an ADM to JDM swap. (I also found a few incorrect references to D16 to D15.)
Now to sort out the power steering and exhaust, then go for a drive...
FYI, Loosening the turbo bolts still didn't give enough clearance to get the motor in, I ended up removing the 2 bottom studs and replacing them with bolts.
Glad I could help someone =]
took me a lot of hours of search and trials...
rapa is offline   Reply With Quote
Old 09-21-2013, 07:24 PM   #153
Hawken
Member#: 316735
2000 WRX with EJ207
Dark blue
OK, another question for the experienced...
Everythings running sweet. I've modified the splitter so all the intercooler gets air, sorted the exhaust, got the aircon working etc. I'm happy withe the power increase but It's always nice to get a little more.
So now It's time to start fiddling.
The only problem is I can't get the ECU to go into programing mode.
I've connected the 2 green plugs and shorted the 2 pins of the white plug under the dash but the fans don't cycle and my Tactrix cable wont download the ROM.
I can get logging data fine and the cable itself will log, so it's not a problem there.
Are there any other wiring changes that need to be made?
Hawken is offline   Reply With Quote
Old 09-22-2013, 10:32 AM   #154
25rsti
Member#: 166324
I don't touch the white plugs. Just connect the 2 green connectors.
Old 09-22-2013, 08:26 PM   #155
Hawken
Member#: 316735
2000 WRX with EJ207
Dark blue
Mmmmm
Tried that too. Still no joy.
Old 09-23-2013, 06:26 PM   #156
25rsti
Member#: 166324
Are you turning the key and hitting the button quick enough to work aka fans cycle etc?
Old 09-23-2013, 09:06 PM   #157
Hawken
Member#: 316735
2000 WRX with EJ207
Dark blue
Yeah have tried a few different combinations.
Just to clarify.
My impression is that even if you don't have anything to read the ECU, if you have the plugs connected and turn the ignition on the fans should still cycle.
For reading the ECU the trick is to start the software before the fans switch off.
Old 09-26-2013, 10:42 PM   #158
APriestOfGix
Member#: 280305
2003 JDM v9 STi WRX
How is everyone's EJ207's doing?
I took my car out to auto-x at Subiefest and have what sounds like a stuck idler (getting a nice squeal) even though they are all brand new. The timing cover is coming off this weekend to see what's up, but wondering if anyone else has heard of this?
APriestOfGix is offline   Reply With Quote
Old 10-26-2013, 03:40 AM   #159
Fehnix
Member#: 300587
02 wrx wagon ej207
I want more power lol I'm wondering how much I can get out of the stock twinscroll.
Fehnix is offline   Reply With Quote
Old 10-26-2013, 07:57 AM   #160
25rsti
Member#: 166324
I only drive mine about 1-2 times a month for a few miles. Love it every time.
Old 10-26-2013, 12:05 PM   #161
Fehnix
Member#: 300587
02 wrx wagon ej207
Must be nice. I'm forced to commute to school 4 days a week :/
Old 01-30-2014, 08:40 PM   #162
Florin1
Member#: 163625
91 Legacy SS
Bumping this thread since the OP seems to be gone. Have an AVCS question.
After reading the thread, I got a bit confused on what I need to do wiring wise. I bought a jdm engine harness, and I also bought an avcs harness like OP had from another member that has been prepped. My car is an 02 wrx manual. I'm following the ds1 write up but now I'm wondering if I'm doing too much. Last night I got as far as page one. The one on moving pins 4 5 10 11. I also added 6" pigtails to pin 2 3 9 14 15. These are not yet soldered to anything. I'm worried about pin 14 because it says shield common ground. Not sure what that means. So my question is, do I need to follow the ds1 instructions all the way, or do I not, since I have the harness.
Florin1 is offline   Reply With Quote
Old 02-18-2014, 08:28 AM   #163
bipolarnrute
Member#: 340737
I don't remember the ds1 instructions mentioning anything about soldering. You should just be relocating pins and adding in your harness.
bipolarnrute is offline   Reply With Quote
Old 03-14-2014, 02:00 PM   #164
APriestOfGix
Member#: 280305
2003 JDM v9 STi WRX
You will need to re-locate 4 pins, and add 2 additional. I ended up going with the IA Performance AVCS wiring harness, and it was SUPER simple. I highly recommend it, just plug and play.
Old 03-20-2014, 06:10 PM   #165
PHruska
Member#: 214589
2002 wrx wagon
I scrounged mine out of the full JDM harness. There is already a fully functional shielded harness in there if you know where to look. lots of messy wiring to sift through to get to it though. then it was just move a few and plug in. super easy.
PHruska is offline   Reply With Quote
Old 07-01-2014, 08:24 PM   #166
rgibs041
Member#: 361761
2002 wrx wagon
aspen white
My v7 comes tomorrow. Anyone in the east bay, Bay Area willing to help with the avcs wiring next week? I got two buddies helping with the motor install I just want to make sure the wiring gets done correctly. I would greatly appreciate any help!
Thanks guys
rgibs041 is offline   Reply With Quote
Old 10-26-2014, 03:17 PM   #167
carruthers23
Member#: 337779
02 S7 WRC
So if I purchase the IAPerformance AVCS wiring kit do I need to go through the hassle of adding wires and re-pinning the ECU on the JDM ECU?
carruthers23 is offline   Reply With Quote
Old 05-23-2015, 06:21 PM   #168
subaruty37
Member#: 348543
Ive got a question. I have a jdm v7 with active avcs, mated to a jdm v9 6 speed with dccd, I was told by my tuner last time I dynod that avcs werent working. And the time I went before that the avcs was working with a 5 speed. On romraider logger it shows my gear is 6th in any gear 1st-6th and rever se. My question is can avcs be mated with 6 speed and still work? Any one had similar experience?Thank you
subaruty37 is offline   Reply With Quote
Old 05-23-2015, 06:45 PM   #169
AFBeefcake
Member#: 27874
2002 WRX V7 EJ207
DOM1.5 6MT 360 whp
I don't see how one is connected to the other. The AVCS wiring has nothing to do with the transmission.
Unless the ECU turns off the AVCS between gears or something.
I have a 6 speed in my 02 and just installed my v7 motor, but haven't got my ecu reflashed yet so I cant start it.
AFBeefcake is offline   Reply With Quote
Old 05-23-2015, 06:51 PM   #170
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
your NPS switch polarity is different on your 6sp. If you still have the NPS from your 5sp, switch it up...otherwise there are some rom hacks to "swap" the polarity.
fastnoypi is offline   Reply With Quote
Old 05-23-2015, 06:55 PM   #171
subaruty37
Member#: 348543
Shoot I may be able to find a 5 speed nps. I sold my 5 speed... any ideas on what the hacks would be? Would I do it thru ecuflash?
Old 05-23-2015, 06:59 PM   #172
AWDWRXLOVER
Member#: 50267
02 built hybrid
sr55/meth/sick speed
I just got mine in mail today. 04 sti NPS switch. It's $35
AWDWRXLOVER is offline   Reply With Quote
Old 05-23-2015, 07:07 PM   #173
subaruty37
Member#: 348543
Nice! And this is what is needed to get avcs to work with the 6 speed ?
Mine is an 06
Old 05-23-2015, 07:26 PM   #174
subaruty37
Member#: 348543
Do you have a link to the changing the Rom? That would probably be easier the swappi ng nps
Old 05-23-2015, 07:55 PM   #175
AWDWRXLOVER
Member#: 50267
02 built hybrid
There are links on romraider on how to change the NPS on the ecu but use caution because you can brick the ecu if you mess with the wrong line of code. My tuner said he would prefer for me to buy the right sensor.
2005 STI into 2002 Bugeye Swap psychorunner Subaru Conversions 20 03-08-2012 08:28 PM
My STI swap into 02 Bugeye Tweeder Member's Car Gallery 19 06-04-2011 03:13 AM
JDM V7 ej207 into my 05 WRX CamTunedSti Built Motor Discussion 6 11-10-2010 04:40 PM
I have some questions regarding - Version 7 v7 EJ207 into USDM 2004 STi STepeci Subaru Conversions 8 09-18-2009 07:26 PM
dash/interior swaps into 02 bugeye? ricky05 Interior & Exterior Modification 4 01-25-2007 04:03 AM
