Old 03-27-2012, 04:14 PM   #1
big_scoggs
Member#: 206090
Default 02 wrx fuel problem
ok so i have been searching and searching and i dont really want to take my car in to a shop so this is whats going on...
car has trouble pumping gas...sometimes it will bump just a gallon or so and stop and sometime it will do like 8 gallons than after it stops wont pumnp more than a gallon..while pumping gas my inside of the car reeks like fuel so bad...its not cold out when im doing this..like 60-75 degrees..i popped off the 4 bolts in the trunk and didnt see anything? is it the evap canister?evap purge solonoid? fuel pump im confused? any help please?
im changing my fuel pump to a dw300 anyways but dont want to buy unecasary parts like the evap can or purge valve if not necasary..
big_scoggs is offline   Reply With Quote
Old 03-27-2012, 05:07 PM   #2
big_scoggs
Member#: 206090
anybody???? help please..lol
Old 03-28-2012, 06:33 AM   #3
big_scoggs
Member#: 206090
Anybody have any ideas???
Old 03-28-2012, 09:08 AM   #4
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
I've never had this problem, so I don't know what to tell you exactly. What I would do, is start inspecting all the lines to the fuel tank, from the filler neck to the tank. On my 02 wagon, there is an access panel under the rear seat that gives me access to the top of the fuel pump, look there for any leaks.
Honestly though, I'm just guessing and letting you know what I would do if I had the problem. It could be that you have a blockage in the filler neck, but I don't know for sure.
I know you don't want to take it to a shop, but unless the car can sit for a while, while you take it apart to find the problem, you may have no choice. You may even have to remove the fuel tank, but that is a serious PITA, since it's a "saddle" tank, and you have to remove the drive shaft to get it out.
If it were me, and I couldn't figure it out, I would find out how much the dealer wanted to tell me whats wrong. Hopefully it isn't any more than $100... then I would fix it myself.
Whatever you do, good luck.
Bacon117 is offline   Reply With Quote
Old 03-28-2012, 09:16 AM   #5
big_scoggs
Member#: 206090
Thanks for the help I'm changing my fuel pump and evap canister so I'll keep you updated thanks
Old 03-28-2012, 09:56 AM   #6
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
Are you sure they are bad? Is the fuel pressure low? If not, there really is no need to change the pump.
You're spending a few hundred dollars on a guess, rather than take it to someone that has probably seen this issue before, and can tell you exactly what's wrong.
Why are you against having it looked at by the dealer, or other qualified shop?
Old 03-28-2012, 10:05 AM   #7
big_scoggs
Member#: 206090
I'm changing the fuel pump for e85..
Old 03-28-2012, 10:07 AM   #8
big_scoggs
Member#: 206090
If changing my pump or evap can doesn't work then im taking it to a shop I'm just going to swap evap cans with a buddy to see if that's it
Old 03-28-2012, 10:47 AM   #9
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
ah cool. What else are you doing to it?
Old 03-28-2012, 10:50 AM   #10
big_scoggs
Member#: 206090
I'm just doing the deatchwerks 300lph pump and some fic injectors.. And might do external waste gate .. But buying the pump this week at least.. It's a start .. I'm taking it to the track this weekend and depending on if I'm disappointed or not will show how fast this progress will take lol
WTT: My carbon fiber gas/fuel door for a stock PSM 02 WRX fuel door madmax02 Exterior/Styling 4 09-17-2011 10:38 PM
02 wrx wiring problem?turn key on, fans and fuel pump keeps cycling on&off 05 gt Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 03-01-2011 08:40 PM
05 WRX tranny into 02 WRX...clutch problems? HeeroRaven Transmission (AT/MT) & Driveline 3 07-20-2006 03:26 PM
stock 02 wrx fuel pump Rickyh Private 'For Sale' Classifieds 0 01-11-2004 01:52 PM
MA: 02 WRX Fuel Injectors and Fuel Pump K2Skier Private 'For Sale' Classifieds 0 09-19-2003 11:33 PM
