Old 03-28-2012, 03:04 PM   #1
Mr.BlackNorris
Member#: 281422
2004 wrx
red
Default P1491;P0442 Help????
I'm not sure if this is the right forum for this but I need some help. I keep getting a check engine light and my accessport pulls up the same codes after clearing them twice. P1491 (positive crankcase ventilation) and P0442 (Evap emission control system leak: small leak)
I have a 2004 wrx w/ custom tune via cobb accessport.
Mods:
2.5l block (balanced & blueprinted), 2.0l heads (Quenched to Sti specs)
cp 99.5mm pistons
Manley H beam rods
ACL race main & rod bearings
2008 sti crankshaft
cosworth head studs
cosworth head gaskets
Killer B oil pickup & baffle
Subaru OE gasket set
Grimmspeed TGV deletes
Perrin big MAF intake
Samco turbo inlet air hose
Deadbolt SZ 49 (20g) turbo
Invidia V2 downpipe
Trust up pipe
Stromung 3" turbo back exhaust
HKS electronic boost sylenoid
RC 850 injectors (stock fuel rail/FPR)
Turbo XS fmic w/ Tial qr recirc valve w/ 11lb spring
Full Sti drivetrain swap
The P1491 code has popped up several times by itself w/ no other codes, my tuner has turned this code off but for some reason it keeps coming back. My tuner has spoke w/ Cobb numerous times and they cant figure out why the code keeps coming back. I'm concerned about the P0442 code It first popped up 2 days ago I cleared it filled my gas tank and the code came back yesterday. I checked the O ring around my gas cap and it's fine and I can't figure out where the problem (P0442) is coming from. Can anybody help me diagnose this?
Mr.BlackNorris is offline   Reply With Quote
Old 03-31-2012, 10:51 PM   #2
ran2
Member#: 172643
2002 WRXWgn & Legacy
Blue/Green
I am chasing a P0442 on my bone stock 03 Legacy.
I will subscribe to your thread and post back if I can
figure out what is up with my car.
ran2 is offline   Reply With Quote
Old 03-31-2012, 11:43 PM   #3
REDrexsti
Member#: 283553
2004 wrx
jbp
P0442 can be a lot of things. Some have had luck with replacing the gas cap, others the Fuel pump assembly gasket...it really could be anywhere from the gas tank to the charcoal canister and then all the way back up to the engine. Check for any cracked/brittle/broken/etc... rubber lines in the system. This code is such a pia.
REDrexsti is offline   Reply With Quote
Old 03-31-2012, 11:52 PM   #4
MattTHEpainter
Member#: 284046
2000 Impreza w/ WRX
For the positive crankcase code; do you have the pcv sensor connected to your new turbo inlet?
MattTHEpainter is offline   Reply With Quote
Old 04-15-2012, 12:03 PM   #5
ran2
Member#: 172643
Blue/Green
I reset the codes on my car and the error has not come back yet.
I'm with REDrexsti...the code is a PIA.
Old 04-15-2012, 08:00 PM   #6
jakechup
Member#: 280793
02 WRX Wagon
I got a P0442, too. trying to figure it out. Such a PIA.
jakechup is offline   Reply With Quote
Old 04-17-2012, 03:22 PM   #7
fabiosugitani
Member#: 285398
2010 2.5i Premium WG
Spark Silver Metallic
same P0442 here... smoke test could't find anything but little bit of gas smell around the gas tank. The dealership suggested one of the sensors above the gas tank could be cracked.
I'll post any updates...
fabiosugitani is offline   Reply With Quote
Old 04-26-2012, 06:24 PM   #8
fabiosugitani
Member#: 285398
Here's my problem:
It wasn't broke like in the picture, but it was cracked so bad you can see the brown spot around the tube, so when I touched to release the clamp, it broke.
This is how supposed to look like
04 WRX misfire/stutter help! JRosado Newbies & FAQs 6 07-19-2013 06:09 PM
Yet another help me pick a car thread... ganzhimself Off-Topic 78 04-01-2012 01:50 PM
Need some help! Mitchyy Tri-State Area Forum 6 03-29-2012 09:53 AM
Help me with a cheap suspension solution. nicksamba_18 Brakes, Steering & Suspension 3 03-28-2012 06:57 PM
I'm doing a project on subaru and I need some help! mitchell02wrx Off-Topic 16 03-28-2012 11:58 AM
