Old 03-28-2012, 04:32 PM   #1
Fisheys
Member#: 307133
2002 Impreza RS
Default i broke it can i drive it
I broke this thing because im a dumb ass and didnt loosen the locking nut- can i still drive it to the shop or longer?
Fisheys is offline   Reply With Quote
Old 03-28-2012, 04:49 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yes that's only for the AC belt. Belt tension should still be ok if you didn't loosen the locknut. If you're afraid the broken piece will go flying into the belts just remove the loose part, it's shot anyway. Get a new one from the dealer, and check the idler itself while you're at it as they fail often. On an '02 it's very likely that the pulley bearing is gone.
Old 03-29-2012, 03:05 PM   #3
rkramer
Member#: 118209
2015 WRX Limitec
You and pretty much every other subaru owner has broke that part. Personally, I broke my about 6 years ago, and still haven't replaced it... When I've needed to tension the belt, I just got myself a chunk of wood against the pulley to lean on while I tightened it.
Old 03-29-2012, 07:39 PM   #4
Rally Monkey
Member#: 36310
03 WRX Sedan
Wow, usually the bolt just bends.....nice job. Just replace the whole thing, ac idler pulley included.
You can drive it, under caution.......
Rally Monkey is offline   Reply With Quote
Old 03-30-2012, 10:00 AM   #5
rkramer
Member#: 118209
2015 WRX Limitec
so the weak plastic piece bends the relatively beefy steel bolt? Search around, LOTS of people have broken that piece off, it will break even with the idler bolt loosened sometimes. Really poor design, that should have never been made of plastic.
Old 03-30-2012, 10:39 AM   #6
lavid2002
Member#: 226864
^ The bolt bends? Nah that plastic piece breaks before it bends steel lol. I broke it too, just go buy a new pulley.
-Dave
lavid2002 is offline   Reply With Quote
Old 03-30-2012, 10:44 AM   #7
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
I broke mine 8 months ago. Ordered a replacement part 3 months ago. I'll probably replace it tomorrow.
Psychoreo is offline   Reply With Quote
Old 03-30-2012, 11:52 AM   #8
Fisheys
Member#: 307133
2002 Impreza RS
let me know how much of a pain it is to replace
Old 03-30-2012, 12:15 PM   #9
Psychoreo
Member#: 79643
2015 WRX STI
20min
Old 03-30-2012, 01:56 PM   #10
Rally Monkey
Member#: 36310
03 WRX Sedan
Yes, the bolt can bend when the retaining nut is not loosened first. And that is unfortunately speaking from experience. LOL at that.....oh I guess you are, cuz I bent my S**** but that was like 7 years ago, other people have done it though....... you know you did it just admit it....
can i drive it. TGV delete d-zoom Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 07-19-2011 02:02 AM
Bigger injectors and fuel pump...Can I drive it to the Dyno for tuning? xcdhridr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-26-2008 10:33 AM
How can I drive it different than... brianchristie Newbies & FAQs 8 04-28-2004 05:04 PM
greddy bov broke! how can i fix it, or can i? burnout555 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-14-2004 08:39 PM
warm up- let it sit or drive it under certain rpm until operating temp? ChristophWRX Service & Maintenance 7 05-22-2002 07:38 PM
