Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 03-28-2012, 05:13 PM   #1
ARiSTA Performance
Vendor Sales Rating: (56)
Member#: 309599
2006 WRX STi
CGM
Default **AMR Turbo Liquidation Sale Turbos at COST! We only have 5 LEFT!**
This special will only be until April 6th so act fast!
We overstocked on AMR Turbos and we are going to run a Inventory Liquadation Sale for the next week depending on the amount of supplies! Get them while they last! There are only 5 LEFT in STOCK!
They are all 10.5cm Versions.
CXR500-LGT-105 - 08+ WRX - 2 Left!
$1477.27 + Shipping!
AMR's CXR500 Bolt-On Turbo for the 08-10 WRX is an awesome turbo that is sure to put a smile on your face. The CXR500 comes with a ported, 8cm exhaust housing and a ported, custom-cast compressor housing that that is designed to fit in the engine bay better than any other turbo of this size (no grinding or busting out a BFH to make something fit). The CXR500 comes equipped with a 44lb compressor wheel. With the extreme porting on the compressor housing along with the large turbine wheel, gives the CXR500 a flow rate of 47 lb/min. This seemingly small increase in airflow allows the CXR500 to pull hard on top end of the rev-range without any loss of power on low and mid range. The AMR CXR500 is perfectly compatible with the OEM TMIC too! AMR backs their 350-430whp capable CXR500 with a 90-day limited warranty!
CXR500-SUB-105 - 02-07 WRX/STi - 2 Left!
AMR's CXR500 Bolt-On Turbo for the 02-07 WRX & STI is an awesome turbo that is sure to put a smile on your face. The CXR500 comes with a ported, 10.5cm exhaust housing and a ported, custom-cast compressor housing that that is designed to fit in the engine bay better than any other turbo of this size (no more grinding or busting out a BFH to make something fit). The CXR500 comes equipped with a 44lb compressor wheel. With the extreme porting on the compressor housing along with the large turbine wheel, gives the CXR500 a flow rate of 47 lb/min. This seemingly small increase in airflow allows the CXR500 to pull hard on top end of the rev-range without any loss of power on low and mid range. The CXR500 is most efficient when run between 20psi & 24psi and will produce 350-430whp when fully tuned with all supporting modifications. This is a great turbo for both 2.0L and 2.5L engines and is great daily driver turbo. You will not be giving up too much spool over your OEM turbo but will be impressed with the top end power increase. As you can see by the dyno charts, this is a great turbo for those who want something reserved but want the possibility of turning up the power eventually. AMR backs their CXR500 with a 90-day limited warranty.
CXR550-SUB-105 - 02-07 WRX/STi - 1 Left!
AMR's CXR550 Bolt-On Turbo for the 02-07 WRX & STI is quite a weapon. The CXR550 comes with a ported, 10.5cm exhaust housing and a ported, custom-cast compressor housing that that is designed to fit in the engine bay better than any other turbo of this size (no more grinding or busting out a BFH to make something fit). The CXR550 comes equipped with a 52lb compressor wheel. With the extreme porting on the compressor housing along with the large turbine wheel, gives the CXR550 a flow rate of 52 lb/min. Some might call this the FP Green killer turbo as it very similar in design, it comes already ported and polished, and flows a tremendous amount of air. Spool will be slightly slower than the CXR500, but the top end is greater. 2.0L owners beware. This is still a daily driveable turbo but forged internals are recommended. You are looking at 400-500WHP when fully tuned with all supporting modifications. AMR backs their CXR550 with a 90-day limited warranty.
CXR750-SUB-105 - 04-11+ WRX/STi - 1 Left!
$1789.77 + Shipping!
Description: AMR 02-07 WRX / 04-11+ STi CXR750 Turbo 10.5cm / 3inch Inlet / Ported / Includes All Lines
AMR's CXR750 Bolt-On Turbo for the 02-07 WRX & STI is a monster of a bolt on turbo. The CXR750 comes with a ported, 10.5cm exhaust housing and a ported, custom-cast compressor housing that that is designed to fit in the engine bay better than any other turbo of this size (no more grinding or busting out a BFH to make something fit). The CXR750 comes equipped with a 80lb compressor wheel and a 3" compressor inlet. With the extreme porting on the compressor housing along with the large turbine wheel, the CXR750 has a flow rate of 80 lb/min. Slight lag is to be expected with this turbo, but when it spools expect to be pinned back in your seat. Hard. The CXR750 will produce 550-750whp when fully tuned with all supporting modifications. AMR backs their CXR750 with a 90-day limited warranty. All lines and gaskets are included making this an easy installation.
__________________
ARiSTA | Performance
"Integrity in Motion"
Ask for PayPal 0% Financing!
PayPal:
Inquiries:
ARiSTA Performance is offline
Old 03-29-2012, 12:05 PM   #2
ARiSTA Performance
Member#: 309599
2006 WRX STi
CGM
We'll do our best to beat any price! Send us a PM or E-Mail!
__________________
PayPal:
Inquiries:
Old 03-29-2012, 08:09 PM   #3
ARiSTA Performance
Member#: 309599
2006 WRX STi
CGM
Let's get these turbos sold!
__________________
PayPal:
Inquiries:
Old 03-30-2012, 12:05 PM   #4
ARiSTA Performance
Member#: 309599
2006 WRX STi
CGM
__________________
PayPal:
Inquiries:
Old 03-30-2012, 04:54 PM   #5
ARiSTA Performance
Member#: 309599
2006 WRX STi
CGM
Orders shipped. Thank you for your business!
__________________
PayPal:
Inquiries:
Old 03-31-2012, 02:05 PM   #6
ARiSTA Performance
Member#: 309599
2006 WRX STi
CGM
Turbos at cost!
__________________
PayPal:
Inquiries:
Old 04-01-2012, 01:31 PM   #7
ARiSTA Performance
Member#: 309599
2006 WRX STi
CGM
Turbos at cost!
__________________
PayPal:
Inquiries:
Old 04-02-2012, 08:53 AM   #8
ARiSTA Performance
Member#: 309599
2006 WRX STi
CGM
__________________
PayPal:
Inquiries:
Old 04-02-2012, 07:10 PM   #9
ARiSTA Performance
Member#: 309599
2006 WRX STi
CGM
Couple more days left!
__________________
PayPal:
Inquiries:
Old 04-03-2012, 10:57 AM   #10
ARiSTA Performance
Member#: 309599
2006 WRX STi
CGM
__________________
PayPal:
Inquiries:
Old 04-04-2012, 10:52 AM   #11
ARiSTA Performance
Member#: 309599
2006 WRX STi
CGM
__________________
PayPal:
Inquiries:
Old 04-04-2012, 09:35 PM   #12
ARiSTA Performance
Member#: 309599
2006 WRX STi
CGM
__________________
PayPal:
Inquiries:
Old 04-05-2012, 01:30 PM   #13
ARiSTA Performance
Member#: 309599
2006 WRX STi
CGM
__________________
PayPal:
Inquiries:
Old 04-06-2012, 09:34 AM   #14
ARiSTA Performance
Member#: 309599
2006 WRX STi
CGM
__________________
PayPal:
Inquiries:
Old 04-07-2012, 11:02 AM   #15
ARiSTA Performance
Member#: 309599
2006 WRX STi
CGM
__________________
PayPal:
Inquiries:
Old 04-08-2012, 12:45 PM   #16
ARiSTA Performance
Member#: 309599
2006 WRX STi
CGM
__________________
PayPal:
Inquiries:
Old 04-09-2012, 12:28 PM   #17
ARiSTA Performance
Member#: 309599
2006 WRX STi
CGM
__________________
PayPal:
Inquiries:
Old 04-10-2012, 01:10 PM   #18
ARiSTA Performance
Member#: 309599
2006 WRX STi
CGM
__________________
PayPal:
Inquiries:
Closed Thread
*TAX SEASON SPECIALS* Fortune Auto | BC Racing | Hawk | DBA + MORE! Best Pricing! ARiSTA Performance Suspension/Brakes/Handling 912 08-24-2016 06:46 PM
We are having our Annual Thanksgiving sale!! One Day only 20-60% off! RallySport Direct Interior/Dressup/Audio & Security 3 11-23-2007 06:01 PM
Blow Out Sale! Items At Cost!! InjectedPerformance Engine/Power/Exhaust 23 01-04-2007 10:22 AM
