Welcome to the North American Subaru Impreza Owners Club Thursday August 21, 2014
Old 03-28-2012, 08:19 PM   #1
wrb_rex02
Member#: 253582
98 RS
Default 98 EJ25D with 96 HLA heads
I need some advice.
I have an empty ej25d block and some 96 hla heads. If I use ej25d pistons my compression ratio will be low. What piston can I use to put me back in the 9.5 area? What about an ej251?
I just picked up a 98 forester s that's missing an engine for 35 bucks and an ipod(what I had in my pocket) Hoping to get back on the road on the cheap using what I have laying around.
wrb_rex02 is offline   Reply With Quote
Old 03-31-2012, 10:45 AM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
My first EJ25 swap was EJ25D bottom end and HLA heads.....the compression was not too low, the motor ran fine.
Jay
Old 03-31-2012, 10:27 PM   #3
wrb_rex02
Member#: 253582
98 RS
What gaskets did you use? I assume ej25D?
Old 03-31-2012, 10:53 PM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Did the HLA heads have a bigger combustion chamber? Or why do you think you'll end up with low CR? I wasn't aware that there were any significant differences in the short blocks between the '96 EJ25Ds with the HLA heads and the '97-99 EJ25Ds with the bucket lifters.
Old 03-31-2012, 11:52 PM   #5
wrb_rex02
Member#: 253582
98 RS
Yeah FuJi K did a really nice job documenting it here
post #58 for intake
post #175 showing combustion chamber and
post #176 showing different pistons.
from what I am able to find -
97-99 EJ25D are 46cc
96 HLA EJ25D are 50cc-53cc I have found conflicting evidence in regards to these.
2.5 block with 2.2 heads into 96 legacy? benjileo Built Motor Discussion 15 04-28-2011 01:48 PM
WTB/WTT : 96 EJ25D dohc hla heads/EJ20G hla heads cdnsigop Private 'Wanted' Classifieds 3 12-09-2010 03:55 PM
2003 WRX Cams into 98 EJ25D ? poruki Normally Aspirated Powertrain 15 02-21-2006 11:39 AM
What would the compression ratio be with a 96 ej20H shortblock with 96 ej25 heads? hotshot2109 Subaru Conversions 3 10-10-2005 11:02 AM
What will be better for an n/a ej25/ej22 hybrid? ej22 or ej22t HLA heads? lotus2843 Subaru Conversions 4 08-09-2005 03:13 PM
