#1 |
Member#: 284866
South East
Vehicle:1998 Full RSTi Swap Metallic Grey |
So my Tial 44mm EWG is getting a little loud and obnoxious after 3 months on my DD. I have read many places of people using mufflers or other methods of quieting down a VTA EWG. However, I have not seen an execution of it.
So, Does anyone have any links to a solution here? I am NOT looking to plumb it back into the downpipe.
#2 |
Member#: 16200
Vehicle:OK Houston we have an Uncle |
#3 |
Member#: 293509
Vehicle:2004 WRX STI Blue |
Prior to getting my 44mm 3 weeks ago I thought I was gonna hate it but I've honestly grown to like it.
#4 |
Member#: 298231
Vehicle:2011 Subaru WRX WRB |
on different cars i have seen people use mufflers from small CC bikes. like a pocket rocket or even scooters. if your worried about flow then they makes aftermarket performance exhaust for the same kinda thing. i personally ended up plumbing it back into the exhaust after awhile on several different vehicles....
#5 |
Member#: 8356
South East
Vehicle:02 STi swap 12 WRX limited |
Id have it plumed into the down pipe and be done with it.
#6 |
Member#: 258046
BAIC
Vehicle:2011 Impreza WRX DGM |
I had it plumbed back into the dp and actually made more power. I don't think flow is an issue if it's done right
#7 |
Member#: 136396
Vehicle:2012 wrx white |
Yeah we've had quite a few customers run our kit back in to the down pipe. If you bring it to a local exhaust shop they should be able to fab it up for you.
Mike |
#8 | |
Member#: 81102
another option; link to thread http://forums.nasioc.com/forums/show...1809838&page=3. Supposedly no noticeable power loss (supposedly a tuner confirmed this as a VERY negligible loss, or non existant.)
#9 |
Member#: 63767
NWIC
Vehicle:2009 OXT 5-spd 2011 STi hatch |
Just curious, why not plumb it back in? That is my set-up and now I don't believe that EWG are actually loud
![]() Last edited by tazswing; 03-30-2012 at 01:13 AM. Reason: grammer |
#10 |
Member#: 127745
NWIC
Vehicle:06 WRX 30r 6 speed 99L EJ255 6 Speed |
This is what I am running and it helped a lot. Mine comes straight off the EWG though. Got it from Tigwerks
http://forums.nasioc.com/forums/show...&postcount=147 |
#11 |
Member#: 300551
SCIC
Vehicle:2002 DD wgn 6 spd 2.1 kel 272's meth 2.5xtr |
I would just plumb it back in that seems much better.
#12 |
Member#: 171948
Vehicle:08 wrx prem sedan vf52 swap. bilstein susp |
#13 |
Member#: 127745
NWIC
If you need a sticky to tell you that a 1.5 inch tube, venting exhaust straight to atmosphere 2 feet from your combustion chamber, is going to be loud...then you need to throw yourself off a TALL bridge for the betterment of all humanity.
That one is for you Scotty!! (in spirit, not literally) |
#14 | |
Member#: 100834
BAIC
Vehicle:2006 Subaru STI Steel Grey Metallic |
#15 | |
Member#: 293509
#16 |
Member#: 136671
Vehicle:WRX HTA GT3076R 9cm2 eWG'd It's ALIVE!! |
Don't plumb it back, grow some balls and deal with it. If you don't like the noise, get a IWG. Making power may require noise. So be it!
So sick of seeing these posts. People crying about their car being loud. Easy.....don't have a loud car. |
#17 | |
Member#: 63767
NWIC
Plumb it back into your DP and if you use a COBB style DP you will also have the EWG gases run through a cat. With my set-up I also then heat wrapped the whole thing. Sorry to hear that for some noise equals "balls." |
#18 |
Member#: 127745
NWIC
#19 |
Member#: 284866
South East
Last I checked this morning in the shower, I still have balls
![]() Plumbing it back into the downpipe is looking like a good idea now. I just need to find a shop here in ATL that is willing to do it. @tazswing, I have an APS turboback so no cat anywhere. |
#20 |
Member#: 139955
NESIC
Vehicle:# OneBoston |
You hit boost that often during your commute?
I don't baby my car, but during my commute I'll go weeks at a time without opening the gate. |
#21 |
Member#: 191212
South East
Vehicle:'07 Forester XT-5MT ToBe: E85 TD06SL2 8cm 20G |
It is nearly impossible to find a reputable exhaust shop, I would just try one of those Super Trapp contraptions.
#22 |
Member#: 54832
E. Canada
Vehicle:2006 WRX Blue |
Depending on your EWG spring pressure, you really shouldn't be opening it too often. I have a 17psi spring combination in it, so really I don't "hear" it until I'm well on the boost.
#23 |
Member#: 167794
Vehicle:2004 WRX Wagon daily 91 miata. because racecar |
I have a super trapp on my ewg dump tube. It works.
#24 |
Member#: 141952
Vehicle:03 emo 8/2011 wrx |
yes, i did it back in the day too. as far as power loss you guys need to think about it. its the wastegate flowing thru it only. if it was restrictive and not flowing good enough it would boost creep. there is absolutely zero power loss with a muffler on the dump tube. recirculating does cause a power loss. its added exhaust volume and backpressure on the turbine wheel.
#25 |
Member#: 322472
South East
Vehicle:2005 STI PSM |
Theres a guy on fb that makes mufflers for the EWG tigwerks I think. Me personally I like the EWG and wouldnt muffle it
| Thread Tools | |
| Display Modes | |
| Quieting Down an Exhaust | digitalboy40 | Newbies & FAQs | 13 | 06-14-2007 03:05 PM |
| How much will a small muffler quiet down an EWG? | scooterforever | Factory 2.0L Turbo Powertrain | 4 | 03-22-2007 01:16 PM |
| Anyone to quiet down an exhaust system? | schooby | Normally Aspirated Powertrain | 21 | 09-19-2006 12:00 AM |
| How to quiet down a TBE? | WRB4U | Factory 2.0L Turbo Powertrain | 4 | 08-06-2003 08:55 PM |
| What can I do to quiet down my new exhaust? | Robmat | South East Region Forum | 4 | 07-06-2001 12:18 PM |
