#26 |
Member#: 200532
NWIC
Vehicle:05 Legacy GRP |
You are not living life!!! I hit boost everyday at least for a couple of seconds haha.
#27 |
Member#: 144751
Vehicle:02 WRX BW EFR E85 7064 TS WRB |
I don't agree with plumbing it back in to the downpipe. Why did you go external in the first place then? Why not go back to IWG? The benefit of external is that you bypass the primary exhaust....
If you don't like the noise of external, put a muffler on it or go back to IWG... |
#28 |
Member#: 328492
EWGs provide superior boost control -- I'd plumb it back into the down pipe. Just my $0.02.
#29 |
Member#: 191212
South East
Vehicle:'07 Forester XT-5MT ToBe: E85 TD06SL2 8cm 20G |
^very difficult to get a quality weld job, that won't last and will compromise your downpipe, also why reintroduce exhaust into the system. EWG muffler is the best alternative in terms of cost, performance and reliability, it is a no brainer. A virgin downpipe will be easier to unload too at the classifieds.
#30 |
Member#: 87081
NESIC
Vehicle:2005 JrTuned 30r STi PSM/CF |
another alternative: get a bigger turbo that takes longer to spool, then you wont need to hear it all the time, just when you want a good kick in the pants
#31 |
Member#: 256134
NWIC
Vehicle:2005 Baja Turbo 6MT |
Plumb it back in to the intake
![]() Sorry couldn't help myself. |
#32 |
Member#: 27854
Vehicle:STI, WRX, GTR, EVO, BMW, Porsche, + More! |
I have used the Supertrapp on a bunch of rotated turbo kit Subarus for customers and it has worked exactly as intended every time. I've never had an instance where boost becomes uncontrollable due to restricted flow. The only difficult part is that the inlet into the muffler is not the same size as TiAL's outlet tube so you need a reducer pipe.
-Ty |
#33 |
Member#: 82720
RMIC
Vehicle:1993 any 93 + subaru dirty or snowy |
its just too fun running someone just under gate pressure then letting the gate open... GRRRRRRRRRRRRRRRRRRRRR !!!! she growls when the gates open. learn to drive JUST under the gate opening.. only when needed do you "unleash the beast!"
#34 |
Member#: 86061
How much does the supertrap drop the noise level? Would you say it's cut in half? more/less?
#35 |
Member#: 191212
South East
#36 |
Member#: 86061
At work now but will definitely check those out when I get home. Thanks!
#37 |
Member#: 282899
If the sound of the EWG is annoying and as a daily driver you aren't committed to it then get rid of it. Its purpose is to dispose of those gases and as so the noise is made, it is simple physics that it makes that noise. If you wanna quiet the cabin do so with sound deadening material but don't alter flow to block noise if your car truly needs a EWG then it needs to not be tampered with and in all reality, blatantness, and honesty I would say get used to the sound of fine mechanics or remove it.
#38 |
Member#: 95901
SWIC
Vehicle:2004 WRX Wagon White |
The Supertrapps look simple, easy, and judging by the videos effective. So affordable at ~$60.
#39 |
Member#: 294424
South East
Vehicle:1998 Impreza STI RA White |
you could always extend the pipe to its not dumpped right below your feet. You know like aim it to side or farther back behind you. let the sound out around the bottom of the left or right b pillar.
#40 |
Member#: 191212
South East
^too much strain at the welds having a long pipe.
#41 | |
Member#: 323869
W. Canada
Vehicle:2000 ST-outback White/Grey |
Any professional welder should be able to do a fine job plumbing the ewg dump back into the exhaust. Running a small flex pipe alleviates the extra stresses put onto the downpipe by running the dump back into it. Also, as long as it's plumbed back in far enough into the dp and at the correct angle, it won't affect flow that much. Hell, if it's designed correctly it might even help flow at high rpm's. |
#42 |
Member#: 279660
Vehicle:LOL Celery sits down to pee |
wtf, seriously? i love the noise.
#43 |
Member#: 287974
Plumb it all the way to the back ad make It look like you have duels haha
#44 |
Member#: 191212
South East
^There is an Sti with a dump tube on the front fender, can't find the pic but you get the idea.
![]() Last edited by V8 GTFO Lesbic WGN; 09-25-2012 at 05:17 PM. |
#45 | ||
Member#: 140444
NWIC
Vehicle:05 Stage Free LGT ATP 3076, 6MT, AVO FMIC |
Another benefit of an EWG is that you get an actuator with top and bottom ports, for better boost control. You can hook up the solenoid in ways that aren't possible with a regular single-port IWG actuator. You can run more boost with the same-strength WG spring, or you can run a lighter WG spring and have better part-throttle driveability. Another benefit of an EWG is that you get a bigger wastegate port to fix boost creep. Another benefit of an EWG is that you can control boost, which is a real problem when your turbine housing doesn't even have an internal wastegate. ![]() (And as for me, personally, I'm going to switch to one just because removing my IWG will allow me to clock the compressor cover, and that will allow me to run a shorter charge pipe, with fewer bends between the turbo and the intercooler core.) |
#46 |
Member#: 108051
Vehicle:2005 TickingTimeBomb Jr tuned TT Sleeved |
Putting these traps on the EWG will be like making your W/G smaller better chances of boost creep on a high power setup.
Best bet would be to buy the perrin dual tube CBE and run your EWG to the smaller second tube! |
#47 |
Member#: 191212
South East
^you are still routing the gases to a back pressure environment.
#48 |
Member#: 191212
South East
#49 |
Member#: 191212
South East
Now just need to find a competent fabricator.
Mock-up dump tube using PVC pipe and Gorilla tape. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by V8 GTFO Lesbic WGN; 01-21-2013 at 12:18 AM. |
#50 |
Member#: 237145
SCIC
Vehicle:02 WRX 12 FXT |
^ how much black soot are u going to find near the super trap?
| Thread Tools | |
| Display Modes | |
| Quieting Down an Exhaust | digitalboy40 | Newbies & FAQs | 13 | 06-14-2007 03:05 PM |
| How much will a small muffler quiet down an EWG? | scooterforever | Factory 2.0L Turbo Powertrain | 4 | 03-22-2007 01:16 PM |
| Anyone to quiet down an exhaust system? | schooby | Normally Aspirated Powertrain | 21 | 09-19-2006 12:00 AM |
| How to quiet down a TBE? | WRB4U | Factory 2.0L Turbo Powertrain | 4 | 08-06-2003 08:55 PM |
| What can I do to quiet down my new exhaust? | Robmat | South East Region Forum | 4 | 07-06-2001 12:18 PM |
