Mid Atlantic Impreza Club
Closed Thread
Old 08-21-2002, 02:47 PM   #1
SubyNewbie
Member#: 9529
2011 Forester 2.5X
Dark Grey
Default I wore a flat spot in my tires, what should I do ?
Last night I had to slam on my brakes to keep from hitting some Idiot in a Ford Explorer. My tires locked up and slid a little ways, and I think I've worn a flat spot in them. It kinda feels like a bent rim, but I didn't hit anything, so I'm assuming that's what happened. Any suggestions on what I should do ? Take it to get new ones ? Wait and see if it goes away ?
SubyNewbie is offline
Old 08-21-2002, 02:47 PM   #2
blaster88
Member#: 1109
1999 Suzuki Samurai
Blackish
Spin em
blaster88 is offline
Old 08-21-2002, 03:06 PM   #3
beastcivic
Member#: 17795
2002 Impreza WRX
Platinum Silver Metallic
You can have them shaved. Take it to a tire place and have them check the 'run out' on them. Your ABS didn't kick in?
beastcivic is offline
Old 08-21-2002, 03:38 PM   #4
SkToBe
Ghost Mod
Member#: 1278
2001 RS
Normally a shop won't shave used tires because of the damage they can cause to the cutting teeth.
You really only have too options that I can see:
Try to have the tire re-balanced or get a new tire.
SkToBe is offline
Old 08-22-2002, 09:16 AM   #5
SubyNewbie
Member#: 9529
2011 Forester 2.5X
Dark Grey
Beast, my model doesn't have ABS, I believe it only came in the SE on my model year. I have a base model, didn't want all that added weight .
Old 08-22-2002, 10:16 AM   #6
beastcivic
Member#: 17795
2002 Impreza WRX
Hm, ok. I thought since like... 1990 all 'semi expensive' cars had abs. Oh well, I'm wrong. =)
Old 08-22-2002, 11:03 AM   #7
bajcsi
Member#: 14777
2012 WRX Limited
How much weight does ABS add on a 240sx? Besides, skidding tends to be a slower way to stop
bajcsi is offline
Old 08-22-2002, 12:11 PM   #8
SilverBoosted
Member#: 7764
11 Edge Sport
Kona Blue Metallic
Flat spot=replace tires no if and or buts....
SilverBoosted is offline
Old 08-22-2002, 12:30 PM   #9
SubyNewbie
Member#: 9529
2011 Forester 2.5X
Dark Grey
Dang, Silver that's not what I wanted to hear .
It's not the ABS that adds a lot of weight, it's all the other options along WITH the ABS that came on the SE models that add up to quite a bit of weight. Heavier speakers for the upgraded stereo, heavy electic motors for the power windows and moon roof and rear wiper. Heavier interior styling. I searched out a base model when I bought it because my ultimate plan to strip it all out and fabricate it into a full race car. Well, maybe not full, cuz I want to be able to still drive it on the street. But I want to go pretty well all out.
Old 08-22-2002, 07:04 PM   #10
ChrisDP
Member#: 5879
'02 WRX SDN 5MT
STS Civic, ITA Integra
Flat spots eventually seem to go away. Either that, or you get used to the vibration
BTW, locking up the brakes sure seemed to work better than ABS or threshold braking for SCC on their WRX when they did the braking test.
ChrisDP is offline
Old 08-23-2002, 08:49 AM   #11
SubyNewbie
Member#: 9529
2011 Forester 2.5X
Dark Grey
Hmm, well I don't know about the tires they used, but the ones I got sure did get pretty dang sticky afterwards, that's probably how it helped them. Not my idea of a good solution to get traction though .
I think I'm just gonna go burn these ones off and get these Yokohama's I saw on TireRack. They're $17 cheaper, and have a way more aggressive tread pattern.
Old 08-23-2002, 09:10 AM   #12
KC
Member#: 442
16 SS
00 S2000
If you feel/hear the tumpa-thumpa-thumpa-thumpa-thumpa-thumpa when driving, you need a new tire. No doubt about that. What would happen is if you gradually braked to almost lock-up, the wheel with the flat spot would lock up on the flat before any of the other tires.
I did that to one of my new Azenis' early this year. I unplugged the ABS to 'see what would happen'. Well I found out.
--kC
KC is online now
Old 10-19-2005, 03:11 PM   #13
joohnsonrg
Member#: 98937
--kC
If you have new brake pads, will this stop the flat spot.
joohnsonrg is offline
Old 10-19-2005, 03:24 PM   #14
joohnsonrg
Member#: 98937
Any Suggestions what i should do about the flat spot on each tires.
Old 10-19-2005, 03:25 PM   #15
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Will new brakepads magically change the surface of the tire?
Butt Dyno is offline
Old 10-19-2005, 03:29 PM   #16
joohnsonrg
Member#: 98937
I still have flat spot in all four tires,
Old 10-19-2005, 03:32 PM   #17
joohnsonrg
Member#: 98937
If you replace the brake pads, will that change the suface of each tire.
Old 10-19-2005, 03:33 PM   #18
rogue
Super Moderator
Member#: 7977
100% Abuse
Hello old thread.
Fill in the flat spots with Windoweld.
rogue is offline
Old 10-19-2005, 03:34 PM   #19
joohnsonrg
Member#: 98937
If change all brake pads, will stop the flat spot
Old 10-19-2005, 03:38 PM   #20
rogue
Super Moderator
Member#: 7977
100% Abuse
*popcorn*
rogue is offline
Old 10-19-2005, 03:39 PM   #21
joohnsonrg
Member#: 98937
Should i get new tires
Old 10-19-2005, 03:39 PM   #22
rogue
Super Moderator
Member#: 7977
100% Abuse
you may have worn flat spots on your wheel bearings and axles as well, I'd replace the drivetrain to be safe.
rogue is offline
Old 10-19-2005, 03:41 PM   #23
joohnsonrg
Member#: 98937
What is windoweld
Old 10-19-2005, 03:43 PM   #24
joohnsonrg
Member#: 98937
Will brake pads that flat spot
Old 10-19-2005, 03:44 PM   #25
rogue
Super Moderator
Member#: 7977
100% Abuse
pads spot will
rogue is offline
Closed Thread
my speakers rattle on my door what should i do 04 Slo Sti Car Audio, Video & Security 3 11-29-2007 10:01 AM
Flat spots on my tires dyslexicwrx Tire & Wheel 1 01-28-2005 04:39 PM
my friend....what should he do?(girl trouble) AltimaJay Off-Topic 10 05-28-2004 01:35 AM
Ruined my motor what should I do? d_a_Go_02_wRx! Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 07-05-2003 05:32 PM
Next Mod for my REX? What should I do??? JoeBloggz23 New England Impreza Club Forum -- NESIC 3 07-02-2001 07:44 PM
