Welcome to the North American Subaru Impreza Owners Club Wednesday March 4, 2015
Old 03-29-2012, 07:42 PM   #1
02redwagone
Member#: 87067
02 Old but tasty
SRP
Default 8K Shell RT6 results
As was expected.
02redwagone is offline   Reply With Quote
Old 03-29-2012, 07:54 PM   #2
subi400
Member#: 216984
1996 Impreza outback
Green
Nice results!!
I have a few friends that think the shell rotella T-6 is not a good oil of which I told them they don't know what they are talking about.....
So, you added no oil correct after the last change right?
subi400 is offline   Reply With Quote
Old 03-29-2012, 07:56 PM   #3
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
I start thinking about changing mine at 6k and usually get it done by 7k miles...but im not worried about it if it goes past that
and I have never had to add any oil between changes with the T6, either
Old 03-29-2012, 08:18 PM   #4
02redwagone
Member#: 87067
02 Old but tasty
SRP
None of this used ever... and Ive tried.
Old 03-29-2012, 10:08 PM   #5
Ernest
Member#: 45076
2004 Stg2 Wagon 4eat
And people still question whether they should use it.
Ernest is offline   Reply With Quote
Old 03-29-2012, 11:51 PM   #6
bluesubie
Member#: 767
04 FXT
I clicked on this thread looking for a used oil analysis, not an unused oil analysis! Where is it ?!?
Are you stock? What air and oil filters? Driving conditions? A 25 mile commute daily and not exceeding 55 mph or 4,000 rpm's? Details please!
-Dennis
Old 03-30-2012, 05:34 AM   #7
02redwagone
Member#: 87067
02 Old but tasty
SRP
-Dennis
Oil Filter:Purolator Pure One 14612
Air filter: Amsoil dry panel in the stock intake.
Its been very good for me.
The silicon in the sample is probably in part from having the whole inter-cooler and duct-works apart three times in the past month and dust falling in.
Honestly i have more short trips and city driving on this sample than Ive had in years. Once it's up to temp I just drive it...in short piles of whoosh. Its had a pump gas pnp tdo4 at 20psi for a few years. With a bunch of add-on stuff. It just runs very clean. Ive had it long enough to know how it likes a clean positive battery terminal, very little slack in the throttle cable, shell gas preferably from pump#3, check the oil to make sure...yup full again... ect. Minimalistic DD setup really.
Old 03-30-2012, 08:54 AM   #8
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
I like this oil as well, but in my DD FXT it seems to burn off faster than some. I have switched to Schaefers 5w40 and have been running that for the last 15000 miles with no burn off and great oil analysis results. Car has 125000 miles on original engine running vf48 with supporting mods.
Tony
Old 03-30-2012, 04:09 PM   #9
subi400
Member#: 216984
Green
I know exactly... Someone I know thinks that he needs to use a 5w30 castrol synthetic in his 04 wrx wagon because that is what subaru recommends is a 5w30 and I was like.....d000000d....you need to READ up on how many posts about a 5w30 has sheared down and caused problems for subaru owners with a turbo subaru...
He said that these people who think that the shell T-6 is one of the best oils don't know what they are talking about and need to provide scientific evidence to show him why this oil is good and so I posted this thread about this oil analysis....
Old 03-30-2012, 04:13 PM   #10
subi400
Member#: 216984
Green
Tony
This^^^ is ok because yeah it was still protecting but going to another 5w40 or something really similar is still going to protect your engine. I want to run this oil eventually but the bottom line for people is picking a robust oil that is going to handle what you throw at it and then some
So, this oil analysis is just another indication that it really is a good oil for quite a few people.
Old 03-30-2012, 04:52 PM   #11
Ernest
Member#: 45076
This post shows that I could probably go a year without changing my oil - I only put on about 8K a year, but I just change at 6 months regardless of miles. Car loves it, no burning or anything.
Old 04-01-2012, 03:31 PM   #12
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
stupid people are stupid and even when you hit them on the head and make them bleed with the proof...they still believe their wives tales and faulty shade tree logic and old, outdated, bull****
Old 08-04-2012, 12:29 AM   #13
02redwagone
Member#: 87067
02 Old but tasty
SRP
As was expected again... Old rusty is a tank. Recently hit 30 mpg after fresh maf cleaning and plugs.
Old 08-04-2012, 02:22 AM   #14
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
Great to hear!!
I'm usually running 4-5k between oil changes (with no UOAs) but I lagged a bit between last October and May and ended up going about 7k. I do check the oil often though and end up adding about a quart every 2k so it does get freshened up, but I was kicking myself for going that long and hoping I didn't do any damage.
Glad to see you're able to run 8k for the last 3 OCIs and everything looks good!!
*even better that they're saying you could run 10k miles!!!
z is offline   Reply With Quote
Old 08-04-2012, 09:31 AM   #15
bluesubie
Member#: 767
04 FXT
I don't know of I'm more amazed at the good uoa, or the fact that you didn't add any make-up oil for 8,000 miles. I may have to return this Mobil1 10W-30 High Mileage that I just picked up. Are you the original owner? I'm wondering what kind of break-in was done.
-Dennis
Old 08-04-2012, 05:23 PM   #16
424wrx
Member#: 171948
08 wrx vf52 swap
best et,12.6@108.7
-Dennis
ive used t6 for about 30k miles of 44k since new on my 08 wrx. ive also never had to top off my oil level. thats at 22psi and stage 3. it holds up very well.
424wrx is offline   Reply With Quote
Old 08-04-2012, 08:09 PM   #17
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
-Dennis
i never have to add oil between changes either and i dont go less than 6k miles...usually change it somewhere between 7k and 8k...but i dont freak out if it is a bit longer
Old 08-05-2012, 01:39 PM   #18
02redwagone
Member#: 87067
02 Old but tasty
SRP
-Dennis
Got it with 27 k on it. It had come to Alaska from Montana. By all indications towing a little u haul trailer. It had allot of brush in the bumper cover and impact scrapes underneath when i got it.
I'm assuming it had a harder break in and allot of varied speed highway time.
It drank 5/30.
Old 08-07-2012, 04:21 AM   #19
calishere
Member#: 326039
2008 STI
Aspen white
I recently bought my sti and he was using mobile one. I switched to t6 after driving 1300 miles back from new York and def felt the difference.
calishere is online now   Reply With Quote
Old 08-07-2012, 10:35 AM   #20
kingme
Member#: 280943
'11 WRX
Samesies. I even started doing UOAs every other oil change because they weren't very interesting. Doesn't matter what type of driving I do, the UOAs are always perfect. The stuff just works.
kingme is online now   Reply With Quote
Old 08-08-2012, 05:40 PM   #21
oaklandish_WRX
Member#: 267339
2002 0[[XXXXoXXXX]]0
MBP
Looking forward to my 8-9K mile OCIs...
http://www.bobistheoilguy.com/forums...2696493&page=1
oaklandish_WRX is offline   Reply With Quote
Old 08-09-2012, 10:23 PM   #22
424wrx
Member#: 171948
08 wrx vf52 swap
best et,12.6@108.7
how could you feel a difference in motor oils?
05 WRX shell, parts, 02 WRX shell gotawd Complete Car Part-Out 144 06-27-2012 10:39 AM
Anyone riding 7k/7k or 8k/8k in Houston? dragosdor Texas Impreza Club Forum -- TXIC 15 07-19-2011 12:35 PM
So my 8k motor lasted 8k miles........ godforbid67 Built Motor Discussion 184 11-11-2010 03:01 PM
98-01' RS Shell or 02' WRX Shell Rallypro7 Private 'Wanted' Classifieds 2 07-25-2009 08:44 PM
who did i fallow on rt6? ^jynx^ New England Impreza Club Forum -- NESIC 1 11-21-2001 01:17 AM
