Old 03-30-2012, 10:28 AM   #1
mejifair
Member#: 11356
2012 WRX STi Hatch
Default Weird CEL & Traction Control notification
Hey all,
Thanks in advance for any help you might be able to provide.
I have a BONE STOCK 2012 STi with almost 3,000 miles on it. Yesterday I was following a semi up an on ramp, and was in 2nd gear for a while sitting at about 5,000 RPM. I made normal shifts from 3rd to 4th and when we got on the freeway I zipped around the semi at WOT (in 4th) almost immediately the CEL started blinking and the traction control light went off. It blinked for just a couple of seconds and then went away.
Does anybody have any idea what happened? Would a code be stored that I could pull?
And please, only say things like "you blew a ringland", "your engine is shot", "you better get a full compression and leak down test done", "If you had a Cobb AP you would not have this happen" or other such thoughts ONLY if you really think they are valid.
Of course, I will get flamed for even asking for that, but hopefully somebody has an idea of what might have happened.
Thanks,
Erik
mejifair is offline   Reply With Quote
Old 03-30-2012, 10:38 AM   #2
LTD77
Member#: 257416
2011 STI Sedan
Dark Gray
hmmm...see if you can pull a code out of it. I had a similar situation where I went wot in 5th on the highway. My car is not stock though and my check engine light stayed on and the car stayed in sport mode. I was making too much boost. I doubt that is any help, I am just rambling on this morning.
LTD77 is offline   Reply With Quote
Old 03-30-2012, 08:57 PM   #3
mejifair
Member#: 11356
2012 WRX STi Hatch
I will pull the code(s), if any and see what they say. Thanks!
Old 03-30-2012, 09:05 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Flashing CEL is a real-time misfire. If the light did not remain on steady there may not be a code stored.
Since it's a new 2012 you should have a dealer look at it.
Old 03-30-2012, 10:12 PM   #5
mejifair
Member#: 11356
2012 WRX STi Hatch
Whoa - thanks I will set something up ASAP.
Thanks!
CEL and Traction control light came on... evane Newbies & FAQs 4 12-14-2010 11:59 AM
09 Impreza - CEL and Traction Control light, blinking Cruise Control CrotchMonster Service & Maintenance 4 10-17-2010 03:38 PM
08 WRX: Hill hold, ABS, & Traction Control lights on dash Shohin General Community 7 01-23-2009 08:56 AM
Already get CEL, no traction control light, and blinking cruise control! Shohin Newbies & FAQs 17 02-04-2008 01:08 PM
ABS & Traction Control Lights Won't Go Out Err 55 3rdsub Tribeca Forum 12 12-16-2007 06:17 PM
