Old 08-21-2002, 04:13 PM   #1
roybfr
Member#: 14456
09 BMW 335i Sedan
69/72/01 Corvettes
Default Anyone with TXS Stage 4 and their new TMIC
I am looking for anyone who has added the new TurboXS TMIC to their Stage 4 setup and had their unichip remapped. Since the upgrade and remap what has the but dyno told you.
Troy
roybfr is offline   Reply With Quote
Old 08-21-2002, 06:02 PM   #2
SGOSWRX
Member#: 10921
04 04 STi
12.8 @ 105 mph
I have the new TMIC with the stock Stage 4 program. I've noticed some increased power in the midrange. The weathers so hot and humid its hard to compare track times. I ran 8.24 @ 85mph in the 1/8 mile last week in 100 degree heat index.(very hot and humid)
My previous best was 8.18 @ 84 before the new TMIC. This time was done in better weather. (hot but dry)
With some better air I'm sure I can beat my previous best.
I'm confident I can run high 7s in the 1/8 mile with some cooler drier air.
I live in S. Florida were its so hot and humid most the year. Thats why I decided on getting an upgraded IC. If I lived up north where the weather was only hot a few months out of the year I wouldn't get this mod. $1000 is a lot of cash for a relatively small increase in HP.
The main thing I noticed with the new IC is the increase in boost pressure. I get about 18psi boost at the setting that used to give me 16psi. So the turbo is working much easier. That should prolong turbo life and reliability. I think that is the most important thing about upgrading the IC.
SGOSWRX is offline   Reply With Quote
Old 08-21-2002, 08:35 PM   #3
Si2WRX
Member#: 13173
309 hp on 93 + W/I
on Dyno Dynamics
I'm not sure there is a remap available yet. So my results are similar to SGOSWRX's.
Overall the car is consistently stronger. Boost response is very good.
Here's a good comparison and the only modification was the TXS TMIC:
Stock intercooler on cool night, best of [email protected]
TXS intercooler on hot day (130+ track temp), best of [email protected]
I can't wait to run on another cool night
Erik
Si2WRX is offline   Reply With Quote
Old 08-21-2002, 10:10 PM   #4
HS WRB-rex
Member#: 7218
2002 Impreza WRX
WRB Pearl
I'm sure there will be an optimized map for you guys soon. I was talking to phil a few weeks back and he said that his car gained about 35hp with the new TMIC, for some reason I forgot to ask if that was wheel HP or est. crank numbers. Either way, thats a huge gain and hopefully there will be something for you guys to pull out similar gains.
HS WRB-rex is offline   Reply With Quote
Old 08-22-2002, 12:16 AM   #5
roybfr
Member#: 14456
09 BMW 335i Sedan
69/72/01 Corvettes
IIRC there is a map for it now, but there was not when it was first released.
Old 08-22-2002, 12:36 AM   #6
MAXXPSI
Member#: 14696
2003 Dodge Silver
SRT-4
to all who have the stage 4, hows your tranny and how do you launch your subie
MAXXPSI is offline   Reply With Quote
Old 08-22-2002, 08:42 AM   #7
Si2WRX
Member#: 13173
309 hp on 93 + W/I
on Dyno Dynamics
My tranny is still in one piece (knock on wood). Try to be nice to it
Drag launch is something like 5000rpm slipping the clutch off the floor.
As for the map... I will check to see if they really have one. The 35hp Phil gained was because of the TMIC and the new ECU they have.
Erik
Old 08-22-2002, 08:56 AM   #8
n20x3whitewrx
Member#: 21511
13.0 @104mph
with massive wheels spin!
i have not seen any better times since doing the tmic and uppipe install. no better times but it seems to breathe a lot better and run coolerbut my ets are the same.why.? exactly the same times before and after the tnic and txs uppipe. why?im a very consistant driver and i cant figure it out.car runs great.
n20x3whitewrx is offline   Reply With Quote
Old 08-22-2002, 09:05 AM   #9
roybfr
Member#: 14456
09 BMW 335i Sedan
69/72/01 Corvettes
I may just hold off for now, get the Utec when it comes out and then pick up the new I/C next spring before it gets hot here again.
Troy
Old 08-22-2002, 10:19 AM   #10
motoxphil
Member#: 5094
11.96, 1.64, 115mph!
n20x3whitewrx,
Try lowering your boost as you may be running a little leaner than optimal, which may cause your ecu to pull timing. If you are running a stage 2 kit lower your boost to about 15.5psi. You can also send back your Unichip and we'll add more fuel.
If you are running a stock turbo, it's not likely you will pick up +30HP like the STG4 guys. In the quarter mile they are picking up about 3mph (108-109) which equates to about 30 more HP at the wheels.
Phil
TurboXS
motoxphil is offline   Reply With Quote
Old 08-22-2002, 12:24 PM   #11
HS WRB-rex
Member#: 7218
2002 Impreza WRX
WRB Pearl
phil, you've got mail
wrx with txs stage 4 yayitzian Bay Area Impreza Club Forum -- BAIC 3 08-29-2003 04:52 PM
Fuel Rail with TXS Stage 4 BassMan097 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 06-03-2003 09:12 AM
Injen cai with txs stage 4 yes or no? datdudedennis Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 02-21-2003 12:41 AM
TXS Stage 4 and TMIC ?? camdoc Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-18-2002 03:18 AM
Anyone with TXS stage II and a Blitz SBC-id? Tronner Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-25-2002 10:04 AM
