Old 08-21-2002, 04:36 PM   #1
MrZone
Member#: 6785
Default EGT bung on manifold.. some adviced needed
hi all.. I am about the to install the Greddy EGT sensor on the manifold.. I will be giving this to the machine shop to do the tap.
My question is... after the tap the manifold and installed the bung(or adaptor.. whatever it is call).. does the connection/thread between the bung and the manifold require any sealant/loctie/tape? I just want to make sure no leak...
And.. I have heard from everyone that when I screw in the sensor into the bung.. it will require some high temp. loctie... right?
pls help.. thx
Wilson
MrZone is offline   Reply With Quote
Old 08-21-2002, 05:10 PM   #2
tnmn28
Member#: 16071
2005 G35 Sedan
Twilight Blue
Here check this thread:
http://forums.nasioc.com/forums/show...hreadid=230569
stevedood has some answers/comments
tnmn28 is offline   Reply With Quote
Old 08-21-2002, 05:10 PM   #3
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I tapped mine myself and just wrenched it into place. No locktite or anything. It hasn't come loose at all. One point of note though, I bought and used a tapered tap. This means that the hole at the outside is larger than the hole on the inside. I think you are fine with it being threaded in and torqued down decently, just make sure that they use a tapered tap.
And don't forget, the GReddy EGT bung uses a 1/8" BSPT-28 thread, not a standard NPT.
-Jon
www.nothingserious.net
Old 08-21-2002, 07:48 PM   #4
adam99rs
Member#: 20
Stimpy is right on the $$.
And we don't use loctite either....wouldn't hurt I suppose, but I ahve yet to find it necessary
adam99rs is offline   Reply With Quote
Old 08-21-2002, 08:02 PM   #5
teiva-boy
Member#: 22825
Anti-seize wouldn't be too bad of an idea though.
teiva-boy is offline   Reply With Quote
Old 08-21-2002, 11:07 PM   #6
WizardBlackWRX
Member#: 14979
I wouldn't do that.
WizardBlackWRX is offline   Reply With Quote
EGT bung on aftermarket headers? mannyOlicious Newbies & FAQs 3 10-09-2008 08:40 AM
installing egt bung on coated headers? orionh2215 Newbies & FAQs 6 09-26-2007 04:28 AM
plugging EGT bung on Header? knertified Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 11-10-2006 09:50 AM
where to put the EGT bung on the header? Drink Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 07-08-2006 05:28 AM
FS: Borla Header w/EGT Bung on Cyl. 4 Jard Mid Atlantic Impreza Club -- MAIC 4 02-28-2005 12:34 AM
