Old 08-17-2002, 05:40 AM   #1
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
Default Greddy FMIC verses Blitz FMIC...
Knowing that the Greddy is typically $100 cheaper in price over the Blitz, which FMIC performs better, even though i'm asking a completely USELESS question since NOBODY has any dyno number for maybe 2% of the total performance parts out on the WRX.
But which kit has a bigger core? I guess that will be the turning point to which kit is higher performing.
Jay
Diversion is offline   Reply With Quote
Old 08-17-2002, 11:03 PM   #2
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
Bump, someone would of had to research this in a least. I don't know where to find the core sizes, any clues?
Jay
Old 08-18-2002, 01:26 AM   #3
KOBIR
Member#: 20370
Default fmic
Jay
hi
the core off the greddy as well as the blitz is 600*240*76
KOBIR is offline   Reply With Quote
Old 08-18-2002, 01:52 AM   #4
wRxbeater11
Member#: 12682
bump
wRxbeater11 is offline   Reply With Quote
Old 08-18-2002, 01:53 AM   #5
Imprezer
Dynamic Uno
Member#: 1
2011 Impreza WRX STi
The cores are not the same size. The Blitz one has 2 more rows than the GReddy core. I had the pics comparing the two somewhere. I will try to find them.
-Alex
Imprezer is offline   Reply With Quote
Old 08-18-2002, 02:48 AM   #6
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
Do you think 2 more rows is worth an extra $100??
Do either the Greddy or Blitz kit already have a flange for a BOV?
Jay
Old 08-18-2002, 02:51 AM   #7
wRxbeater11
Member#: 12682
I know the greddy doesn't, u have to get some one to weld a flange. and its aluminum so don't go trying to weld steel on it
-=melo
Old 08-18-2002, 05:26 AM   #8
GimpWRX
Member#: 11704
0209 02/09 WRX's WRB
02built sti block,09stock
well if your gonna spend that much money for the intercooler, why not just drop another 100 for the bigger one
GimpWRX is offline   Reply With Quote
Old 08-18-2002, 07:18 AM   #9
ellisnc
Member#: 4229
2003 S2000
Did someone say track day
AFAIK neither one is that great... Both are 2 row. The Greddy that Alex has is the spec R which isn't sold here. There's like a spec V and a spec R. I'm not sure what the exact differeces are but maybe one is a 2 row and one is a 3 row? Or different fin design...
ellisnc is offline   Reply With Quote
Old 08-18-2002, 11:43 AM   #10
STEALTH-WRX
Member#: 7822
Multi layer snot green
alright here we go:
the greddy core is smaller than the blitz core and they both have the same design of a tube fin. heres where everyone should be concerned. the blitz has about 3 feet of piping extra as it goes under the engine and the greddy over the engine. ( lag ) Both do not have blow off valve mounts. on the greddy, the driver side piping goes to the throttle body and it is opposite on the blitz. personally if you dont want to do any modifications to make the blitz work the best than get the greddy.
i am making a kit for the blitz that routes the tubing from the turbo over the engine, then straight down and then to the intercooler. that should make the blitz all around better, because of the short piping and the increased core size.
STEALTH-WRX is offline   Reply With Quote
Old 08-18-2002, 12:04 PM   #11
WRXThis
Member#: 3960
What turbo are you running? If you have a smaller turbo get the Greddy FMIC because it won't take as long to fill the pipes as it would if you had the Blitz FMIC. This in turn will equal less lag for you. I run the Blitz but I have an 1820 so my turbo is big enough to fill the Blitz pipes perfectly. My buddies and I just installed a Greddy FMIC yesterday.
WRXThis is offline   Reply With Quote
Old 08-18-2002, 12:17 PM   #12
STEALTH-WRX
Member#: 7822
the 2 extra rows are not significant to noticed extra lag. you maybe would see 20 rpm increase from those rows.
Old 08-18-2002, 01:05 PM   #13
Imprezer
Dynamic Uno
Member#: 1
Yes, they are both 2 rows, but I mean that the Blitz one is taller by 2 whatever they are. Rows? I honetsly don't think it matters, because they are tucked in behind the bumper anyways.
GReddy now has both R-SPL and V-SPL FMICs available in the US.
I prefer GReddy. The piping is much nicer and larger. Also, the piping allows you to do the fliparoo of the manifold with less headache.
-Alex
Old 08-18-2002, 01:41 PM   #14
ellisnc
Member#: 4229
2003 S2000
Rows means how thick they are... have you ever seen a 4 row IC on a skyline
Old 08-18-2002, 02:00 PM   #15
Imprezer
Dynamic Uno
Member#: 1
So how do you call what I was talking about? Tubes? 2 extra tubes? LOL.
I know row means thickness, but those are also rows, hehe.
-Alex
Old 08-18-2002, 03:32 PM   #16
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
I would go with the GReddy as the piping is shorter and the pipe from the turbo to IC is thinner than the IC to TB one allowing for less drag.
I still think the GReddy would be a great one for the VF-22 to 34 as long as you don't go above 22psi, then the Sper-R would be better.
Bottom line is here in Puerto Rico, ANY FMIC is better than a TMIC!
Leo
Leonardo is offline   Reply With Quote
Old 08-18-2002, 05:15 PM   #17
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
So then in comparison, what is the power bandwidth of an MRT FMIC compared to a Greddy?
Jay
Old 08-18-2002, 05:54 PM   #18
BlueWRX
Member#: 7898
2008 g37s
i read somewhere that greddy fmic v-spec is not efficient over 18psi of boost. does that apply to vf23 also? or just for bigger turbo such as pe1820?
BlueWRX is offline   Reply With Quote
Old 08-21-2002, 12:05 PM   #19
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
Default Re: fmic
Originally posted by KOBIR
hi
Can anyone confirm the core size?
What size piping do the different brands use? I'm looking into making my own, so this would be very helpful.
TIA, -C
TypeC is offline   Reply With Quote
Old 08-21-2002, 12:21 PM   #20
Twelvz
Member#: 11302
11 GT-R
10.x @130+
Yeah...someone throw the MRT FMIC in this argument !!
Ryan ?
Twelvz is offline   Reply With Quote
Old 08-21-2002, 01:01 PM   #21
WizardBlackWRX
Member#: 14979
I have a Blitz and have handled a GReddy. The Blitz goes up to the top of the bumper whereas the GReddy doesn't quite as much (small difference in a relatively low effect area). The endtanks are better on the Blitz.
WizardBlackWRX is offline   Reply With Quote
Old 08-21-2002, 01:11 PM   #22
EJ20K
Member#: 23058
STi v4 RA-M800ecu
STi7 shortblock & 1100kg.
Why haven't you considered the APEXi FMIC ?
anyone can get this for the GC8 WRX ?
EJ20K is offline   Reply With Quote
Old 08-21-2002, 02:10 PM   #23
Z1 Performance
Member#: 9327
the Blitz core is slightly bigger, but tio be honest, the Blitz piping is hideous IMHO, so we opt for the Greddy. Fit and finish are excellent as well BTW.
MRT is also a nice option too..I ahve the dims someplace on that one as well.
The Apex'i is only for a GC8....we have sold them before, but it does not fit a GDA without modifications.
The bigger core in this case doesn't buy you anything...both will handle up to around a PE1820 turbo with ease. Bigger than that, and you would be better off making your own FMIC using a Spearco/Griffen core and HKS, etc. endtanks, and custom piping.
WRThis had the right idea....size your IC to your turbo and you won't be disappointed!
Adam
Z-1 Performance
www.z1auto.com
Z1 Performance is offline   Reply With Quote
Old 08-21-2002, 03:22 PM   #24
EJ20K
Member#: 23058
STi v4 RA-M800ecu
Question
Adam, what was your impression of the Apexi unit, for a road/race track car ?
Old 08-21-2002, 06:09 PM   #25
ellisnc
Member#: 4229
2003 S2000
I don't think IC's are efficient or not based on pressure... the pressure loss across them has more to do with the flow rate that the larger turbos are capable of because they are relatively efficient at higher pressure ratios compared to the TD04.
Therefore, the Greddy V spec IC might be fine at 18psi from a TD04 but would bluntly suck if you try to use it with one of the large Garrett or APS turbos that are becoming more common at the same pressure because you're cramming more air through it.
Alex, I think I would just call that extra height
where's my bumper beam? hehe
FS: GReddy WRX/Leg Turbo FMIC with Blitz SSDD BOV, all hardware/small coolant tank DeusExMachina Private 'For Sale' Classifieds 26 11-12-2005 09:10 AM
Greddy / Blitz FMIC scottm1978 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-12-2003 04:51 PM
FS soon: Greddy FMIC, UTEC, Blitz SBC id 3.... lame Private 'For Sale' Classifieds 3 08-17-2003 04:54 PM
FS soon: Greddy FMIC, UTEC, Blitz SBC id 3.... lame Bay Area Impreza Club Forum -- BAIC 0 08-07-2003 11:32 PM
aps FMIC vs blitz FMIC 99prelude Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 02-14-2002 01:52 PM
