#1 |
Member#: 11356
Vehicle:2012 WRX STi Hatch DGM |
Hey all,
Thanks in advance for any help you might be able to provide. I have a BONE STOCK 2012 STi with almost 3,000 miles on it. Yesterday I was following a semi up an on ramp, and was in 2nd gear for a while sitting at about 5,000 RPM. I made normal shifts from 3rd to 4th and when we got on the freeway I zipped around the semi at WOT (in 4th) almost immediately the CEL started blinking and the traction control light went off. It blinked for just a couple of seconds and then went away. Does anybody have any idea what happened? Would a code be stored that I could pull? And please, only say things like "you blew a ringland", "your engine is shot", "you better get a full compression and leak down test done", "If you had a Cobb AP you would not have this happen" or other such thoughts ONLY if you really think they are valid. ![]() Of course, I will get flamed for even asking for that, but hopefully somebody has an idea of what might have happened. Thanks, Erik
#2 |
Member#: 257416
Vehicle:2011 STI Sedan Dark Gray |
hmmm...see if you can pull a code out of it. I had a similar situation where I went wot in 5th on the highway. My car is not stock though and my check engine light stayed on and the car stayed in sport mode. I was making too much boost. I doubt that is any help, I am just rambling on this morning.
#3 |
Member#: 11356
I will pull the code(s), if any and see what they say. Thanks!
#4 |
Trust no one
Moderator Member#: 11170
Vehicle:02 WRX 05 GTO/11 Sonata(!) |
Flashing CEL is a real-time misfire. If the light did not remain on steady there may not be a code stored.
Since it's a new 2012 you should have a dealer look at it. |
#5 |
Member#: 11356
| Thread Tools | |
| Display Modes | |
| CEL and Traction control light came on... | evane | Newbies & FAQs | 4 | 12-14-2010 11:59 AM |
| 09 Impreza - CEL and Traction Control light, blinking Cruise Control | CrotchMonster | Service & Maintenance | 4 | 10-17-2010 03:38 PM |
| 08 WRX: Hill hold, ABS, & Traction Control lights on dash | Shohin | General Community | 7 | 01-23-2009 08:56 AM |
| Already get CEL, no traction control light, and blinking cruise control! | Shohin | Newbies & FAQs | 17 | 02-04-2008 01:08 PM |
| ABS & Traction Control Lights Won't Go Out Err 55 | 3rdsub | Tribeca Forum | 12 | 12-16-2007 06:17 PM |
