Old 03-31-2012, 02:14 PM   #1
ManualOverAuto
Member#: 304662
2001 Impreza L coupe
Sedona red Pearl
Changed the air filter today (stock intake with black box, rectangular filter, ect). It was really dirty (should have changed it a while ago) and I noticed 2 or 3 oil burn spots on the filter. About the size of a bottle cap. Again I was told I needed a new one about 9,000 miles ago.
[b]Do you think those oil spots could have been caused by my recent valve cover gasket/tube seal leak and misfire?[b]
ManualOverAuto is offline   Reply With Quote
Old 03-31-2012, 07:31 PM   #2
ManualOverAuto
Member#: 304662
Sedona red Pearl
Also, I don't have the filter anymore and forgot to take a picture of it.
I tried to get a picture off google to show what it looked like but there's nothing.
So just imagine a dirty filter with some "bottle cap" sized oil spots.
Old 03-31-2012, 11:12 PM   #3
lolol
Member#: 311801
Sometimes oil gets spat out from valve cover vent
lolol is offline   Reply With Quote
Old 03-31-2012, 11:17 PM   #4
ManualOverAuto
Member#: 304662
Sedona red Pearl
So it could be regular venting over time or from the recent valve cover gasket failure. That's good to know because I really don't want a hg problem. Not ruling a bad hg out though, I know subi's are notorious for them -_-
Old 03-31-2012, 11:37 PM   #5
lolol
Member#: 311801
Cover gasket leaking won't spit oil into the intake.
Old 04-01-2012, 12:25 AM   #6
ManualOverAuto
Member#: 304662
Sedona red Pearl
So spark plug tube seals won't either?
Damn, you got my hopes up for nothing. So hopefully it is just from the filter being super old, and not a hg problem. I should know about a hg issue when I send out my oil to Blackstone here shortly.
Old 04-01-2012, 05:46 PM   #7
lolol
Member#: 311801
No, they won't.
Search the web for "oil in intake manifold"
Oil comes form crank case or valve cover and these connections are for emission control. Overfilled oil, normal oil splashing up the lines cause oil getting spit into intake.
Check to see that oil isn't overfilled. I read here that oil level is hard to read on some Subarus due to difficulty getting a stable reading on the dipstick.
Check that PCV hose and valve are in good order. Replace air filter and observe.
Old 04-01-2012, 07:30 PM   #8
ManualOverAuto
Member#: 304662
Sedona red Pearl
No, they won't.
That's where you confuse me lol. You said that oil can come from the crankcase or valve cover. If I had a valve cover gasket leak why wouldn't that explain the oil spots?
Anyway it's not from an overfill. When the old air filter was in, the oil level was fine.
Checking the pcv valve in the next few days. Whenever I get the chance really, cause it seems pretty easy from what I've seen/read.
Old 04-02-2012, 05:15 PM   #9
ManualOverAuto
Member#: 304662
Sedona red Pearl
Replaced the pcv valve today. Super easy, and $7. The old one was pretty gunked up, although it still rattled just a little. Put in a fresh one anyway, so during the next oil change I'll check the air filter and see how it looks.
While trying to screw it in I did drop it down into the engine, ha. That was the hardest part of the whole thing, trying to squeeze my hand down there to retrieve it.
So thanks for the tip.
Old 04-02-2012, 09:39 PM   #10
lolol
Member#: 311801
Valve cover vent connects the space under the cover into intake. Cover gasket seals between the cover and the cylinder head. If the gasket leaks, oil would leak along the side of the engine and drip on the ground, not into the intake.
As camshaft and valves dance around, oil splashes around inside the case. Some mist gets carried into the vent hose connected to intake.
Make sense?
Old 04-02-2012, 10:57 PM   #11
ManualOverAuto
Member#: 304662
Sedona red Pearl
Make sense?
Yea I see what you mean now.
So when the pcv valve gets sticky or clogged that mist is forced somewhere else causing potential problems?
Also, my valve cover gasket didn't leak to the outside. It was all inside, but there was also leaky plug seals.
Oil on air filter AND spark plug boots karst Normally Aspirated Powertrain 6 11-01-2008 12:46 AM
Is it normal to have large oil deposit on air filter @ 24K? atlblu Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 03-26-2008 10:39 AM
oil pump removal = air filter? sepharad 'Old School' Subaru Forum 12 09-18-2007 08:57 AM
burnt oil on air filter BlackoutWRX Newbies & FAQs 8 05-13-2005 09:54 PM
car wants to stall after oil change, new air filter DoinkMobb Normally Aspirated Powertrain 10 06-24-2001 06:32 PM
