Old 03-31-2012, 04:48 PM   #1
schrags
Member#: 162529
2006 STI SGM
2004 4Runner
Default Throttle Position Sensor CEL p2109
Car is a 2006 STI. Motor just back together, rebuilt shortblock. Intake manifold was left completely alone. Went to start it for first time and it starts, but idle surges around 1000rpm's and throws the CEL p2109: throttle / pedal position sensor A minimum stop performance . Pushing the throttle doesn't really do anything.
Troubleshooting:
-Took off intercooler, looked inside throttle body. It was clean and you can easily push and open the throttle, and it will close itself.
-Unplugged the position sensor connector, it looked good, plugged it back in.
-accessport logging. The voltage for the tps sensor stays at 0.85, but the duty always stays at 0 no matter if you push the throttle or not.
All the searching i've done didn't really help. A lot of people had the issue but noone really concluded what they did to fix it. Some did but it was random. Just doesn't make sense the sensor would all of a sudden go bad.
schrags is offline   Reply With Quote
Old 03-31-2012, 05:08 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
disconnect the battery for a few minutes.....reconnect the battery
DO NOT TOUCH THE THROTTLE PEDAL AT ALL ! ! ! !
.....reach in and turn the key all the way over to the LAST 'click' B E F O R R E the stater engages
count to 10 slowly
put the clutch pedal down and turn the key to start the car
let it start and let it run until the engine reaches full operating temp
turn the car off and take the key out
wait 30 seconds, put the key back in and start the engine
see what happens after that
Old 03-31-2012, 05:44 PM   #3
schrags
Member#: 162529
2006 STI SGM
2004 4Runner
I have done those steps except I did not let it get fully warm. After a little bit the AFR's lean to around 20 and I shut if off.
Some additional info:
I followed some first start technique suggested by axis performance posted on a forum. I left the harness connectors near the battery out, and kept cranking to prime the engine. I then re-connected them and reset the ECU, both by unplugging battery, hitting brake and waiting, and also via accessport.
The CEL still exists after reset right when you turn the key to accessory mode.
I have noticed that with the key in acc... the throttle doesn't make an electrical humming sound in which i remember it doing all the time.
Old 04-05-2012, 09:18 PM   #4
schrags
Member#: 162529
2006 STI SGM
2004 4Runner
Took it to turninconcepts to have them swap out the throttle body and see if that was it. Turns out it was some loose wires in the connector, which glancing at looked fine. Upon my searching I saw a lot of people run into this issue when they did a lot of major work to the car. I believe this happened when I tried tucking the blow of valve to intake line behind the throttle body to install crankcase vent line. Some people solved it by replacing the throttle body but make sure it's not the connector first and that a new throttle body wasn't actually the fix, messing with the connector was.
Old 01-18-2013, 08:08 PM   #5
MonsterSubie
Member#: 246931
2006 Impreza WRX
I have an 06 Wrx and I encountered the same problem. I used the relearn procedure as mentioned by Uncle Scotty and it seems to be working so far. The next couple of days will tell all. +1 internets for Uncle Scotty.
MonsterSubie is offline   Reply With Quote
Old 01-19-2013, 11:55 AM   #6
WashWRX
Member#: 335408
From what the OP states, the TPS has a stuck in-range failure. As you described the voltage does not change and is stuck at 0.85 V, and as you saw the duty cycle for the sensor is stuck at zero. In my experience the sensor will have to be replaced and I don't see the reset procedure as the long term solution...at least that's what I have seen in my past experiences. Good luck
WashWRX is offline   Reply With Quote
Old 01-13-2014, 09:35 AM   #7
jwijnaldum
Member#: 231025
Default TPS senser/ Throttle
Hi guys,
i'm somewhat having a similar issue, i replaced my MAF senor lately and i noticed that in the moring when crank up the engine, its idles link it wants to die but it catches itself to idle normal also when i try accelerate quickly, the car wants to die but doesn't.
what i wanted to know if i have a bad spot in my TPS or do i have to replace the sensor also.
for the record im driving a JDM 2000 subaru forester sti. turbo.
Your help would be greatly appreciated
regards,
jwijnaldum
jwijnaldum is offline   Reply With Quote
Old 11-14-2014, 03:32 PM   #8
emericareaper2
Member#: 323008
02 WRX minivan
Got the same problem in my 06. Tried those methods twice, swapped throttle bodies, reset ecu several times, swapped relays & made sure my connections were secure. Still get the code & the car won't get out of limp mode. I'm gonna try getting another ECU & making sure it's not fried very stumped on this
emericareaper2 is offline   Reply With Quote
Old 11-14-2014, 05:59 PM   #9
Member#: 301037
2004 Forester XT
I had a very similar situation going on with my XT last month, also swapped a few throttle bodies over with no avail and was about ready to pick up an STI ECU as a replacement. Eventually a code for my Camshaft Sensor started popping up, replaced it and all has been well since.
-Art
art@grimmspeed is offline   Reply With Quote
Old 11-14-2014, 07:22 PM   #10
emericareaper2
Member#: 323008
02 WRX minivan
Art, thanks for the info! Do the 06's have 2 cam pos sensors? If so, which one did you replace?
Old 11-17-2014, 06:04 PM   #11
Member#: 301037
2004 Forester XT
I want to say yes, but check by the oil filler neck, if there's not one there you'll see one on either side at the back of the heads. They're an absolute pain to get to, ask me how I know
-Art
CEL P0519... check your throttle position sensor jamesfacts Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-13-2012 05:29 PM
CEL P0123 Throttle Position Sensor/Switch A Circuit High Input help GLD247 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 04-19-2010 11:15 PM
wtb: Tumble Generator Valve (TGV) sensor / Throttle Position Sensor (TPS) Sensor simprezl25 Private 'Wanted' Classifieds 0 01-10-2007 04:25 PM
Throttle Position Sensor CEL! CatchMyDrift Service & Maintenance 1 03-20-2005 02:54 PM
throttle position sensor CEL willdaddy Service & Maintenance 1 06-07-2004 04:54 PM
