#1 |
Member#: 311801
NWIC
New NGK plugs, air filter, PCV valve. Drained and filled automatic trans fluid.
Adjusted TPS as per factory service manual. Cleared check engine code and it hasn't come back since. Didn't expect any outcome, but ran Seaform through the intake. Tire inflation, fine. Car drives fine, but I continue to get 17mpg on highway, 15 city. Looking at the engine, the timing belt cover is held in place with zip ties. Perhaps the timing belt was replaced at one point. Could it be off a tooth? If so, can I check this with a timing light?
| Thread Tools | |
| Display Modes | |
| How is it that leafy green lettuce gets ahead of food I ate hours ahead of it? | Snoopy | Off-Topic | 17 | 01-02-2012 11:51 PM |
| So why is it that my obdII scanner cannot connect to my ECU (ecutek reflashed)??? | jigga | Commercial ECU Reflashes | 30 | 07-14-2006 02:34 PM |
| wtb: tranny cable clutch that will work in my 91 legacy or parts car with tranny | eph | Private 'Wanted' Classifieds | 0 | 01-01-2006 08:57 AM |
| 91 Legacy FWD wheel options | CapeRex | Tire & Wheel | 5 | 12-06-2005 12:57 PM |
| just curious : why is it that every thread I post on gets locked? confused.. | wrxg/f | Off-Topic | 21 | 08-11-2005 12:55 AM |
