Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 05-01-2012, 11:50 PM   #351
gordyzero
Member#: 56219
2011 WRX STI Limited
SPW
Originally Posted by b1aze
Where does it say that the T6 is diesel engine oil?? Heavy duty, yes.
This is where the oil debate would start. , no thanks. Its marketed as a diesel fleet lubricant. The end . I am sure its good stuff. But my OCD can't stop seeing the dump trucks and bulldozer's all over shells Rottela T6 web page.
gordyzero is offline   Reply With Quote
Old 05-02-2012, 01:29 AM   #352
purplewrx
Member#: 315291
2012 WRX
PBP
Its better that you stay away from T6. Leaves more for everybody else.
purplewrx is offline   Reply With Quote
Old 05-02-2012, 02:39 AM   #353
gordyzero
Member#: 56219
SPW
Agreed.
Old 05-02-2012, 02:58 AM   #354
J-horn92
Member#: 314815
2007 Wrx
^^^ haha I second that.
J-horn92 is offline   Reply With Quote
Old 05-02-2012, 03:22 AM   #355
gordyzero
Member#: 56219
SPW
The loyalty over bulldozer oil is impressive. This is really good ****t after all. I admit it.
Old 05-02-2012, 03:22 AM   #356
gordyzero
Member#: 56219
SPW
Old 05-02-2012, 08:00 AM   #357
b1aze
Member#: 284003
2010 Alpine 135i
I really dont understand what you have against it based on "marketing"? Its been used. Its been proven time after time after time. What has also been proven is that there are more ****ty 5W30/5W40s on the market that people seem to think, based on price alone, that it will perform better and they are, more often than not, disappointed. Just because the peg wasnt designed for the specific hole doesnt mean it cant fit.
b1aze is offline   Reply With Quote
Old 05-02-2012, 12:42 PM   #358
WRXLTD
Member#: 136314
2014 Grand Cherokee
Since we're talking oil...
I have 20 qts of Mobil 1 Extended Performace 5w30 down in my basement (leftover from my Xterra) that I will be using up in my new 2012 STI Limited...as to not waste money. Since I'll be changing oil at 3000 mile intervals, and I won't be racing...I'm not worried in the least.
I WILL be switching over to the T6 once all my Mobil 1 is gone though.
WRXLTD is offline   Reply With Quote
Old 05-02-2012, 02:32 PM   #359
zackg
Member#: 248581
2015 Impreza Sport
Red
"Conventional oil for the first 1000 miles. , bring every gear gradually through the RPM range and as close to 6,000 RPM as often as possible, no constant low engine speed, no abrupt WOT, DO NOT lugg the motor. Install Shell Rotella 5w40 , after break in period. Never use Royal Purple ".... I don't want to start yet another oil debate. But using a diesel engine oil in a gasoline engine, not interested. But I will be using 5w40 from someone intended for a gas engine. I really wanted to use RP, but he pointed out a additive in RP has been known to accumulate over time and actually clog the oil sump screen. ? First I heard of it. But all this boy racer engine oil BS is really getting old. I will just use a appropriate API grade and viscosity.
so the tech specifically told you to use rotella 5w40 and you wont?
zackg is offline   Reply With Quote
Old 05-02-2012, 04:12 PM   #360
Asharus
Member#: 276300
2015 Ford Mustang GT
Oxford White
whats so magical about this T6 oil anyway. it doesnt even have any zddp in it. brad penn or amsoil pls
Asharus is offline   Reply With Quote
Old 05-02-2012, 04:33 PM   #361
adevney
Member#: 271383
2012 WRX Sedan
Nothing. I'm sure it's a great oil but it's become a chain reaction of fanboys that will argue it to it's death. 99% of these people don't have a clue and just argue to agree with everyone else and sound smart.
adevney is offline   Reply With Quote
Old 05-02-2012, 04:52 PM   #362
Asharus
Member#: 276300
Oxford White
lol figures
Old 05-02-2012, 05:04 PM   #363
b1aze
Member#: 284003
2010 Alpine 135i
Can you really argue with Blackstone labs? TBN still good after 8k miles? Check. Flash point and CST Viscosity after 8k miles still within spec? Check. Theres nothing magical about the oil. Its readily available at almost all WalMarts across the nation and very cost effective at ~$22/gal. Are there "better" oils out there? Probably, but the T6 is easy to find and proven to work well in these engines. We are only "fanboys" because we tried it and it has worked and worked well, and we are only advocating the oil because it works.
Old 05-02-2012, 05:11 PM   #364
WaitTheresMore
Member#: 289315
2006 STi
"Frosty"
My car didnt like rottela T6 but loves German castrol 5-30. 06 sti
WaitTheresMore is offline   Reply With Quote
Old 05-02-2012, 05:31 PM   #365
kingme
Member#: 280943
'11 WRX
You are a brave man. Check out some UOAs of M1 5W-30 in the EJ. In some cases cSt viscosity drops to xW-20 after 2K miles. Though, with easy driving and short intervals, you might make it through all 4 oil changes to the T6 promised land .
Back on topic, thanks for sharing your experience OP. I find it very interesting that the Subaru tech told you to switch to 5W-40 after break-in. There have been reports of some dealerships giving owners crap about using syn 5W-40 (blaming misfires, etc. on the heavier oil) just because the owner's manual states that syn 5W-30 is required .
kingme is offline   Reply With Quote
Old 05-02-2012, 05:50 PM   #366
WRXLTD
Member#: 136314
2014 Grand Cherokee
If the Mobil 1 was the regular 5w30 I wouldn't chance it, but it's the Extended Performance 5w30...a little better.
Old 05-02-2012, 05:55 PM   #367
adevney
Member#: 271383
2012 WRX Sedan
I'm not arguing against the oil. BUT it's not the only oil out there and not running this oil in this engine is not going to result in a bad engine. I'm not even denying that I've used it before. I used it in my 03 WRX. And I'm not speaking about every person who speaks highly of it. But like I said a vast majority of the people who do, probably couldn't even tell you what's good about it or why.
Old 05-02-2012, 06:06 PM   #368
GrumpyPitbull
Member#: 313311
If you want to know about oils, and which work well and which don't, go to www.bobistheoilguy.com. There you will get way better information than you will on this site about what works and what does not.
The problem with discussing oil on a specific car forum is you get "forum favorites" based more on what the frequent posters use, rather than what works. In turn, people who know nothing then convert to that oil because if so-and-so says it's good, then it must be ... then they in-turn post about how great it is .. and so on. On this forum, that oil seems to be the Rotella T6.
Bottom line is if your using your car as a daily driver, and changing oil less than every 5k miles, there are many many oils that will work just fine for you.
GrumpyPitbull is offline   Reply With Quote
Old 05-02-2012, 06:13 PM   #369
kingme
Member#: 280943
'11 WRX
True story. The EP has a better additive pack. I'll stop there as I don't want to turn OP's thread into another NASIOC oil war .
Old 05-02-2012, 07:07 PM   #370
b1aze
Member#: 284003
2010 Alpine 135i
I certainly stated that there are probably better oils out there, and no, not running this oil will not result in catastrophic engine failure. But running lesser quality energy conserving oils will certainly increase the chance of engine damage as compared to a better, more robust oil, such as T6.
I just dont understand why people are so adamant to reinvent the wheel here. X, Y, and Z oils are proven to work well and provide lasting protection in these cars, but so many people want to use Q, R, and S because....? I cant find any sort of logic to knowingly use a product that could significantly increase the chances of damaging an ENTIRE engine. Not just pistons/shortblock but turbo and heads...
Old 05-02-2012, 08:35 PM   #371
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
German Castrol is 0w-30.
Spenk is offline   Reply With Quote
Old 05-02-2012, 10:36 PM   #372
k mier
Member#: 98000
05 sti [email protected]
0w-30 but it's thicker than mobile one's 5w-30, go figure. All my blackstone results came back great on german castrol and t6, this running e85.
k mier is offline   Reply With Quote
Old 05-02-2012, 10:46 PM   #373
WaitTheresMore
Member#: 289315
2006 STi
"Frosty"
My Bad.... but yea this oil is much thicker.
Old 05-03-2012, 01:17 AM   #374
gordyzero
Member#: 56219
SPW
Great point.. for most. Its a well liked highly respected oil for many who use it. But this IS designed for diesel engines. Which just makes me wonder why if its Soooo great why does shell make Helix 5w40 in all other markets except for the U.S. ? Helix is actually designed and intended to be used in high performance gas engines. Not to say T6 is bad. But there is other choices. Not to mention I am not even sure it meets the " SM " API certification. Explaining to SOA that my motor failed again and this time I used oil intended for a Peterbuilt... , if you don't understand my point of view. Most don't.
Old 05-03-2012, 01:23 AM   #375
gordyzero
Member#: 56219
SPW
Yes. This is the same tech who told me to change my tune and the engine internals. Which is great advice if I want to throw away money and my warranty. I can't take any chances, I don't trust this car or SOA. I am not eating a $5000.00 ****t sandwich if something goes wrong .
2011 STi Sedan 305/368 EFI Tuned krotondo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 09-22-2011 02:46 AM
***PhatBotti Tuned: E85'ed 2011 STi, 330whp!! Per Gear Data + Tuning Discussed*** PhatBotti Tuning TKR Proven Power Bragging 54 06-24-2011 11:58 AM
2011 STI OTS map vs Pro tune Jose Gordils Newbies & FAQs 6 05-09-2011 12:08 PM
2011 STi V-Limited LIPS IN STOCK! Yeah we got them! RallySport Direct Vendor 'General Sale' Forum 1 11-08-2010 04:03 PM
07 STI Blown Piston or Ring? 07stilover Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 49 01-25-2008 02:24 AM
