Old 09-24-2013, 11:44 AM   #1
remski
Member#: 151895
Default Antigravity Batteries
Hi.
Anybody has any experience with those ?
Seem to be very light.
http://antigravitybatteries.com/oem-case-clymb/
Remi
Old 09-24-2013, 01:30 PM   #2
DentMagnet
Member#: 352689
2004 Impreza
dark green but looks blak
A Ragone Chart will tell you how much of the literature on these batteries is puffery.
DentMagnet is offline   Reply With Quote
Old 09-28-2013, 12:45 AM   #3
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
actually....there are seveal options in these small lithium based batteries.....and NO...they DO work and ARE so light that you wouldnt believe it.....
i have researched these kinds of batteries for a while now, and they are quite interesting.....a lithium-iron style seems to be quite promising
a 3 pound li-fe battery can be far more powerful than the 14ish pound PC680 size agm battery
these seem to be the next step in battery evolution,...and their price is coming down
my next battery will be one of these 3 pound li-fe batteries
Old 09-28-2013, 12:59 AM   #4
Uncle Scotty
OK buy Nates beans
and energy storage density is only one consideration...of many
Old 10-17-2013, 06:01 PM   #5
2JZ
Member#: 291949
http://projectbdon.blogspot.ca/2012/...t-battery.html
local time attack guy has run the battery. No problems starting in Canadian cold winters. However he ended up draining it/killing it somehow (didnt use it and somehow had something drawing current from it by accident) Needless to say it was junk after his mistake, but otherwise they seem to work well!
Price wise... is a 10 pound deka battery for $100 that much worse than a $350 3 pound lithium battery? The cost effectiveness of that several pounds for hundreds of dollars seems like an expensive weight reduction measure, especially since batteries do not last forever and the long term usage of these batteries is yet to be discovered for daily drivers. I might try it out if the prices continue to drop and their compact size makes it more convenient to mount it behind the glove box, under the footwell etc instead of under the passenger seat
2JZ is offline   Reply With Quote
Old 10-17-2013, 09:07 PM   #6
DentMagnet
Member#: 352689
2004 Impreza
And that depends on your particular utility function.
http://www.wisegeek.com/what-is-a-utility-function.htm
My utility for one of these things is just about zero, but I only do repair and maintenance.
There may be people here who would spend a kilobuck for whatever advantage they believe this thing gives them.
Old 10-21-2013, 09:19 AM   #7
Uncle Scotty
OK buy Nates beans
the prices of these batteries has fallen a LOT lately.....that battery that you think is $350 is almost certainly available for under $200 now if you shop around.
I found the one I will be buying next on Amazon for $189 within the last week(it WAS $239 last time I searched it) which is about 2x the cost of the Magna Powersports agm battery that i now have under my passengers seat.....the weight savings of the lithium battery over the Magna Powersports battery is ~10 pounds and the specs of the lithium battery are a bit better
and maybe the poster, ABOVE, should stay out of these kinds of threads if he is only interested in routine maintenance
Old 10-31-2013, 12:49 AM   #8
nashelton
Member#: 253882
2011 STI Sedan
Dark Grey Metallic
http://www.tougetuning.com/ up in Canada sells Antigravity batteries. They have good reviews on the Toronto boards as daily driver batteries as well.
They have a 10% discount with the code adventure.
Maybe we could get a group buy in
nashelton is online now   Reply With Quote
Old 08-05-2014, 07:00 PM   #9
nashelton
Member#: 253882
2011 STI Sedan
Dark Grey Metallic
Having gone through 2 Antigravity batteries I would not recommend them.
1st one was a 24 cell. It started smoking at idle. Once it was off it blew up, literally. This was blamed on "overcharging" causing thermal runaway. Not sure how that happens at idle.
After throwing a fit about buying a new one for 75% off, they sent a 20 cell to use. After about a month and a half this one is toast too.
I would not recommend using on for a Daily Driver; only for a dedicated track or drag car where you plug it in to start it and take it out after.
Car runs fine with a cheap 20 amp hour Shuriken AGM battery in it.
Having spent over $400 on the 24 cell and terminals, and $140 on the cheap AGM + terminals, go with the AGM.
