Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 11-24-2012, 02:39 PM   #126
JDMSTA
Member#: 310615
1213 12'Sport+13'STi
Satin White Pearl
Yeah it seems like everywhere else gets all the goodies while the US gets shafted.
JDMSTA is offline   Reply With Quote
Old 11-24-2012, 04:16 PM   #127
ZURCALED12
Member#: 309754
2012 Impreza Sport L
Ice Silver Metallic
Talking Fog Lights Assembly Retrofit
Each fog light assembly is $135.00 @ the stealer! Ouch! I was trying to buy a set to have no down time. What size are those Blazer Projectors? 2.5" ?
Originally Posted by JDMSTA View Post
Thanks guys! Yeah I did alot of questionings at the retrofitsource.com and the guy reassured me that using the 50w ballasts with 50w hid bulbs won't give as much heat as compared to using a 50w ballasts with a 35w hid bulbs which overpowers them which creates alot of those heat issues and shorten the lifespan of the bulbs too. Plus the 50w hid bulbs glass capsule is made thicker from the 35w ones which suppose to help out with the heat problem. I think you are referring to the Mini H1, which don't have the 50W option when you make an order, plus the back reflector bowl is so much smaller as well, which makes it not compatible with the 50W setup. As for the foglights. here's a couple of pics I did.
Cut a hole big enough to fit the foglights.
And I just use the leftover headlight sealant to seal all around the edges and then I just use the stock foglights mounting brackets to mount the whole thing. I used a little bit of JB Weld to secure the Blazers mounting holes to the oem brackets and it seems to work well. Sorry I didn't take any pics of the completed mounting of the fogs as it was getting really late and we hurried to get it all done.
ZURCALED12 is offline   Reply With Quote
Old 11-24-2012, 09:33 PM   #128
alt14
Member#: 271928
2014 WRX Limited
Crystal Black Silica
I'd say wait a little for Trs to get the revised matchbox projectors (supposedly completely sealed) instead of the blazers
alt14 is offline   Reply With Quote
Old 11-25-2012, 09:34 AM   #129
JDMSTA
Member#: 310615
Satin White Pearl
Yeah I'd say the same. They are not making the blazers anymore so the matchbox would be your best bet.
Old 11-29-2012, 01:28 AM   #130
ZURCALED12
Member#: 309754
Ice Silver Metallic
Talking Huummm!!!!
What is a matchbox projector? Any pictures of a sample or a website?
Old 11-29-2012, 01:30 AM   #131
ZURCALED12
Member#: 309754
Ice Silver Metallic
Picked these up very cheap, and they are OEM!
Old 11-29-2012, 07:28 AM   #132
alt14
Member#: 271928
2014 WRX Limited
Old 12-01-2012, 09:47 PM   #133
ZURCALED12
Member#: 309754
Ice Silver Metallic
Thanks! what size bulb is used in the matchbox projector? D2S?
Old 12-01-2012, 11:08 PM   #134
JDMSTA
Member#: 310615
Satin White Pearl
It uses the H1 bulb size like the mini H1's.
Old 12-02-2012, 07:34 PM   #135
ZURCALED12
Member#: 309754
Ice Silver Metallic
Unhappy D2s D2r D2c
What is the difference between these bulbs? I want the OEM setup, that is why I went with the Matsu****a ballasts. I will try and get the Auto-leveling headlights and then do the H.I.D. retrofit on those headlights, then I can sell the ones that came with my car to someone else. My only concern is that I am not sure if the "D2S D2R D2C" H.I.D. projector setup would fit into our headlights.
Old 12-02-2012, 07:53 PM   #136
ZURCALED12
Member#: 309754
Ice Silver Metallic
This is the diagram from one of the dealer websites.
#1 is the entire headlight assembly $636.03 OUCH!!!
#4 is just the headlight housing $427.47 wow!
#12 is the OEM Matsu****a Ballast
Old 12-02-2012, 08:57 PM   #137
ZURCALED12
Member#: 309754
Ice Silver Metallic
The 4300K D2S is I guess the brightest in its class, but for many it's not blue enough, but I like the brightness and lumens on the road from this kelvin temperature scale. The 5000K is what real OEM is but hard to get for aftermarket bulbs, that is another reason why I like the D2S type bulb.
Old 12-02-2012, 09:28 PM   #138
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
No, 4300k is the OEM spec.
And D2S /D2R is not a matter of preference. Your headlights require either one or the other. D2S is for projector types (for instance 06+ sti) and D2R is for OEM HID of reflector type, like for instance 04-05 sti). there are other types like D1S and D4S but they are on specific oem setups, they use different ballasts (I dont feel more details are needed for now on these).
Edit: I just realized you were probably talking about d2s preference when talking about mini h1 vs mini d2s.
D2C as far as I am concerned is not an actual bulb type. it is just a bulb base type that physically fit in either headlights, d2s or d2r. this is moot if you ask me. socket fitment is not the relevant difference between d2s and d2r. The important difference is the d2r has a shield to prevent glare so that the oem designed reflector hid have correct beam pattern. In retrofit world d2r is almost Inexistent, everybody retrofits with projectors anyways.
And if you have projectors designed for d4s like I do, you just mod the bulb or the projectors to remove the tab that prevents d2s from fitting and run it with d2s bulbs and ballasts.
frederik is offline   Reply With Quote
Old 12-02-2012, 10:49 PM   #139
ZURCALED12
Member#: 309754
Ice Silver Metallic
A solution to our fog lights OEM wiring, kind of pricey, but if you don't want to cut your harness wires. Here you go: http://www.hidguy.net/5202-Plug-and-...sing-Extension
Old 12-02-2012, 10:57 PM   #140
ZURCALED12
Member#: 309754
Ice Silver Metallic
I am sorry about the previous post, but I found something better and a lot cheaper, TWO (2) for TEN DOLLARS with pig tails.
The previous website wants $30 for two ! That is crazy !
Old 12-02-2012, 11:38 PM   #141
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
Originally Posted by ZURCALED12 View Post
Sorry found something better and a lot cheaper TWO (2) for TEN DOLLARS with pig tails. the previous website wants $30 for two ! Crazy !
So this pig tail makes it so you can install HIDs into the stock fog lamp housing without having to retrofit with projectors?
jr0bb5 is offline   Reply With Quote
Old 12-03-2012, 10:48 AM   #142
ZURCALED12
Member#: 309754
Ice Silver Metallic
Yes, I just ordered my set, research research research ! That way it's all plug and play and if you sell the car you can go back OEM.
Old 12-03-2012, 10:58 AM   #143
ZURCALED12
Member#: 309754
Ice Silver Metallic
Smile No, u still need to modify the Foglight housing.
NO, what it does is it allows you to install the after market ballast to the original Foglight harness without cutting the OEM plug. You still need to modify the Foglight housing to fit the projector in them.
Old 12-03-2012, 06:26 PM   #144
ZURCALED12
Member#: 309754
Ice Silver Metallic
Smile Thank You For Making that Clear.
OK, now I understand Frederik. So, I am going to stick with my original plan of using the OEM 4300K and my Matsu****a Ballasts are wired to D2S sockets. Now to find some D2S in 4300K for a reasonable price.
Old 12-03-2012, 07:22 PM   #145
JDMSTA
Member#: 310615
Satin White Pearl
Well my current retrofitted projectors are the Mini D2S and these are the D2S bulbs that I'm using and I feel its worth every penny. http://www.theretrofitsource.com/pro...ducts_id=10591
Old 12-03-2012, 07:31 PM   #146
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
So, you've got the ballasts, and chose 4300K capsules. What projector are you using? This is no longer for the foglight location & function, is it?
That takes both the Morimoto matchbox & Mini H1 out of the list.
satrya is offline   Reply With Quote
Old 12-03-2012, 08:24 PM   #147
ZURCALED12
Member#: 309754
Ice Silver Metallic
Cool Did you ever get around to do the retrofit?
Originally Posted by 06SE View Post
JDMSTA - I just wanted to say thank you for doing this. TRS had a 25% off sale last Friday evening and I jumped on it. My 12' Sport Limited will be in around 6/19 and the retrofit along with a set of HIRs for the high beams, will be installed within the first couple of days. Thanks again and I will shoot you some pictures of my install as well.
Did you ever get around to do the retrofit? I was curious to know how it turned out for you. Any pictures?
Old 12-03-2012, 08:36 PM   #148
ZURCALED12
Member#: 309754
Ice Silver Metallic
No, not for the fog lights, I am going to wait for the completely sealed matchbox projectors. As for the main low beam, I am going with what JDMSTA went with, the Morimoto mini DS2 projectors. I don't know if you guys know this, but the Masu****a OEM ballast mount to the bottom of the headlight housing as the OEM HID's that come with the CANADIAN Imprezas.
Old 12-04-2012, 08:14 PM   #149
06SE
Member#: 158925
12' Sport LTD
MBP
I did. Replied with an older picture (don't have any of the current setup) to your PM.
06SE is offline   Reply With Quote
Old 12-05-2012, 06:41 PM   #150
ZURCALED12
Member#: 309754
Ice Silver Metallic
Wow! they look awesome, I can't wait to do mine.
[Mini Review] Traded 2011 Impreza Outback Sport for 2012 Impreza Sport Premium tornado542 General Community 22 01-11-2015 01:28 PM
Help with JBL MS-8 install on 2012 impreza sport premium gobells12785 Car Audio, Video & Security 9 03-23-2012 09:56 PM
I finally got a chance to drive a Sprinter. upnygimp Off-Topic 49 03-02-2008 01:32 AM
Finally got a chance to snap some pics ElDuderino Member's Car Gallery 19 08-04-2002 03:30 PM
('93-'01) Finally I got the chance to max out my car. Chode_boy Impreza Forum 11 05-22-2002 03:41 PM
