Old 04-01-2012, 04:06 PM   #1
Daniel's05WRX
Member#: 93798
2005 WRX Hybrid
Crystal Grey Mettalic
Default Major misfire issues need help
Ok so after my build I'm getting misfires on all cylinders car runs decent when cold but gets worse as it gets to operating temp and shortly after runs horrible and starts shooting flames out of the downpipe... Any thoughts?
I'm running a built 2.5 block
DW 1300 cc injectors
DW 300 lph fuel pump
Bc over sized valves
Bc springs and retainers
Sti cams
Wrx heads with a few cc's removed and corners smoothed to prevent detonation
TD04
Daniel's05WRX is offline   Reply With Quote
Old 04-01-2012, 04:34 PM   #2
Chino Bling
Member#: 129743
2009 335i
Jet Black
What is your ECU/Engine Management setup?
and aren't those injectors a little overkill for a TD04?
Chino Bling is offline   Reply With Quote
Old 04-01-2012, 04:45 PM   #3
Daniel's05WRX
Member#: 93798
2005 WRX Hybrid
Stock ecu, break in tune from Keith @ Awd
Old 04-01-2012, 05:16 PM   #4
atomicfire
Member#: 136296
2005 STi
can you post a learning view
atomicfire is offline   Reply With Quote
Old 04-01-2012, 06:44 PM   #5
SGC2CIC
Member#: 286908
2014 EVO X GSR
2000 2.5RS
Who built the engine?
SGC2CIC is offline   Reply With Quote
Old 04-01-2012, 06:59 PM   #6
Daniel's05WRX
Member#: 93798
2005 WRX Hybrid
I've still got to data log... Gonna do that tonight or tomorrow
Old 04-01-2012, 07:00 PM   #7
Daniel's05WRX
Member#: 93798
2005 WRX Hybrid
Me... Engine starts just fine idles perfect just misses under load... Heads were built by scroggins machine in Houston... Very good shop
Old 04-01-2012, 07:28 PM   #8
Spider Pig
Member#: 82323
I'm a lead farmer,
mother****er!
Are your plugs and coil packs good?
And that is a hell of a lot of injector and fuel pump for that TD04. Could have something to do with the unburned gasoline that keeps lighting on fire at your downpipe.
Spider Pig is offline   Reply With Quote
Old 04-01-2012, 07:29 PM   #9
Aquase
Member#: 292264
02 WRX
I bet u are too rich, and that is ur miss.
Aquase is offline   Reply With Quote
Old 04-01-2012, 07:49 PM   #10
Big_Hitter
Member#: 10831
1995 Firehawk #456
2009 FXT VF52/E85
Big_Hitter is offline   Reply With Quote
Old 04-01-2012, 08:05 PM   #11
txjunglist
Member#: 11926
2011 Outback Limited
Dark Grey
yeah you need to dump those injectors for something smaller.after that check to see that all timing marks line up. jumping time happens (not likely ) my money is on injectors
txjunglist is offline   Reply With Quote
Old 04-01-2012, 09:19 PM   #12
grimlin
Member#: 176088
2009 Legacy SpecB
Keith still thinks injectors as well. Could still test coil packs though just to rule it out.
grimlin is offline   Reply With Quote
Old 04-01-2012, 09:56 PM   #13
Daniel's05WRX
Member#: 93798
2005 WRX Hybrid
I'm planning on going 30r and e85... Plugs are new and coil packs worked fine before build, also a buddy used one for a week while he waited on his new one to come in on his 04 Sti and it worked just fine
Old 04-01-2012, 09:59 PM   #14
Daniel's05WRX
Member#: 93798
2005 WRX Hybrid
Timing is perfect had a small oil leak @ the oil pump and retimed it @ wk Friday at gillman... Only thing that makes me not think injectors is that it's missing on all cylinders
Old 04-01-2012, 10:01 PM   #15
Daniel's05WRX
Member#: 93798
2005 WRX Hybrid
Yeah I'm hoping injectors, I'm just stumped... I'm going to replace my turbo inlet and check my whole vacuum and intake system tomorrow
Old 04-01-2012, 10:32 PM   #16
PostaL cm
Member#: 156654
2002 Dom 3.0 Hybrid
I just had this exact same problem. It ran fine through the whole RPM range, idled great, but as soon as I hit about 18psi (tuned for 24), it would start missing pretty bad. And it wouldn't be a constant dead miss, it would miss once, climb a couple of RPM, miss again, climb a couple of RPM, miss again.. I kept checking datalog and I wouldn't see anything except boost jump around. Only codes I would get were random misfire codes and every now and then it would name a particular cylinder misfire.. The one I saw most was on #3, so I swapped coil packs with #1 and the misfire code for #1 would pop more than the others.. so I bought a set of coil packs from a fellow NASIOC member, installed one on #1 cylinder and haven't had an issue since
PostaL cm is offline   Reply With Quote
Old 04-01-2012, 10:36 PM   #17
PostaL cm
Member#: 156654
2002 Dom 3.0 Hybrid
I actually came across this when I was having issues, it's what pointed me to my coil pack. Check it out: http://www.mkivsupra.net/vbb/showthr...fire-diagnosis) (yes, I know it's a supra board, but boosted is boosted! )
Old 04-01-2012, 10:46 PM   #18
Daniel's05WRX
Member#: 93798
2005 WRX Hybrid
Mine is missing @ like 8psi and sometimes less then that and consistently bad
Old 04-02-2012, 04:51 AM   #19
grimlin
Member#: 176088
2009 Legacy SpecB
Do you still want me to send you the coilpacks to test? Just call John at the shop and let him know yes or no. Hopefully you'll get it figured out soon.
Old 04-02-2012, 08:30 AM   #20
Daniel's05WRX
Member#: 93798
2005 WRX Hybrid
Yes plz send them
Old 04-02-2012, 09:08 AM   #21
atomicfire
Member#: 136296
2005 STi
Post learning view please
Old 04-02-2012, 09:47 AM   #22
iconone
Member#: 174883
135i 05 CGM WRX
2006 Yamaha R1
I have a set of 750 injectors I'll trade you . I'll come by today and pull the learning view.
iconone is offline   Reply With Quote
Old 04-02-2012, 08:22 PM   #23
txjunglist
Member#: 11926
Dark Grey
he needs the 1300 for e85. what is your EM?
this is what I think.
I have heard DW have problems above 1000cc . I have a set now that are in route to be checked
I also believe you should be using a stock injector on stock tune to break that engine in as these demons will rear their heads.(less is more on break in)
Old 04-02-2012, 08:30 PM   #24
Daniel's05WRX
Member#: 93798
2005 WRX Hybrid
Just stock ecu w Awd tune
Old 04-02-2012, 09:13 PM   #25
Spider Pig
Member#: 82323
I'm a lead farmer,
mother****er!
He'd need the 1300cc ones for E85 if he was running a bigger turbo, but not for a TD04. My 850cc injectors are good for E85 and my 20g.
LongTerm Misfire issue, Any help? Silver_AWD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 10-26-2009 11:40 PM
MAJOR electrical issue!!! please help... stranged NNJ_wrx Newbies & FAQs 30 06-09-2009 04:01 PM
2005 STi with misfire issues - Help dexterous Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 170 10-23-2008 10:18 AM
major touble --> need help!!!! jayssubie Engine Management & Tuning 9 12-04-2004 03:57 PM
HELP! - Major WRX Issues/Need NW Tuner giovanni North West Impreza Club Forum -- NWIC 0 09-29-2003 12:35 AM
