Old 04-01-2012, 04:41 PM   #1
edwinv04wrx
Member#: 306067
2004 wrx
wrb
Exclamation low oil but just replaced!!
hows it going guys i just replaced my engine oil last week & yesterday out of curiosity i wanted to check the oil level. it was on low just barley making it on the L & it was a bit dark. i used Valvoline full syn 5w30. car has 87k miles no check engine light have ever turned on. it does smoke gray smoke but that's cause its cold. please help am i looking at a turbo rebuild or motor rebuild or anything else?
edwinv04wrx is offline   Reply With Quote
Old 04-01-2012, 06:23 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
do not use ANY 5w30 oil in it and you will be FAR better off
Old 04-01-2012, 07:44 PM   #3
Thunderpaw
Member#: 242205
2009 wrx
blue
Did you check after put oil in and running engine for a few minutes?
Thunderpaw is offline   Reply With Quote
Old 04-01-2012, 07:55 PM   #4
Vrooom_Psh
Member#: 311923
04 STi
Yeah, was it full in the first place? how much did you put in?
Vrooom_Psh is offline   Reply With Quote
Old 04-01-2012, 11:35 PM   #5
edwinv04wrx
Member#: 306067
2004 wrx
wrb
what do you recommend & why?
yeah once i did the oil change i checked the oil level & it was a bit short on full.
i put in about 4 quarts
Old 04-02-2012, 12:35 AM   #6
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
You were almost a quart down right off the bat:
(you need 4.8)
*04 factory service manual...
z is offline   Reply With Quote
Old 04-02-2012, 01:11 AM   #7
Daijoubo-yo
Member#: 252612
2010 WRX 5dr
97 Lude Sh,99 Durango 5.2
Shell Rotella T6 5w-40 or German Castrol 0w-30 should do you right
Daijoubo-yo is offline   Reply With Quote
Old 04-02-2012, 03:10 PM   #8
04subiewrxCobbstg2
Member#: 311485
2004 WRX
Most likely you noticed the drop because oil filter and lines drained out during oil change and it had to fill those and not positive but I think that your car is good bro
04subiewrxCobbstg2 is offline   Reply With Quote
Old 04-05-2012, 08:13 AM   #9
SHOfast
Member#: 99083
02 impreza
Was this your first oil change?
Top it up correctly and then check it again after you drive it some, that is the only way you will know if you are losing or burning oil. These cars can burn oil...
SHOfast is offline   Reply With Quote
Old 04-05-2012, 07:02 PM   #10
edwinv04wrx
Member#: 306067
2004 wrx
wrb
today i checked the oil level right after work & its on full but i have some oil resedue on the bottom of the tmic. what does that mean?
Leak from oil dipstick tube? Just replace o ring? newtothescene Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 02-09-2016 12:32 AM
Help! Low Idle, Stalling Problems and Low Oil Pressure? KUEDA Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 09-23-2011 01:17 AM
Just replaced my front diff oil and now getting a grind in first kbcr3 Service & Maintenance 9 06-18-2009 03:29 AM
04 WRX, tons of burnt oil smoke out of exhaust, but just once... JasoNeon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 04-14-2007 04:06 PM
('93-'01) oil pick-up tube precaution (in case of oil pan dent or unexplained low oil pressure) Rick G Impreza Forum 0 01-22-2003 08:58 PM
