Old 04-01-2012, 06:10 PM   #1
Blue BugeyeRS2.5
Member#: 295045
Default Rack and pinion boot leak, i think....please help
i own a 2002 impreza 2.5 rs, i noticed a burning smell yesterday and could not figure out what it was. i finally was able to track it down to something leaking onto my hot catalytic converter. the fluid, is thick and light brown, i also found that its is coming from what i think is my rack and pinion joint, i am not sure that is what it is though, i am not good with parts really. it looks like there is a crack in the rubber boot, and whatever lubrication is inside of the boot is spraying out onto the cat, as well as other parts. i took some pictures of the problem area, i circled and added text to describe whats wrong,.if you cannot read them well let me know how i can describe it. my questions are, is this going to be an expensive fix? do both sides have to be changed? can the boot only be replaced? how worried should i be about driving in this condition? any help will really be appreciated, thanks.
jeff
Blue BugeyeRS2.5 is offline   Reply With Quote
Old 04-01-2012, 06:13 PM   #2
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
I think you are looking at your axle boot.
Old 04-01-2012, 06:26 PM   #3
cinnaman
Member#: 298063
2005 legacy 2.5i
DIP
yeah it is the axle boot. you'll have to re-lube it and put a new boot on. you will have to take the axle out to do this.
unless you have had this problem for a really long time there shouldn't be any significant damage to the axle.
and if the other side isn't leaking it is fine.
cinnaman is offline   Reply With Quote
Old 04-01-2012, 06:42 PM   #4
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Axles are cheap just put a new one in.
Old 04-01-2012, 07:22 PM   #5
Vrooom_Psh
Member#: 311923
04 STi
this.
Vrooom_Psh is online now   Reply With Quote
Old 04-01-2012, 08:04 PM   #6
Blue BugeyeRS2.5
Member#: 295045
That doesnt sound too bad, i was pretty worried, i just looked up an axle, only around 70 dollars, thanks for the help, i really appreciate it!
Old 04-02-2012, 07:48 PM   #7
Elbert Bass
Member#: 283429
Please, PLEASE,do yourself a favor. If you replace the axle don't buy an aftermarket axle. Buy a Subaru reman at the dealer. I can't begin to count how many cars with a vibration I see that have aftermarket reman axles. The axles are just a touch too long which causes the joints to wobble at the end of the races in the joint when the weight of the car is on the suspension.
If that is too much $$$ replacing the inner
boot is not hard. It's messy but not hard.
Elbert Bass is offline   Reply With Quote
Old 04-02-2012, 07:59 PM   #8
Blue BugeyeRS2.5
Member#: 295045
the one i ordered is from jcwhitney.com, it is the same one that is on there now though, once again guys thanks for all the help
09WRX Leaking rack and pinion IE09WRX Southern California Impreza Club Forum -- SCIC 3 11-13-2011 05:37 PM
rack and pinion boot ripped bbun Brakes, Steering & Suspension 1 12-13-2008 05:45 PM
Torn Rack and Pinion Boot koeix2 Brakes, Steering & Suspension 1 08-15-2007 11:42 AM
rack and pinion question HELP trinistyles Brakes, Steering & Suspension 2 09-08-2006 09:50 PM
Rack and Pinion Leak navamous Brakes, Steering & Suspension 0 03-30-2006 11:48 AM
