Notices
Old 04-01-2012, 07:38 PM   #1
MeinKreuz
Member#: 315376
1993 Legacy sport
Question Transmission
Hey guys, new here; I picked up a 93 legacy sport turbo with automatic transmission for dirt cheap. Needless to say I hate automatic transmissions and this one did not last too long after I turned the boost up haha. Looking to do a five speed swap. I searched the forums before posting and could not find what year transmissions would fit this. I know I need a transmission with hydraulic clutch, but I do not know what years. Can I take a 5mt from a late 90's legacy and put it in my early 90's? As for that, would a 5mt from other models bolt up also?
I know I need to get the axles, crossmembers, pedal assembly, driveshaft, rear diff, flywheel, and a few other things. anything else I would need to know for this swap besides it's going to be a pain in the ass? haha
Any help is much appreciated, Thanks!
MeinKreuz is offline   Reply With Quote
Old 04-02-2012, 12:47 AM   #2
RallyColtTurbo
Member#: 16819
Multiple writeups at LegacyCentral.org
RallyColtTurbo is offline   Reply With Quote
Old 04-02-2012, 02:08 PM   #3
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
Also on rs25 DIY section.
Although it is for an Impreza. It cant be that different from a legacy.
azn0boi04 is offline   Reply With Quote
Old 04-02-2012, 07:23 PM   #4
MeinKreuz
Member#: 315376
1993 Legacy sport
thanks for the info
Old 04-04-2012, 11:13 AM   #5
Devc
Member#: 218437
1992 Lego SS/Stagea
Use any 5mt you want from the 90+(not usure of the newer stuff) just makes sure you get the right clutch setup, matching diff rear ratio and pedal box to go with it.
Devc is offline   Reply With Quote
Old 04-04-2012, 05:26 PM   #6
Mister Anderson
Member#: 296056
1993 Turbo legacy
Metalic silver
Since you have to get all the parts for this swap you can run either a cable set up or a hydro set up, depending on the transmission type. I did my swap with a 2001 Impreza 5 speed. You can pretty much use any of the 5 speeds you like but you have to have matching differentials. 90-94 N/A's used a 4.11 diff set up while the turbo Legacys used a 3.90. the only reason why I went with a 3.90 is because I have the 91 year only LSD rear end. I also used a 2.5rs clutch.
For the wiring read the write ups here: http://www.surrealmirage.com/subaru/...lectrical.html
A list of transmissions with diffs/VIN http://spda-online.ca/modules/tinyco...ite/tc_28.html
Also check out: http://bbs.legacycentral.org/index.php
Mister Anderson is offline   Reply With Quote
Trouble installing axel stub in 03 jdm Sti Transmission speedyblacklude Transmission (AT/MT) & Driveline 3 04-01-2012 08:56 PM
Are forester transmission 2006 stronger than 06 wrx transmission? 06wrxlbart Transmission (AT/MT) & Driveline 3 09-11-2007 08:39 AM
Wated: Transmission and rear diff for WRX or Transmission for 2.5RS navpo55 Private 'Wanted' Classifieds 0 03-06-2007 09:14 PM
06 WRX Transmission VS. 02 WRX Transmission? 02BlueSuperRoo Transmission (AT/MT) & Driveline 17 08-06-2006 10:27 PM
WRX Transmission VS RS Transmission VEGETA_GT Transmission (AT/MT) & Driveline 3 10-26-2001 11:49 PM
