Old 04-02-2012, 12:26 AM   #1
rollnsf
Member#: 277607
2009 WRX Hatch-Red
2007 MB R500
Default Car pulls to the right - Not an alignment issue - Help!
I bought my 09 WRX in 2011, completely stock. It was pulling slightly to the right (noticeable only at highway speeds). At that point I had just assumed a simple alignment would correct it.
Since then I've changed the springs, shocks, sways, wheels and tires (on purpose, not to fix the alignment).
I've gotten 3 alignments, 2 from the dealer, 1 from an independent shop.
I know it's not the tires because it was pulling to the right even with the stock tires.
I've tried rotating the tires left to right, no help. On the advice of a Subaru independent shop I then tried, right to left and left rear to right front and vice versa), although the car was vibrating significantly I believe because of the wear on the tires from lowering the car. Again, I don't think this would fix anything because I don't think it's the tires.
I love this car but the pulling to the right is driving me nuts. I'm not sure what to do next, the dealer seems to be useless. I've gotten two services done, someone said to check if the calipers are sticking, I assume that would be evident during a service check?
The dealer did say that they saw evidence in the right front area of collision repair. The car fax was clean but I'm not sure how reliable that is.
Note, I'm not very mechanically inclined, so I'm looking for suggestions on how to find and get someone to fix it.
I'm in the SF Bay Area if someone knows of a shop I can actually try to get to fix it.
Thanks in advance.
rollnsf is offline   Reply With Quote
Old 04-02-2012, 12:59 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
most roads are 'crowned' so that water runs off them to the gutters on the sides of the road....this means that many cars will pull just a little to the right on many roads even if they are all good
I think this is what you are experiencing and are over sensitive to
relax...it is just a car and it is gonna be not quite perfect...ever
Old 04-02-2012, 09:12 AM   #3
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
What are your alignment specs? As you add more negative camber the car is more likely to follow grooves in the roadway. It could also amplify what Scotty mentioned above.
Scooby921 is offline   Reply With Quote
Old 04-02-2012, 04:33 PM   #4
Silverspark
Member#: 274545
Even wider tires will make it wonder the crown..
Silverspark is offline   Reply With Quote
Old 04-02-2012, 09:58 PM   #5
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
As mentioned, we need the alignment specs. Just because the alignment is "in spec" doesn't mean it isn't the cause of the problem.
Tony
Old 04-03-2012, 12:54 AM   #6
rollnsf
Member#: 277607
2009 WRX Hatch-Red
2007 MB R500
I'm familiar with crowning, and own another car with 20" rims that doesn't do this. In fact, I've owned 14 cars in my lifetime so I know what crowning is. I've also had technicians from a scooby specialist and the dealership drive the car to confirm it. That's not the case here.
I would just like a car that tracks straight.
BTW, the service technician at the dealership also who told me that all Subaru's pull to the right.
Old 04-03-2012, 01:08 AM   #7
rollnsf
Member#: 277607
2009 WRX Hatch-Red
2007 MB R500
Alignment specs from the dealership:
LF: -0.1 Camber, 6.3 Caster, -0.03 Toe
LR: -1.7 Camber, 0.01 Toe
RF: -0.1 Camber, 6.2 Caster, -0.02 Toe
RR: -1.9 Camber, 0.02 Toe
Front
Cross Camber 0.00
Cross Caster 0.2
Cross SAI -0.8
Total Toe -0.05
Rear
Cross Camber 0.2
Total Toe 0.03
Thrust Angle 0.0
I then took it to another place and got the following specs (they said they just measured and didn't adjust anything because everything looked fine). BTW, they just charged me $15 because they didn't do anything (just trying to head off questions implying I got scammed by the second place):
LF: 0.12 Camber, (no reading) Caster, -0.05 Toe
LR: -1.57 Camber, 0.04 Toe
RF: 0.35 Camber, (no reading) Caster, 0.05 Toe
RR: -1.6 Camber, 0.03 Toe
Front
Cross Camber -0.23
Total Toe 0.00
Rear
Total Toe -0.01
Thrust Angle -0.03
Thanks in advance!
Old 04-03-2012, 01:20 AM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
oh that alignment sucks bad....real bad...like REALLY sucks
ya want the front camber even, side to side and max negative that they can get
Old 04-03-2012, 01:40 AM   #9
rollnsf
Member#: 277607
2009 WRX Hatch-Red
2007 MB R500
So if I get the camber even on the front it will stop pulling to the right? I mentioned I'm not mechanically inclined, what about the numbers tells you it pulls to the right? I know what camber/caster/and toe are, but I'm not sure how to interpret the numbers to say whether a combination of numbers will cause the car to do one thing or another. One thing I was considering trying is to over correct and force it pull to the left (temporarily), just to test if this is an alignment issue.
Also, I don't think the camber on the rear is adjustable.
Old 04-03-2012, 01:46 AM   #10
rollnsf
Member#: 277607
2009 WRX Hatch-Red
2007 MB R500
Actually, won't the fact that I have more camber on the right front than the left front actually have it pull to the left?
EDIT: In my noob interpretation of the numbers, it looks to me like everything says the car should pull to the left. Unless I have everything backwards
Old 04-03-2012, 01:52 AM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
that
alignment
sucks
sweaty
monkey
balls
Old 04-03-2012, 09:08 AM   #12
rollnsf
Member#: 277607
2009 WRX Hatch-Red
2007 MB R500
that
alignment
sucks
sweaty
monkey
balls
Thanks for your response, I don't know how this helps me.
Old 04-03-2012, 09:35 AM   #13
Chuck H
Member#: 20442
Front
Cross Camber 0.00
Cross Caster 0.2
Cross SAI -0.8
Total Toe -0.05
Rear
Cross Camber 0.2
Total Toe 0.03
Thrust Angle 0.0
Front
Cross Camber -0.23
Total Toe 0.00
Rear
Total Toe -0.01
Thrust Angle -0.03
Thanks in advance!
Somebody's machine is way off, because there's no way you should get an alignment done, go to another shop and have it checked, and have camber change from negative to positive.
Looking at just the second set of numbers, it helps explain why the car would pull to the right. Your left front tire is toed in by .05, meaning it points slighty towards the center of the car (to the right). The right front tire is toed out by .05, meaning it points slighty away from the center of the car (again to the right). So if you hold the steering wheel perfectly straight, the car is going to drift slightly to the right. However, if you let go of the wheel, it should self-center pretty well. That fact that your right front wheel has significantly more positive camber than the left front (on both alignments) may also be contributing to the car pulling to the right.
As far as why Uncle Scotty is telling you that the alignment sucks, positive camber is just plain bad, especially in front. When you turn the wheel, body roll makes the outside front wheel (the one taking most of the weight) gain positive camber. That's why we set them up with negative camber to begin with, so that when you corner, you still have the whole tread width available. When they are set up with positive camber, they roll onto the outer edges and your cornering limits are significantly reduced. Now, on to the rear. You have tons of negative camber going on back there, but you're toed slightly out. The camber is going to make the rear end stick well in corners, but the toe-out is going to make it want to oversteer when you go into corners. Combine that with your positive camber up front, which is going to make the car want to understeer like crazy in corners, and I think Uncle Scotty's assessment is pretty much spot-on -- the alignment sucks sweaty monkey balls.
Not sure which lowering springs you're running, but you have things reversed front-to-back in terms of how you want the camber set up. Try to get an alignment shop set you up much closer to zero camber in the back and zero toe. Then get as much negative camber up front as you can, but make it even side-to-side. Front toe is a matter of preference. Slight toe-in generally makes you track straighter on the highway, but reduces turn-in sensitivity a little. Slight toe-out generally gets you quicker turn-in, but the car will have more tendency to wander on the highway. Don't let the alignment shop tell you that negative camber is going to eat your tires, because it won't. But any significant toe-in or toe-out will chew them up pretty quickly.
Chuck H is offline   Reply With Quote
Old 04-03-2012, 09:47 AM   #14
TXwrxWagon
Member#: 191557
2004 WRX Wagon
WRB not so minty fresh
yeah I was going to ask:
1. your first sentence says "completely stock" then next paragraph or so you mention lowered... what is it? stock height or lowered?
2. If it is lowered: by what method? just strings on stock struts? springs and new struts? coil overs? any camber bolts up front? brands for all non stock parts?
3. is it PULLING or just slowly drifting to the right... its supposed to slowly drift slightly as a safety measure... but like between 4-5-6 marker polls on the highway it will inch toward the right shoulder. if its catching or darting then its def. alignment
I have the same problem as you are having and I can tell you 210% it is alignment. Like yours most shops take the OE (aka not lowered) specs and if they are in range they stop. They don't worry about matching left/right because they are trying to turn-n-burn cars through.
The forget that AWD is more sensitive to L/R AND F/R variances of as little as +/- .01
Firestone did mine "lifetime" so I just have to make time to get up there and have them redo it.
Last thing, most better suspension companies will give recommended alignment specs with their lowering parts. My RCE springs came with mild street, serious street, and race specs... Firestone failed to do as I asked and use those specs. So this time I will have to demand they align it to the specs of the suspension system I am using.
Rob
TXwrxWagon is offline   Reply With Quote
Old 04-03-2012, 11:54 AM   #15
philly15
Member#: 223137
14' super ultimate
race car project
ok clearly both alignement specs show why it pulls right. camber and caster will cause a pull the toe not so much toe mainly just causes tire wear because the total toe equals zero there is a good chance it would be fine, in the first set of specs your front camber is equal so that would mean you feel the road crown as stated what they should have done is make the left side slightly more positive than the right to oppose it as the car will pull towards the most positive camber and least positive caster. In the second set of specs your front camber shows a more postive number on the right causing the pull to the right so obviously it is the alignment so find a new shop!! but i highly disagree with the statement about toe causing a pull if the toe was off it would cause the tires to dog track and create a really odd tire wear not pull but as total toe equals zero it is fine
philly15 is offline   Reply With Quote
Old 04-03-2012, 03:59 PM   #16
rollnsf
Member#: 277607
2009 WRX Hatch-Red
2007 MB R500
Thanks so much for the thoughtful response.
I thought the negative toe on the left front meant it points away from center, which meant it points to the left.
I don't think the rear camber is adjustable without modification?
I guess I'll look for a higher-end alignment specialist that can modify to my specs instead of aligning to ranges.
Thanks!
Old 04-03-2012, 04:01 PM   #17
rollnsf
Member#: 277607
2009 WRX Hatch-Red
2007 MB R500
I bought it stock, but have since modified. I'm running Epic Springs (and Konis, and Epic rear sway and Perrin front sway)
It's drifting.
Rob
Thanks! I'll another alignment shop and have them align to Epic's specs.
Old 04-03-2012, 04:29 PM   #18
rollnsf
Member#: 277607
2009 WRX Hatch-Red
2007 MB R500
Thanks! Will be looking for a better alignment shop now...
Switched to 18" wheels, car pulls to the right Ziggyrama Tire & Wheel 6 04-14-2006 12:26 PM
Why does my car pull to the right? qik-RE Newbies & FAQs 11 10-25-2004 03:58 PM
causes for car pulling to the right? fireguy5 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 08-10-2004 06:30 PM
Car pulling to the right Gfunk720 Transmission (AT/MT) & Driveline 1 03-30-2004 01:47 AM
Car pulling to the right when braking. Tkacik Brakes, Steering & Suspension 5 04-10-2001 09:12 PM
