Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Gauges & Electronics
Old 04-02-2012, 10:55 AM   #1
Rev Works
Vendor Sales Rating: (12)
Member#: 305656
05 STi
Talking AEM, STRI, GReddy, HKS EVC's, COBB, GrimmSpeed, + More All On Sale!!
Rev Works is your Subaru Specialist shop and we aim to provide the best possible customer service and support you can find. We will not be beat on price, so if you find it somewhere cheaper we will do our best to match or beat the price!
Ever wonder if being a NASIOC member had any benefits? Well with us it does! Enter the coupon code NASIOC on our website at checkout to receive and extra 5% off your order!
STRI 52mm & 60mm Gauges
Stri DSD warning gauges offer full function, features, and extreme accuracy. Driven by rugged stepper motor, control by advance microprocessor, DSD is the latest technology in precise monitoring device. DSD gauge series is equipped with laboratory grade sending units. Along with a convenient pre adjustable warning allowing you to keep track of everything the car is doing!
User Preset Warning with Peak recall
Auto Self Calibration
Short circuit auto detection
Sequential open / closing ceremonies
Light weight brushed aluminum casing
All sensors, gauge cup, and gauge hood included
Click here or PM for pricing!
Monkey Bone Racing In Dash Gauge Pods
The MBR (Monkey-Bone Racing) Dual Vent Gauge pods are a great way to monitor your vehicles gauges while retaining an almost stock appearance, without losing any comfort or styling. Designed for holding two 52mm gauges and in a spot with easy visibility!
No Glare Matte Finish
99% Match To Interior
Holds (2) 52 mm Gauges
Retains Ventilation Slots For your AC/Heat
Stock Option Appearance
Return to Stock at anytime
Clean Install In under 5 min
ATI Triple Center Gauge Pod
The ATI gauge pod will hold either 52mm or 60mm gauges. The pod comes pre-textured and colored to match the factory dash color. No painting is required. Out of the box it will hold 52mm gauges. All that is required for it to hold 60mm gauges is to remove a perforated ring.
Installation is a snap, it has the same type of tabs that the factory clock pod has. All it requires is a quick pop out of the clock pod, and a pop in of the ATI pod. Faceplates are available to be able to customize the look of this gauge pod.
AEM UEGO Wideband AFR Gauge
The AEM wideband UEGO sensor controller accurately monitors Air/Fuel ratios (AFR) during the tuning process to prevent a lean fuel mixture, which could lead to engine damage. AEM has combined its single-channel wideband UEGO controller and gauge display into one unit, uniting unsurpassed AFR accuracy and control with an easy-to-read interface. AEM's Gauge-Type Wideband UEGO Controller features a digital LED display and sweeping LED "needle" that changes colors as AFR changes from rich to lean. The unit's 52mm (2-1/16") gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere.
HKS EVC-S Electronic Boost Controller
High Boost Capability: up to 250kPa or 36psi
Target Boost Input: simplifies basic programming features, set it and forget it.
Offset Function: automatically adjusts if target boost is not achieved.
Drop Boost Function: allows peak boost default to a pre-set level if overboost occurs.
Analog and Digital monitoring: unit can be set to display boost digitally or with an analog style meter
After Image Function: will display live peak boost for 3-seconds after throttle is lifted.
Data Lock: 3-digit code locks out settings from being adjusted by other drivers.
Peak Hold: will store and display maximum achieved boost
Rear Wire Harness: unit can be flush mount with no exposed wires for a perfectly clean appearance.
GReddy Profec B Spec II EBC
Based on the very popular B-Spec, the all new Profec B-Spec II increases boost as easily and accurately as the original, with an added built in boost pressure display and new optional features like real-time, peak or last boost display (in either kPa or PSI). There are optional warning and boost limiter functions that can be programmed to offer much more control. The two presets values can be stored and are executed by a larger capacity inline solenoid valve.
This unit does not require extensive programming and is ideal for low to high boost levels for single or twin turbo systems with actuator or external wastegates. The Profec B-Spec. II is available in black or silver cased head units.
Click here or PM for Pricing
COBB Tuning Accessport's
  • Installs via the vehicle's diagnostic port - no tools/disassembly/wiring required!
  • Reversible Process: the ECU can be returned to stock at any time
  • Scantool Capability: Read and clear check engine lights (CELs).
  • Measure 0-60, 1/4 mile times, estimate fuel economy, & estimate torque and horsepower.
  • Data Readout: Display engine parameters on the color screen.
  • Dynamometer: Easily calculate power output and compare with other Accessport users
  • Accessport part numbers vary between model and year. Please choose the correct Accessport for your car below.
ALL INSTOCK ACCESSPORTS ARE SHIPPED OVERNIGHT FOR FREE!!!
GrimmSpeed Electronic Boost Control Solenoids
  • Get into boost faster: flows 10% faster than the competition
  • Plug and play for OEM harness: No cutting or splicing!
  • Model specific bracket for clean install: No more zip ties!
  • Works safely with the Subaru ECU
  • Nickel plated fittings
  • PLEASE NOTE: This is a boost control solenoid, not a boost controller. Custom tuning is required!
  • PLEASE NOTE: part numbers are model and year specific, please choose the correct product for your car when ordering.
And here is a list of most of companies we carry but are not limited to!
Looking for something and didn't find it here or on our website? We are constantly updating out website and carry tons or product lines. Send us a PM or email us at [email protected] with any and all questions!
We look forward to earning your business.
__________________
We will not be beat on price!
Phone
-407.542.7863
Email
Rev Works is offline   Reply With Quote
Old 04-03-2012, 01:04 PM   #2
Rev Works
Member#: 305656
05 STi
Prosport EVO Gauges
Introducing the 4 time award wining, (SEMA show 2010) industry first, dual color digital gauge. This gauge has a Black bezel, Black case and is Blacked out when off. This one gauge can display either Red or Blue and is dimmable!
A 270 dial sweep provides quick one glance accuracy. Track tested and race proven these gauges use precision electric senders (Included) to keep hazardous fluids out of the passenger compartment.
All of the Evo Series gauges perform a dramatic opening ceremony with a full digital sweep each time the vehicle is turned on.
Old 04-05-2012, 10:58 AM   #3
Rev Works
Member#: 305656
05 STi
AEM Series 2 Engine Management System
AEM's Series 2 Plug and Play Engine Management System (EMS) is a full user-programmable standalone engine control module, allowing a you to unlock the full potential of your Subaru while unlocking features previously only available professional tuners.
  • Direct replacement for factory ECU-No additional wiring or hardware necessary, installs in minutes and uses all the factory sensors
  • 1MB Internal Data Logging
  • CAN bus/Drive by Wire Equipped
  • Anti-Lag/Flat Foot Shifting Enabled
  • 8 Injector Ouputs
  • 6 Coil Outputs
  • Start-up calibration (base map) included
  • Individual Cylinder Ignition & Fuel Trims
  • All channels/maps/tuning options unlocked
  • Optional Sensors (sold below) available for additional real time logging/tuning
__________________
Phone
-407.542.7863
Email
Old 04-05-2012, 04:18 PM   #4
Rev Works
Member#: 305656
05 STi
Keep the PM's coming!
__________________
Phone
-407.542.7863
Email
Old 04-06-2012, 11:49 AM   #5
Rev Works
Member#: 305656
05 STi
Replied to all PM's. Keep em coming, its Friday and im ready to make a deal!
__________________
Phone
-407.542.7863
Email
Old 04-06-2012, 03:29 PM   #6
Rev Works
Member#: 305656
05 STi
Bump, just because its Friday!
__________________
Phone
-407.542.7863
Email
Old 04-08-2012, 11:09 PM   #7
Rev Works
Member#: 305656
05 STi
Easter dinner was delicious so i feel it deserves a bump! Hope everyone had a happy holiday!
__________________
Phone
-407.542.7863
Email
Old 04-09-2012, 11:39 AM   #8
Rev Works
Member#: 305656
05 STi
All Weekend PM's replied to!
__________________
Phone
-407.542.7863
Email
Old 04-10-2012, 02:01 PM   #9
Rev Works
Member#: 305656
05 STi
Lunchtime Bump!
__________________
Phone
-407.542.7863
Email
Old 04-11-2012, 11:04 AM   #10
Rev Works
Member#: 305656
05 STi
Happy Humpday Bump!
__________________
Phone
-407.542.7863
Email
Old 04-12-2012, 03:09 PM   #11
Rev Works
Member#: 305656
05 STi
PM's Replied!
__________________
Phone
-407.542.7863
Email
Old 04-13-2012, 10:50 AM   #12
Rev Works
Member#: 305656
05 STi
Happy Friday Bump!!
__________________
Phone
-407.542.7863
Email
Old 04-13-2012, 06:03 PM   #13
Rev Works
Member#: 305656
05 STi
All PM's Replied!
__________________
Phone
-407.542.7863
Email
Old 04-14-2012, 12:09 PM   #14
Rev Works
Member#: 305656
05 STi
Weekend Bump! Hope everyone is enjoying there weekend!
__________________
Phone
-407.542.7863
Email
Old 04-16-2012, 10:36 AM   #15
Rev Works
Member#: 305656
05 STi
All weekend PM's replied to!
__________________
Phone
-407.542.7863
Email
Old 04-17-2012, 01:59 PM   #16
Rev Works
Member#: 305656
05 STi
Eating Lunch and Bumping Threads
__________________
Phone
-407.542.7863
Email
Old 04-18-2012, 10:29 AM   #17
Rev Works
Member#: 305656
05 STi
Humpday Bump!
__________________
Phone
-407.542.7863
Email
Old 04-18-2012, 06:32 PM   #18
Rev Works
Member#: 305656
05 STi
All PM's Replied!
__________________
Phone
-407.542.7863
Email
Old 04-19-2012, 01:03 PM   #19
Rev Works
Member#: 305656
05 STi
Quotes sent!
Thank you for your business!
__________________
Phone
-407.542.7863
Email
Old 04-20-2012, 10:58 AM   #20
Rev Works
Member#: 305656
05 STi
Weekends almost here!
__________________
Phone
-407.542.7863
Email
Old 04-20-2012, 05:22 PM   #21
Rev Works
Member#: 305656
05 STi
Off to go play racecar down in Sebring! We will respond to all PM's and inquires when we are back from the track. Have a great weekend!
__________________
Phone
-407.542.7863
Email
Old 04-23-2012, 11:34 AM   #22
Rev Works
Member#: 305656
05 STi
Happy Monday Bump!
__________________
Phone
-407.542.7863
Email
Old 04-23-2012, 05:01 PM   #23
Rev Works
Member#: 305656
05 STi
Thank you for the orders and all the inquiries! Keep 'em coming!
__________________
Phone
-407.542.7863
Email
Old 04-24-2012, 10:44 AM   #24
Rev Works
Member#: 305656
05 STi
All PM's replied to!
__________________
Phone
-407.542.7863
Email
Old 04-25-2012, 12:34 PM   #25
Rev Works
Member#: 305656
05 STi
Weeks halfway over
Bump!
__________________
Phone
-407.542.7863
Email
BC, Titek, HKS, JIC, PE, STi, Tanabe All On Sale! Caliente Auto Engine/Power/Exhaust 418 09-19-2008 03:34 PM
Uppipes, Pullies, Turbos, injectors and more all on sale!! NinosAutoAccesories Engine/Power/Exhaust 14 09-14-2004 03:48 PM
