Old 04-02-2012, 03:05 PM   #1
04subiewrxCobbstg2
Member#: 311485
2004 WRX
Default Rear end noise
Does the rear cv shafts make noise like a wheel bearing going out and shut up around 25-30 mph some one please help I replaced my wheel bearing today and the noise is still there I have also replaced the brakes and rotors also the drum e brakes. I am out of ideas except the half shaft or cvt shaft I don't know what there called lol
04subiewrxCobbstg2 is offline   Reply With Quote
Old 04-02-2012, 03:16 PM   #2
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
Humming noises can be hard to find. Does it change when you make a hard corner left or right? If the CV axle (Stands for constant velocity) is bad, the noise will change as the suspension moves through its motion. Although, it usually gets worse with speed. Could be the rear differential. Or it could even be your tires making noise. What kind of tires do you have?
Bacon117 is offline   Reply With Quote
Old 04-02-2012, 03:26 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
bet the car was jacked up/lifted using the forward, rear end carrier outrigger bushing attach plates which are now bent against the body them causing this noise
Old 04-03-2012, 02:52 AM   #4
04subiewrxCobbstg2
Member#: 311485
2004 WRX
I got Nitto nt555's 18 low profile I'd have to look to give specs and it does get louder when I turn hard either way left or right and it's from the right rear I am gonna change the inside taper type bearings and hope it ends my head ache
Old 04-03-2012, 02:57 AM   #5
04subiewrxCobbstg2
Member#: 311485
2004 WRX
Even on concrete it makes the noise with no suspension travel and would this be obvious by looking I did get it used and I have tore it apart a dozen times and never noticed anything
rear end noise ryzies Transmission (AT/MT) & Driveline 1 01-25-2007 09:15 AM
Rear end noise Burnt_Toast Normally Aspirated Powertrain 8 07-09-2006 08:17 PM
97 Legacy Outback w/ AT rear end noise in reverse ChayesFSS Outback Forum 6 11-20-2005 08:54 AM
91 subaru awd help rear end noise coryc916 Newbies & FAQs 0 04-11-2005 01:20 AM
Rear End Noise??? sen New England Impreza Club Forum -- NESIC 3 04-17-2003 10:57 PM
