Old 08-21-2002, 09:51 PM   #1
Baluchitherium4
Member#: 6480
00' WS6
Red
Default 1/4 mile times for mods
What's up guys?
What are the typical times for a WRX with 3" turbo-back, up-pipe, K&N filter in stock airbox, Samco IC hoses, and boost controller? Everything else is stock.
I ran a [email protected] with a 1.86 60ft. I only want to know if I'm close to where I should be. The temp was around 85 degrees with high humidity. Boost was set ~16psi and trailing to ~14psi by redline.
Comments please.
Thanks in advance,
Dale
Baluchitherium4 is offline   Reply With Quote
Old 08-21-2002, 10:54 PM   #2
SubyRex
Member#: 10794
2002 Impreza WRX
13.47 @ 98.98MPH
Well.... I did a 13.8 with only an MBC set at 15.5PSI... the filter * hoses don't help that much at all... TB & uppipe are pretty much good for .4 or so... I'm guessing you could be able to squeeze a 13.4 with a little better launch (like a high 1.7xx) Your next step is electronics; unichip / AFC. You'll be good for a flat 13 or so with some tuning.
SubyRex is offline   Reply With Quote
Old 08-22-2002, 07:30 AM   #3
Baluchitherium4
Member#: 6480
00' WS6
Red
Thanks for the reply.
I did a 13.60 without the downpipe or the hoses but the weather was 40 degrees cooler in early spring. I think my time is probably average for the mods and the heat.
Later
Old 09-04-2002, 10:21 PM   #4
1quikrex
Member#: 15329
2015 WRX WRB Ltd
2002 WRX PSM (sold)
that sounds about right
1quikrex is offline   Reply With Quote
Old 09-05-2002, 12:35 AM   #5
V6TurboTA
Member#: 9090
09 Forester Gump
02WRX->04STi->09Gump
Thats pretty fast for the weather. Wait till a nice cool night and that car will FLY. Put a lil race gas in it and run about 16psi. Try shifting at 6500rpm also. Seems to work for me.
~v6
V6TurboTA is offline   Reply With Quote
Old 09-05-2002, 08:12 AM   #6
Baluchitherium4
Member#: 6480
00' WS6
Red
Default race gas
What octane race gas do you guys recommend?
I can get 100 octane unleaded up to 116 leaded.
I'm going back to the track on October 5th, so hopefully it will be a little cooler then.
Later,
Dale
Old 09-05-2002, 12:18 PM   #7
gldenchld
Member#: 19994
If you want run 100 octane at 18 psi.
gldenchld is offline   Reply With Quote
Old 09-05-2002, 01:26 PM   #8
V6TurboTA
Member#: 9090
09 Forester Gump
Try to get your hands on some VP Performance Unleaded.
Thats what I was using when I ran 13.5 last year.
~v6
Old 09-06-2002, 03:29 AM   #9
jbfoco
Member#: 20836
02 WRX
I ran a 13.5 with a 1.81 60' time. With the same mods and i have my unichip comming this week.
jbfoco is offline   Reply With Quote
Old 09-07-2002, 10:22 AM   #10
is2scooby
Member#: 19851
02 WRX
Aspen [email protected]
When you guys shift @ 6500rpm do you have to shift into 4th by the end of the 1/4?
I shift at 7k rpm now and am JUST bouncing off of the rev limiter in the middle of the traps...
Aloha,
Richard...
is2scooby is offline   Reply With Quote
Old 09-07-2002, 11:45 AM   #11
Baluchitherium4
Member#: 6480
00' WS6
Red
I shift at 7k in every gear and still shift to 4th well before the finish line. When I didn't have as many mods, I could ride 3rd through the traps and shave a little time. Not anymore.
Thanks for the tip on the race gas. I will give it try next trip to the track.
Later,
Dale
looking for 1/4 mile times for GC8 with legacy turbo cvcsmkr Normally Aspirated with bolt-on Forced Induction Powertrain 14 11-26-2002 09:38 AM
('93-'01) 1/4 mile times for 2000 rs stock CHACHI Impreza Forum 4 06-15-2001 11:01 PM
what is the 1/4 mile time for a stock 99 legacy gt zx2boy Legacy Forum 7 04-11-2001 12:27 AM
Any 1/4 mile times for new WRX yet? CheezeFrog General Forum Archive 23 01-23-2001 09:49 PM
1/4 mile times for a stock 2001 RS 2.5??? CyberLogic General Forum Archive 3 01-12-2001 11:29 AM
