Old 04-03-2012, 12:46 AM   #1
dillonlightman88
Member#: 287889
2008 Wrx
Default Launch control??
Can anyone explain to me simply what exactly launch control is and how it works. I read a few things abut it through some threads related to carberry(witch I don't understand either) and was wondering if anyone wanted to break some of this stuff done for me.
dillonlightman88 is offline   Reply With Quote
Old 04-03-2012, 07:32 AM   #2
quazimoto
Member#: 70395
Launch control is kind of like your rev limiter. It temporarily limits your revs by either fuel or ignition cut. This allows you to be able to launch at a constant rpm and not have to feather the gas. You can basicly just hold your gas pedal to the floor and just worry about the clutch.
quazimoto is offline   Reply With Quote
Old 04-03-2012, 10:06 PM   #3
dillonlightman88
Member#: 287889
2008 Wrx
thank you. good simple explanation.
Old 04-04-2012, 02:47 AM   #4
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Let me just add that fuel-cut is the way the stock rev limiter works, and it's the most common method for a launch control rev limiter.
With spark cut, fuel continues to spray, and it accumulates in the exhaust tract. When combustion resumes, the hot exhaust gas tends to ignite the fuel droplets in the exhaust pipes, creating pops and bangs, and occasionally breaking things.
Old 04-04-2012, 11:38 PM   #5
dillonlightman88
Member#: 287889
2008 Wrx
explains some of the vids ive seen tho
Old 04-05-2012, 12:41 AM   #6
dillonlightman88
Member#: 287889
2008 Wrx
Any body payed around with carberry?
Old 04-05-2012, 09:05 AM   #7
quazimoto
Member#: 70395
Check the Carberry thread. Not a ROM for a novice at all. It's far more than just launch control. It's switches to speed density. I would leave it alone unless you have some experience with tuning EFI vehicles and have a pretty good understanding of how these systems work.
Old 04-05-2012, 10:38 AM   #8
dillonlightman88
Member#: 287889
2008 Wrx
Icic.
Can Cruise control co-exist with launch control with the 2002 wrx Hydra? jigga Other Engine Management 5 04-17-2007 08:16 PM
Utec launch control tried out on my 03 wagon IA Performance Engine Management & Tuning 20 03-19-2003 07:07 PM
UTEC launch control in full effect. Opinions within IA Performance Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 56 03-13-2003 07:46 PM
UTEC Launch control rev limiter? Typhoon Engine Management & Tuning 6 01-28-2003 09:08 PM
Launch control and flat shift...what do you think? Onederer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 10-23-2002 06:40 PM
