Welcome to the North American Subaru Impreza Owners Club Saturday October 22, 2016
Old 04-03-2012, 04:51 AM   #1
Member#: 313179
Cool 2009 timing belt
I have a 2009 impreza 2.5i. I know subaru calls for the belt to be replaced at 105k. I took it in to the stealership to have the oil changed a while back and they recommended all these inspections which included a timing belt inspection. I didn't have it done because I'm not a big fan of blowing my hard earned dollars on an inspection that's gonna tell me I'm still good. I'm currently at 69,900 miles on the car. Do I really need to have it inspected or am I good to ride it out to 105,000 miles and have the belt replaced then. I don't drive my car hard and most of these miles are highway ones. It's a bone stock impreza too. advice is greatly appreciated.
megabyte5689 is offline   Reply With Quote
Old 04-03-2012, 06:24 AM   #2
Member#: 208052
2004 SGM FXT-6speed
I would say if it is under warranty have it done, if not you should be fine. I have 74400 miles 7 year old car which is under the 105 mark but the belt is also 7 years old so it is probably getting brittle and would probably be a good idea to replace. Yours only being 3 years old shouldn't be a problem and I wouldn't worry about it.
KOJAK-02-WRX is offline   Reply With Quote
Old 04-03-2012, 08:51 AM   #3
Member#: 118209
2015 WRX Limitec
10 year old subaru timing belts with 105k miles are nearly identical to new. The belts don't wear, and although inspecting them is never a bad idea, the belt isn't the part that fails. Idlers fail, which won't be caught by a visual inspection.
Timing belt cover and checking the timing belt Pinned Service & Maintenance 14 12-28-2015 12:09 AM
FS:Brand New OEM Timing Belt Tensioner & Timing Belt jsnm Engine/Power/Exhaust 5 04-06-2010 12:58 PM
Help Please! Timing belt cutting into timing belt cover behind A/C idler pulley Kansai Subaru Service & Maintenance 14 10-23-2008 04:05 AM
FS: Gates Racing Timing Belt NEW/ PE timing belt Keo Engine/Power/Exhaust 6 07-04-2008 03:15 AM
Instructions for taking timing belt cover off to inpect the timing belt? scoobbee Service & Maintenance 3 05-09-2005 06:33 PM
