#1 |
Member#: 148549
NESIC
Vehicle:95 RHD GC V7 STi 04 WRX, Sold the BlackSTi |
![]() Not really sure where to start. I am a driving instructor with ADSI in Rhode Island, we teach State Police training, vehicle dynamics classes, cornering, car control classes and most importantly AutoX courses. This is about my 14th Subaru, I currently own 3 as you can see in my profile. I flew to Japan last year and bought a V7 STi and brought it back to rebuild my 95 impreza which is extremely fun too! I am not sponsored, and prefer to be that way since I like having zero stickers on the car! This sti though sticks to the ground with the wide setup. It handles as if it were on rails, it's a completely different level when you run 11.6" wide slicks all the way around! I really care about this car in particular and am very pleased with the way it looks and performs! I couldn't have done this all without the help from my good friend John L, Joe P, my g/f, Wicked Innovation/Wicked Bodyworks (Matt, Tom, Jimmy, Jay), and of course Joshua Hanley photography. Built Block: EJ257 (703) CP 100mm Pistons Manley H-beam Rods ACL HX and H mix Race bearings STI 400 series Nitrided Crank P&L Modified Oil Pump Heads decked, "cleaned up" and pressure tested ARP Head Studs Balanced rotating assembly to 10k APS turbo Inlet Group N Motor mounts Cosworth Air Pump Delete Cosworth timing belt guide Gates kevlar reinforced timing belt A/C Delete GMS 160 T-stat NGK 1 step colder plugs ACT 6 Puck sprung clutch and ACT Xtreme Pressure Plate Being built by me and tuned by EFI Logics STRI DSD Slim II Gauges 60mm Oil Pressure EGT Oil Temp ATI triple dash pod with CF face. STRI Fuel Pressure Gauge STRI Boost Gauge HKS Limited Edition Oil cap "Lots of" -an fittings, Pro-Lite 350 hose and hose finishers. AEM 3.5 BAR MAP Sensor and Cobb MAP adaptor block. Engine: Perrin Garrett Rotated 35r Perrin up-pipe Tial 44mm V-band EWG Prodrive EBCS APS DR525 Perrin CAI NGK 1 step colder plugs Perrin Turbo inlet Perrin Downpipe 1000cc top feed fuel injectors Perrin Top Feed fuel rails & -an fittings Grimmspeed TGV Deletes with coated housings Aeromotive FPR with -an fittings Gimmick aluminum radiator Gates Alt. Belt Gimmick radiator hoses HKS Carbon Ti APS 50/50 BOV Walbro 255lph Fuel Pump Perrin crank pulley Perrin coolant overflow tank Crawford Type 2 AOS Snow performance stage 2 progressive methanol kit Perrin EL header (wrapped) Optima Red Top Battery Much heat shielding and wraps!!! Beatrush forged pitch stop mount Paranoid Fabrications Grounding kit HKS "Limited" oil cap Gallery Fresh (Sonoma Red) bolt kit Transmission and Chassis: Group N tranny mount TIC Transmission Crossmember mounts Cobb Front shifter bushings TIC Rear shifter bushing Cobb Short Shifter WC Lathe Works 1lb sphere Paranoid Fabrications 3 pc. front subframe Cusco H-brace Unabomber Sexy rear end kit Whiteline Front strut tower brace Whiteline Rear strut tower brace JDM Lightweight front bumper beam Beatrush aluminum pilot shaft bushings Kartboy exhaust hangers TiC Giuyngmyo Fender Cowl Braces Suspension and Braking: BC Racing Coilovers Cobb F/R swaybars Cobb F/R endlinks DBA 5000 slotted front rotors DBA 4000 slotted rear rotors Ferrodo DS2500 F/R brake pads Goodrich Stainless lines Castrol Synthetic Brake fluid Safety and Interior: AutoPower Race Roll Bar with Cross and Harness Bars Sparco "Ultra" race seats Sparco harness bar G-Force 5pt. harnesses Back seat delete with custom aluminum pan Red light mod to ALL switches and knobs (HVAC, Gauges, Window and Meth Switches, Radar Detector, Speaker switch, etc. JDM hazzard button AEM wideband Labonte methflow gauge Prodrive floormats with aluminum heel guard on driver mat Black WRX door panels and carpet COBB Shift Knob (flat black) JDM CF mirror cover Hardwired Beltronics 995 Radar Dash painted black (S204 style) Dual JL Audio Separator kit for the front two speakers 10" JL Sub with custom fitted box in trunk with cleats for ease of removal for autocross, etc. Rockford Fosgate Amp with a cutoff bypass switch and connection for ipod input. Blacked out interior (Pillars, Trim + Headliner (all painted & dyed black)) Exterior: Seibon Rear Carbon Fiber Diffuser CF Rear exhaust shield CF Front Lip with DIY lip addition Fog light cover mod for intake Replica Symms rear wing NRG Carbon Fiber 1pc roof vane Tein hood dampers wrapped in Sim...CF Carbon Fiber B-pillar covers Lightwerkz front headlight clearing and painting 6000K HID bulbs JDM Yellow High beams Carbon Fiber grille and blacked out front STI badge Custom rear LED tails All bulbs changed to clear,red,mirrored or LED Hella Horns Hidden (High + Low tones) I-badge front Black front STI badge Nukabe rear tow hook Cut, rolled and sealed rear fenders Tinted (20% front windshield with a 5% sunshade 1/3 of the way down, 5% on the remaining 5 windows) Custom full wide fender flair kit all around (painted OBP to match) Custom Front bumper side braces Enkei RPF1's (Black) 18x10.5 +15mm offset Hoosier R6's 295/30/18 Shaved + Debadged rear trunk lid Muteki closed ended lugs [center] ![]() ![]() Obviously lots of sliding so I went wider... Oh man, going to get flamed for this one... ![]() ![]() ... and since I need a video, here's an old one before the wide setup on the old horrible tune: More pics on the next page or click: http://forums.nasioc.com/forums/show...2&postcount=66
#2 |
Member#: 148549
NESIC
![]() ![]() ![]() ![]() ![]() My old 07 STi... ![]() ![]() From only a couple months ago but have changed a few things since then... aka 35R kit ![]() ![]() ![]() Last edited by HERSHEY; 04-03-2012 at 06:42 PM. |
#3 |
Member#: 148549
NESIC
Some extra pics...
![]() ![]() ![]() ![]() ![]() ![]() This is from the day the video below was taken: ![]() ![]() Spent most of the remainder sitting since it blew the fmic couplers. ![]() Last edited by HERSHEY; 04-03-2012 at 06:43 PM. |
#4 |
Member#: 148549
NESIC
![]() ![]() ![]() Found some random pic of my first STi when it was brand new: ![]() ![]() ![]() I made a model of my car: ![]() ![]() ![]() ![]() Last edited by HERSHEY; 04-16-2012 at 03:03 PM. |
#5 |
Member#: 107019
E. Canada
Vehicle:Stg2 08 STi MBP Franz Diebold tuned! |
Congrats! LOVE the all black look!
#6 |
Member#: 285698
NESIC
Vehicle:2011 WRX 5dr. WRB |
grats hershey!
#7 |
Member#: 307763
Vehicle:2003 WRX WRB |
The stig has gone all black!
but seriously the car looks great! I'm not exactly sure how I feel about the tail lights however. |
#8 |
Member#: 201046
NWIC
Vehicle:2004 WRX Silver |
Death is the only thing that comes to mind, killing everything in it's path. Sick car man and Congrats on the WIN!
#9 |
Member#: 276165
Vehicle:2013 STi 4-Door Crystal Black Silica |
Awesome, awesome, car! Congrats!
#10 |
Member#: 93646
Vehicle:Many Track Records Let us help you go fast! |
TiC goodie PM sent.
#11 |
Member#: 215707
Vehicle:2003 WRX STI Blue |
Super Cool, the extra wide tires and flared arches a very bruttal looking touch!
#12 |
Member#: 212569
Vehicle:07 Fozzy XT LTD Black |
Thanks for the inspiration...Guess i need to black out my Fozzy
Congrats! |
#13 |
Member#: 312471
Vehicle:2009 Legacy GT |
that thing looks awsome....are the pics with the tinted windsheild legit, or photoshop?
#14 |
Member#: 238682
NESIC
Vehicle:07 BBLGUN STI EJ207 V9 swapped |
#15 |
Member#: 166626
RMIC
Vehicle:2006 wrx ewg vf39'd obp |
I love this car, I need some flares like that!!!
#16 |
Member#: 257195
South East
Vehicle:2004 WRX 2.1L 12k miles strong |
Love it
#17 |
Member#: 154286
NESIC
Vehicle:2006 CGM WRX Dust Collector |
Amazing car! Loved seeing all the Subaru's you had when I was at URI
#18 |
Member#: 189747
Vehicle:2002 Wrx PSM VF48 EWG EJ257 Hybrid |
I also love the flares on the car. Congrats
#19 |
Member#: 314976
South East
Vehicle:2011 STi 4dr SWP |
those tires are MEATLY! love it! so stealth and so burly!
#20 |
Member#: 110330
Vehicle:2007 STI Limited 2012 MDX 2012 Golf TDI |
I like everything you've done with it, and that mod list is ridiculous. Classy yet menacing.
#21 |
Member#: 211715
NWIC
Vehicle:2008 STI - Stage 2 Silver Metallic |
Grats, man. Nicely done.
#22 |
Member#: 130444
Vehicle:'85 AE86 GTS |
It's rare to see an over fender setup as clean as that. It almost looks seamless in some of the pics.
#23 |
Member#: 306894
Vehicle:03 WRX wagon silver |
Well done, beautiful car
#24 |
Member#: 293386
Vehicle:2006 wrx 14 months blaze free |
can I please ride shotgun in that thing...looks so sick
#25 |
Member#: 118538
International
Vehicle:2011 SWP STi hatch & still miss my '05 WRB |
Super cool setup, and I love the black Stig.
| Thread Tools | |
| Display Modes | |
| Congratulations to old_duwel and his '94 JDM STi, Nasioc's Top Scoob 015 | old_duwel | Member's Car Gallery | 175 | 04-29-2013 01:02 AM |
| Congratulations to L-SCHLEGS and his 2008 STi, Nasioc's Top Scoob 014 | L-SCHLEGS | Member's Car Gallery | 166 | 01-01-2013 09:22 AM |
| Stone cone killers! Nasioc's Top Scoob 028 Auto-X Poll | starlightluvsu | New England Impreza Club Forum -- NESIC | 37 | 03-08-2012 06:04 PM |
| Congratulations preacher#1 and his Fozz Invasion, Nasioc's Top Scoob 022 | preacher#1 | Member's Car Gallery | 141 | 10-28-2011 12:22 AM |
| Congratulations to kaeo_15 and his Bugeye Royale, Nasioc's Top Scoob 021 | kaeo_15 | Member's Car Gallery | 186 | 04-08-2011 01:34 PM |
