Go Back   NASIOC > NASIOC Classifieds > Vendor 'Group Buy' Classifieds
Closed Thread
Old 11-27-2012, 03:20 PM   #176
drewvdw
Member Sales Rating: (2)
Member#: 255776
2010 LR WRX
MPS powered.
Yeah, I suppose it would've been too high of compression...Still very anxious for my shortblock...also, I was wondering your thoughts on a lightweight crank pulley as well as flywheel if you're b&bing the assembly. I've got a Grimmspeed piece as well as stock and I could send either in.
drewvdw is offline
Old 11-27-2012, 03:22 PM   #177
Turn in Concepts
Vendor Sales Rating: (159)
Member#: 93646
Many Track Records
Let us help you go fast!
Originally Posted by drewvdw View Post
Especially considering the 704 casting issues...
Originally Posted by manitou View Post
True story! I currently have 704 cases
Aside from two or three posted up cases of a 704 block cracking I'm not aware of any more, and frankly don't feel it's an issue.
Hell, I'm sure you can find plenty of cases of earlier blocks splitting as well just based upon how many there are out there.
In other words I don't think the 704 "issue" is statisically significant.
And to top that off we've built a number of 704 blocks that have had no problem including the rather high compression highly stressed one in our race car.
__________________
__________________
Turn in Concepts is offline
Old 11-27-2012, 03:38 PM   #178
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
I agree, but it is still something worth mentioning.
drewvdw is offline
Old 11-27-2012, 03:53 PM   #179
kellygnsd
Member Sales Rating: (18)
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
I'll mention that I've seen more cracked pre-704 blocks than cracked 704 blocks but you have to take into account sample size also. Lets mention 702, 703, and 704 blocks too.
kellygnsd is offline
Old 11-27-2012, 04:04 PM   #180
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
What did everyone do as far as breaking in their motors?
drewvdw is offline
Old 11-27-2012, 05:18 PM   #181
manitou
Member Sales Rating: (25)
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
I hear you guys and like Dom stated in one of the threads, most of the 704 case issues are probably the result of poorly executed tunes and then pushing them too hard with the poor tune.
My MPS LR motor revs so smoothly and starting it up in mid 30 degree weather, there is absolutely no piston slap when cold. I am very happy with the feel and initial response of this motor!
manitou is offline
Old 11-27-2012, 05:56 PM   #182
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Did you do an easy break in, hard break in, or just drive like normal?
Edit: Dom, I posted these questions and more on Facebook where I had a couple other questions for you. I'm sorry I've got a billion and a half questions I want to make sure I've got everything right.
drewvdw is offline
Old 11-27-2012, 06:09 PM   #183
manitou
Member#: 193757
2006 XTI Limited
An easy break in and I am still breaking it in. Prime the oiling without starting it. Initial start up 1500-2000 rpm 20 minutes with break in additive in organic oil. Change oil, another breakin additive. Drive it for 150 miles (new cams) 5-10 psi boost and 5k rpms max. Change oil, organic oil drive for 1000 miles not exceeding 10 psi boost and 5k rpms until 500 miles. A little more boost after 500 miles running on the 1 bar wastegate. Change oil to synthetic after 1000 miles. I'm going to switch to Rotella 5w40 sun at that point. Tune...... Enjoy!!
manitou is offline
Old 11-27-2012, 07:13 PM   #184
Maxwell Power
Vendor Sales Rating: (16)
Member#: 190729
minimize facebook usage when communicating with me, please. If you need answers to questions like that, I'm not going to type that into my phone. Use email. I'll send you the break in procedure.
Here you are:
Break In Procedure:
1. Install engine and all accessories. Don't start the engine have assembled just to hear it.
2. Add 4qts of oil and coolant. Use conventional 10-40 or another approved break in oil.
3. With spark plugs removed and crank sensor plug removed- crank the engine. Preferably you have a battery charger on the battery to give a voltage boost to aid in fast cranking.
4. Hold cranking for 30 second intervals until you have oil pressure. This can be observed by the low oil pressure light or any aftermarket gauge. Also, when you have good oil pressure you'll notice the engine speed up as oil gets to the bearings and cams. This is the number one reason we don't just start engines. Many people believe that starting an engine is the best way to get oil to it and that the assembly lube will protect the bearings. The large audible increase in speed tells me otherwise. Granted the oil viscosity is different than the assembly lube, there still isn't as good of lubrication.
5. Once you establish oil pressure, maintain cranking for another 20 seconds. This ensures that you have oil to all bearings and passages.
6. Install plugs. Reconnect crank sensor.
7. Start engine and maintain 2000 rpm for 20 minutes. During this time, have someone checking the engine for leaks. If a small drip is present, that isn't a big deal and you should maintain rpm. If a larger leak is present, shut the engine down, fix the leak and start the engine and run it for 20 minutes. Check that the radiator fans turn on and closely watch coolant temperature. This is also when you should be burping the cooling system. We recommend using the radiator cap extension reservoirs for bleeding cooling systems.
8. Change oil.
9. Drive car if it's ready. If using new cams or buckets, change the oil at 100-200 miles. If not, 700-1000 miles will work. During the break in period, the engine should see 7-10 psi of boost and 5k rpm. Maintain AFRs in the mid 12's under low boost and 14's under idle and cruise. 10 or 11:1 will not help the break in. No long pulls under boost. Just short bursts of about 2-3k rpm in any gear. Do not row through the gears under boost until at least 500miles. The goal is good ring seal without creating any hot spots by overloading unseated rings.
__________________
[SIZE=3][COLOR=red][I]Engine builds * Custom Fabrication * Albins Gearsets* DomTunes. [SIZE=1][COLOR=magenta]PBFL[/COLOR][/SIZE][/I]
[SIZE=2][COLOR=black]
[/COLOR][/SIZE]
[SIZE=2][COLOR=black]Hydra, AEM, COBB, Open Source, JE, Tial, Crower, Garrett, ARP, ATP, Racing Brake, Ferrea, Perrin,
[/COLOR][/SIZE]
[/COLOR][/SIZE]
Maxwell Power is offline
Old 11-27-2012, 07:22 PM   #185
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Alright, sorry about that Dom. I'll just email those questions I had for you then.
drewvdw is offline
Old 11-27-2012, 08:18 PM   #186
Maxwell Power
Member#: 190729
no problem. it's just not the best way to get the answers to questions. half the time i don't even see facebook posts.
my shift button is busted on my laptop... so i is always lower case.
__________________
[/COLOR][/SIZE]
[/COLOR][/SIZE]
[/COLOR][/SIZE]
Old 11-27-2012, 08:25 PM   #187
biodude
Member Sales Rating: (16)
Member#: 271720
Hey Dom, that's a nice detailed response, you should include a card made up with this when you ship your blocks out.
biodude is offline
Old 11-27-2012, 08:27 PM   #188
Maxwell Power
Member#: 190729
we're working on a owner's guide. We got our new shipping method down and it's pretty nice. Next is owner's guides, finish the new website etc.
__________________
[/COLOR][/SIZE]
[/COLOR][/SIZE]
[/COLOR][/SIZE]
Old 11-27-2012, 08:32 PM   #189
biodude
Member#: 271720
Awesome
BTW, we might have to talk a bit more about my 2.2 soon. I have some checking to do first, but I'm concerned that something is up with it.
biodude is offline
Old 11-29-2012, 07:53 PM   #190
WhatTurboLag?
Member Sales Rating: (3)
Member#: 243992
2006 WRX TR
Would a +4mm rod on a sleeved motor with larger pistons bring it back out to 2.5l?
Also, whys the +4 rod and 06 wrx head only have a 8500rpm rev limit?
WhatTurboLag? is offline
Old 11-30-2012, 10:47 AM   #191
Maxwell Power
Member#: 190729
rod length has nothing to do with displacement.
Yes, if you go to a big bore like 102.5 mm you bring it up to 2.5.
we do this all the time.
__________________
[/COLOR][/SIZE]
[/COLOR][/SIZE]
[/COLOR][/SIZE]
Old 11-30-2012, 03:20 PM   #192
WhatTurboLag?
Member#: 243992
2006 WRX TR
Okay, and how about my rev limit question?
Would having huge pistons decrease reliability/it's ability to rev?
Old 11-30-2012, 06:53 PM   #193
Maxwell Power
Member#: 190729
Can't get into it very in depth now as I'm out of town and using my phone.
Short answer: actual rev limit depends on the rest of your setup, but the difference is to point out that there is a lower limit with higher compression and smaller chamber design.
The pistons themselves won't care what you spin them to as long as it's under 11000 rpm.
Those setups were a reference for what you COULD do with them, not what they were limited to.
__________________
[/COLOR][/SIZE]
[/COLOR][/SIZE]
[/COLOR][/SIZE]
Old 12-01-2012, 02:52 PM   #194
Froste500
Member Sales Rating: (8)
Member#: 317659
2005 Wrx sti
Subaru Stars Group buy
I'm up for pistons and rods group buy where do I sign up Dom hopefully 102.5 pistons
Froste500 is offline
Old 12-01-2012, 03:24 PM   #195
NucleonQ8
Member Sales Rating: (4)
Member#: 249487
2009 WRX 4D
Am also up for 102.5 or even 103 pistons group buy if there is one in the future.
NucleonQ8 is offline
Old 12-13-2012, 05:27 PM   #196
Maxwell Power
Member#: 190729
Closed for next group buy.
__________________
[/COLOR][/SIZE]
[/COLOR][/SIZE]
[/COLOR][/SIZE]
Closed Thread
High Compression Custom Piston Group buy for 2.34 and 2.5L Maxwell Power Vendor 'Group Buy' Classifieds 25 11-19-2011 03:20 PM
E85 and Custom Pistons Group Buy: Updated Pricing Tiers Maxwell Power Vendor 'Group Buy' Classifieds 19 12-16-2010 07:16 PM
Volk TE37 18x9 and 17x9 +40 5x100 Functional Fitment Group Buy! WorldOne Vendor 'Group Buy' Classifieds 13 12-04-2009 12:53 PM
Draco Performance EXTREME Header/Exhaust Wrap and T3.82 Turbo Blanket ONLY! GROUP BUY Draco Performance Vendor 'Group Buy' Classifieds 9 10-30-2009 03:09 PM
Custom carpet Group Buy - UPS Warning SubaruStu Canada Region Forum 11 01-29-2002 10:56 AM
