#1 |
Member#: 278197
NWIC
Vehicle:2003 Subaru WRX Silver |
So I washed off my engine today. Hopped in my car, started it up and the oil light was not completely on but more of a hazy light was shining through. Saw this post and thinking I have the same problem but nobody said how to fix it...
http://forums.nasioc.com/forums/show...ight=oil+light thanks guys
#2 |
Member#: 87067
AKIC
Vehicle:02 Old but tasty SRP |
Sensor is directly under the alternator rear of the crank sensor which is also under there. (bonus sensor checking while you're there)
Pull connector and blow on it until dry. Reconnect. It doesn't do dim. Its a non dimming LED. The true on state is demoed in the key cycle. It is bright and unmistakable or off. No dim ever. The dim is wetness shorting the connection in frequency to simulate a dim warning light. |
#3 |
Member#: 278197
NWIC
Thanks A Million^^^^^^^
| Thread Tools | |
| Display Modes | |
| 35r install, full on oil. oil light at idle? | BigBossSTI | Factory 2.5L Turbo Powertrain | 9 | 02-12-2009 06:43 PM |
| The oil light came on, then the check engine light, then it stopped... | rogue | Off-Topic | 36 | 10-13-2004 02:29 PM |
| oil light came on for a second after oil change... is this normal? | Poe | Factory 2.0L Turbo Powertrain | 3 | 01-28-2003 10:07 PM |
| what temp does the AT Oil light come on? | IggDawg | Transmission (AT/MT) & Driveline | 7 | 01-19-2002 12:26 AM |
| oil light on | dinosaur | General Forum Archive | 5 | 01-19-2001 08:08 AM |
