Old 04-04-2012, 11:13 AM   #1
Blue BugeyeRS2.5
Member#: 295045
Default broken ball joint? or is it the control arm? help please
While doing some work on my car yesterday i noticed this part, what i think is the ball joint, but i am not good with car parts really. I noticed that it looked broken and confirmed that is was by looking at the other side. i haven't noticed any difference in handling, i don't know how long it has even been like this, but it clearly needs to be fixed. My questions are; what is this part? is it dangerous to drive like this? Is it going to be an expensive fix?
this is the one on the other side, how it should look
these are the shots of the broken one
any help is appreciated, thankss!
Blue BugeyeRS2.5 is offline   Reply With Quote
Old 04-04-2012, 11:20 AM   #2
willg
Member#: 256344
2008 Subaru WRX
Sway bar endlink. Fairly cheap and easy to replace
willg is offline   Reply With Quote
Old 04-04-2012, 11:32 AM   #3
X Mon
Member#: 156443
2006 WRX Wagon WRB
2001 Forester S, EJ205/5m
20470 SA001 STABILIZER LK CP F $32.87
One notes that what has failed, is indeed a ball-joint style joint. The part in question however, is as stated, a Stabilizer (Antiroll, Sway) Bar End Link
X Mon is offline   Reply With Quote
Old 04-04-2012, 11:56 AM   #4
Blue BugeyeRS2.5
Member#: 295045
http://www2.kartboy.com/x4/product.p...7&bestseller=Y
would this replace what i need?, or do i need to get new sway bars as well?
Old 04-04-2012, 12:04 PM   #5
Sir-Knight
Member#: 73636
2007 Impreza 2.5i SE
newport blue pearl
yowza, that's a lot of rust... get the saw ready or take it to a shop to have them do it for you unless you like swearing at seized and stripped bolts.
you just need end links. make sure they will survive salty winters.
Sir-Knight is offline   Reply With Quote
Old 04-04-2012, 12:06 PM   #6
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
Just a side note: There was a recall on my 02 WRX for rusting lower control arms. It doesn't look like you had that done (they put on an anti rust coating if it isn't rusted too bad). It was location based as well, so Upstate NY may or may not have been part of the recall.
Bacon117 is offline   Reply With Quote
Old 04-04-2012, 12:22 PM   #7
Blue BugeyeRS2.5
Member#: 295045
i have that notice letter still, and yes my area is covered, i suppose i'll go to my local subaru dealer and see if they will cover this under the recall, thank you.
Are the Steelers the most popular team in North America or is it the Cowboys? Snoopy Off-Topic 178 09-22-2010 09:27 AM
Just havin a bad day or is it the car??? The Database General Community 18 04-21-2010 08:50 PM
Is my fuel pump getting weak or is it the Turbo? ClayMac Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 11-20-2008 04:59 PM
how to line up the control arm once the ball joint has been removed? sidwin Brakes, Steering & Suspension 5 08-25-2008 10:57 PM
Miller High Life... Misleading name, or is it the truth? Drink Off-Topic 26 07-14-2007 12:22 AM
