Old 08-22-2002, 01:05 AM   #1
HomeGrownXC
Member#: 10234
Midnight Black Pearl
Question New (soon to be) LINK owner - needs base map help
Hello all,
I have already PM'd some of the recommend gurus, but if anyone can help with additional pointers, tips and of course sample maps for similar setups please let me know.
Here is the current list of my performance mods:
MRT 3" turbo back exhaust system
MRT cat-less up-pipe
MRT front mounted intercooler w/ pipe assembly
MRT Unifilter air intake
MRT TMS2 Boost Control Unit
IHI VF30 turbo
STi Fuel injectors
Walbro 255 high pressure fuel pump
Fluidyne Aluminum Radiator
HKS SS BOV with return
GFB Underdrive pulleys
Any help is appreciated, thanks - Greg
HomeGrownXC is offline   Reply With Quote
Old 08-22-2002, 03:40 AM   #2
JenisonWRX
Member#: 6049
02 WRX & 99 RS
talk to Jama ... he has a lot fo the same types of mods that you do ...
but hes at 6k ft
JenisonWRX is offline   Reply With Quote
Old 08-22-2002, 02:23 PM   #3
HomeGrownXC
Member#: 10234
but hes at 6k ft
Ok I'm PMing him now, thanks!
Old 08-22-2002, 04:22 PM   #4
JaMa
Member#: 5206
Default Re: New (soon to be) LINK owner - needs base map help
Hey Greg,
Happy to send you a map, but beware I still have the stalling-when-super-hot problem a lot of Link people have. Otherwise this map does really well. Nice low and high end, but a little rich, which is the way I like to run anyway.
PM me an email address and Ill shoot it over to you
Cheers
JaMa
Originally posted by HomeGrownXC
Hello all,
IHI VF30 turbo
STi Fuel injectors
JaMa is offline   Reply With Quote
Old 08-23-2002, 06:26 PM   #5
HomeGrownXC
Member#: 10234
Default Re: Re: New (soon to be) LINK owner - needs base map help
Originally posted by JaMa
Hey Greg,
Cheers
JaMa
PM'd you, thanks!
Old 08-23-2002, 06:35 PM   #6
Delicious Tuning
Member#: 1990
Cool
I have not had a problem with any cars stalling when the car is super hot.
I would try raising or lowering your HOT IDLE number a little and see what happens. This is more then likely what is causing the stalling problem.
Delicious Tuning is offline   Reply With Quote
Old 08-23-2002, 06:43 PM   #7
HomeGrownXC
Member#: 10234
Is anyone at sea level experiencing the above said stalling problem?
Thanks - Greg
Old 08-23-2002, 06:52 PM   #8
I Wish
Member#: 19278
JaMa,
Just noticed your posting on Scoobynet.
Have you emailed Bob Rawle yet ?
If there isn't anything that he doesn't know about the Link then it isn't worth knowing.
He is probably one of the best tuners of the Link and works very closely with Link NZ.
I Wish is online now   Reply With Quote
Old 08-23-2002, 07:26 PM   #9
JaMa
Member#: 5206
Default Link problems
Yeah, I have tried about everything I can, and in fact I am selling my Link in favor of a different system anyway. I have fiddled with the hot restart numbers a lot and aside from being a little bit leaner I have not really noticed it making a difference. Also, from what I can tell, the only people who have had these problems have been at altitude and running larger fuel pumps than stock, so maybe theres some correlation there, who knows.
The one thing I can truly say about the Link is that you need to know what you are doing. I dont, and I admit it, but the lack of good information about it is irritating to me. Now, there are plenty of people out there running the Link successfully and good for them, but I am personally going to something I can take to the dyno and let a professional tune. I really dont think I should have to "babysit" the computer to make it work properly and thats the direction I have decided to go. If you are willing to go out and buy a Wideband O2 sensor and gauge, fuel pressure gauge, etc etc etc I think the Link is great. You have to be a very dilligent "fiddler/tuner" to make the Link a worthwhile solution, and I have too much else to do to play around with it right now, plus I dont want to put money into extras that other systems come with.
Since I am basically done with my mods until my engine decides to give up, I am going to have someone tune a custom solution for me. I am ready to get in the car every morning and have it start and run reliably with the set of mods I have, so the Link is going "bye bye."
Thanks for the replies!!!
JaMa
Old 08-23-2002, 07:50 PM   #10
Delicious Tuning
Member#: 1990
JaMa,
Thank you for your explanation. I have been out there trying to help people tune thier cars, over the internet and locally.
As for you I think you have made thr right decision, if you can not find someone to tune the Link for you, then move on and get something else. I am sorry we do not have someone out there to tune for you as I sure would if I was there. But you can't be everywhere.
Good luck with your other solution.
Another contact is AMR Modifications, I work closely with them and they work very closey with Link NZ and Link USA.
HomeGrownXC,
In any case, I have not known about this problem but I have brought it to AMR's attention and hopefully they can figure out.
Could someone send me thier MAP and a datalog of the problem, plus your modifications and what altitude you are at. I can take a look and send it on over to AMR to get another source of help.
[email protected]
Old 08-23-2002, 07:56 PM   #11
davidm_sh
Member#: 5994
2004 Impreza WRX STi
Java Black
HomeGrownXC,
[email protected]
Well I and 2 others, up here in Colorado, have been having problems with the car dying on the interstate/cruising conditions. Just out of the blue bam you have no power, pull to the side of the road just to push the clutch in and watch your rpms drop to 0 (fuel pressure gauge indicates no fuel pressure = fuel control problem).
I have talked to Link USA at great lengths about this, sent them my map and a bunch of datalogs, and the only thing they can offer is to replace my board and see if that works.
Hopefully it will but if not then I will probably be joining the ranks of Jama... which makes me sad becuase I DO REALLY LIKE the Link. And I am the one who he is referring to with the wideband, fuel pressure, etc gauges . To me I REALLY like the control and flexibility the Link offers.
davidm_sh is offline   Reply With Quote
Old 08-23-2002, 07:56 PM   #12
JaMa
Member#: 5206
Default Thanks a Bunch
Thanks very much for the info...
I am going to post on the MRT board you referred to - I have been looking for a good Link forum, and that one looks to be as good as they get. Im very surprised no one else has brought up this problem on there, as I know a number of people who have this issue on a regular basis.
I really do like the Link too, and I am really disappointed that its closed loop mode is not better than it is, because I am just too cheap to spend another $1000 on gauges, sensors, etc to make an already $1500 ECU product function properly.
JaMa
Old 08-23-2002, 07:59 PM   #13
HomeGrownXC
Member#: 10234
JaMa,
HomeGrownXC,
[email protected]
As soon as I have something tangible it's all yours.
Old 08-24-2002, 11:13 AM   #14
paulw
Member#: 4507
05 STI
Aspen White- No wing
I was having a TPS related problem with my Link. Sent the board in to Link USA (thanks Tariq), board was replaced and problem went away.
I am at sea level (Portland, OR) and I have never had a stalling problem despite one day at 102F and several others near 100F.
I likne the Link very much and if it had a smooth, lean idle it would be perfect for my uses. We may be getting a 4wd dyno here soon with wideband A/F. I would tune it on the dyno and then forget about it.
paulw is offline   Reply With Quote
Old 08-24-2002, 12:04 PM   #15
Chav
Member#: 3269
2001 2.5RS Sedan STM
RSTi
Paulw, have you looked here . That is what I did to solve my rich idle and now I can idle lean and it will not stall no matter what (unless I pop the clutch at idle). It is worth a shot and is what I believe will work for most everyone with a rich idle. You need to go to the bottom of the first page and look threw the second page.
-Chav
Edit: Whoops, just read threw and saw your post.
Chav is offline   Reply With Quote
New soon to be Subie owner VII Newbies & FAQs 4 04-10-2009 12:47 AM
Soon to be WRX owner... need info!!!!!!!! kyotoegg Newbies & FAQs 18 11-19-2008 10:30 PM
Soon-to-be Suby owner... need advice! natursoul Newbies & FAQs 17 07-07-2008 12:33 AM
Soon to be WRX owner!!!..needs some help (4-sale)(STL Area) SuperSubie81 Mid West Subaru Owners Club Forum -- MWSOC 5 09-27-2002 01:15 AM
soon to be WRX owner needs safety info Diesel'sKate Newbies & FAQs 11 08-19-2002 12:42 PM
