Old 04-04-2012, 06:18 PM   #1
LTM87
Member#: 307759
2004 Impreza WRX
Default flashing XPT Roms without wideband 02 sensor
So I recently set myself on reflashing using an OBD2 cable I had made, and had a few questions pertaining to throwing a Stage 2 map on a car that likely lacks the part requisites for such a map. Performance parts include:
(Vehicle is an 04 WRX MT)
-3" turbo back exhaust
-walbro 255lph pump
-(Soon to be completed) Uppipe.
I'd much rather go with a stage 1, but I can't seem to find any (free) tunes around. I don't have a wideband 02 sensor, so would I be able to, on the basis of this vehicle being a moderately-driven daily driver, refine a stage 2 tune down using ECU sensor readings? Would it be easier, with what I have, to tweak a stock map up, or tweak a stage 2 down?
Thanks in advance,
LTM87 is offline   Reply With Quote
Old 04-05-2012, 03:13 AM   #2
Dzhedaj
Member#: 244552
MY05 Impreza WRX
WR Blue
Subaru ECU has methods to compensate for many things, so I'd just flash Stage 2 map and tune boost with the WG actuator, not touching the map itself.
When you're happy, drive around, check for knock with Learning View and RomRaider.
I don't think it's worth fiddling around with the map, if you plan some "hardware" changes soon.
Dzhedaj is offline   Reply With Quote
Wideband 02 Sensor not showing up in Rom Raider Type2 Engine Management & Tuning 2 05-11-2012 03:19 PM
Oem 02 front sensor Or Wideband 02 sensor Fast_Wrx62 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-06-2006 09:58 AM
AEM wideband 02 Sensor with gauge @Look@ vr-4master Private 'For Sale' Classifieds 8 10-19-2005 03:46 PM
wideband 02 sensor questions? SilverCWestWRX Engine Management & Tuning 1 05-20-2005 01:44 PM
Wideband 02 sensors? Unsung Boxer Normally Aspirated with bolt-on Forced Induction Powertrain 6 12-25-2004 01:28 PM
