Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 04-05-2012, 05:00 AM   #1
KeepCreepin
Member#: 303321
Default Troubles with EcuFlash on Vista
I am having troubles with EcuFlash not wanting to read my ROM on my 07 WRX I posted this in the OpenEcu.org forums but was wondering if maybe someone here has a solution to this. The cable is an op2 and the computer is a compaq with vista. Any help would be great thanks.
KeepCreepin is offline   Reply With Quote
Old 04-05-2012, 07:27 AM   #2
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
what version of ecuflash? The beta version doesnt work with vista iirc. Try version 1.42 if you havnt already. And run as admin.
fastblueufo is offline   Reply With Quote
Old 04-05-2012, 10:48 AM   #3
gotsugg
Member#: 204014
02 02 WRB Bugeye
GTX3582 front mount turbo
What exactly is it doing? or not doing?
gotsugg is offline   Reply With Quote
Old 04-05-2012, 01:47 PM   #4
KeepCreepin
Member#: 303321
Ok I will try the 1.42 and run it as admin. The program itself seems to be working fine it just doesnt seem to be recognizing my car. But the cable works fine with RomRaider.
This was with 1.43 but it was doing the same thing with 1.42
Old 04-05-2012, 01:50 PM   #5
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 440whp 420wtq
I had this same problem, i switched to a new laptop with windows 7 before really troubleshooting, hope you figure it out!
freddy121389 is offline   Reply With Quote
Old 04-05-2012, 03:12 PM   #6
KeepCreepin
Member#: 303321
Thanks i might save up and go to a laptop with Windows 7. Did you have many problems with Windows 7
Old 04-05-2012, 03:33 PM   #7
gotsugg
Member#: 204014
02 02 WRB Bugeye
I just went thru this on window 7. I have a post about 5 or 6 down from yours.
In options, do you have your "metadata directory" pointing at the "Subaru" file or the "rommetadata" file?
Old 04-05-2012, 06:02 PM   #8
KeepCreepin
Member#: 303321
Downloaded 1.43, current definitions and pointed the directory at rommetadata and everything is working now
Old 04-05-2012, 06:34 PM   #9
gotsugg
Member#: 204014
02 02 WRB Bugeye
great
Old 04-05-2012, 06:39 PM   #10
gotsugg
Member#: 204014
02 02 WRB Bugeye
For folks searching:
For EcuFlash:
1. Download the latest EcuFlash definitions file. Choose the file with the units you wish to use (metric or standard).
2. Delete the “Subaru” folder (backing up if necessary) in the Metadata directory specified in File->Options menu of EcuFlash (ex. C:\Program Files\OpenECU\EcuFlash\rommetadata\).
3. Unzip the new Subaru definition folder into the same directory (rommetadata).
4. Make sure your Metadata directory is pointing to C:\Program Files\OpenECU\EcuFlash\rommetadata
Not C:\Program Files\OpenECU\EcuFlash\rommetadata\Subaru
Old 04-08-2012, 01:49 AM   #11
02ej20wrx
Member#: 245333
psm
I had the same problem with my laptop. It was running windows 7starter edition. RomRaider worked fine but ecu flash would not recognize the car. Upgraded to a better version of windows 7 and the program works perfectly
02ej20wrx is offline   Reply With Quote
Odd problem on spare laptop with ECUFLASH - Can't open image file Hyper Open Source Reflashes 4 02-03-2010 08:23 AM
Trouble with lighting on Prosport Boost gauge David03WRX Newbies & FAQs 4 07-04-2009 11:45 PM
Trouble with Cat on a Dolphin Level 5... hikeeba Off-Topic 9 02-06-2008 01:17 PM
Can anyone help me with IPP on Vista? subiekid Off-Topic 4 06-21-2007 01:40 PM
Problem with ecuFlash on 06 STI blueturbo2 Commercial ECU Reflashes 6 06-06-2006 03:25 PM
