Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
View Poll Results: Which Front O2 do you prefer/recommend/use?
Bosch 3 10.00%
NGK/NTK 3 10.00%
Denso 21 70.00%
Subaru (Nippon/Denso) 6 20.00%
AC Delco 0 0%
Airtex 0 0%
Walker 1 3.33%
General/Universal (non/spliced) 0 0%
Multiple Choice Poll. Voters: 30. You may not vote on this poll
Old 04-05-2012, 11:46 AM   #1
Timmy_M2000
Member#: 289514
2003 WRX Sedan
Ralley Blue
Hello, I'm Tim. 2003 Subaru WRX WRB Sedan, P0171/031 codes. Working the
P0171
Fuel trim malfunction (A/F too lean)
then threw-
P0031
Front oxygen (A/F) sensor heater circuit low input
P0171 Troubleshooting help thread-
http://forums.nasioc.com/forums/showthread.php?t=475620
Now that introductions are over, on to the meat and potatoes.
There are multiple question threads pertaining to the Front O2 Sensor Part Numbers.
I've had to do this and in the process, did some homework on prices, sensor types, quality, issues, etc.
As for Prices, they vary from seller to seller, the best i found was $123 @ Amazon.com. (BS15537, Bosch 4 wire, wideband)
Here are the PN's-(Compatible to 2002-2005 WRX) **Many sensors (AFR) for this vehicle are made by Denso or from Denso blue prints, despite manufacturer name, but that doesn't mean all sensors are created equal.**
Here's a list of sensor part numbers which can be used to successfully replace the front oxygen sensor on a 2001-2005 2.0L WRX:
ACDelco - 213-2843
Airtex - 5S4302
Bosch - 15537
Denso - 234-9011
NGK/NTK - 24659 (or 24642 for some '04/05 Sti's)
Subaru - 22641AA042
Walker - 250-54004
Here is a full directory of engine codes for all Model Year Subaru's with computers-
http://www.troublecodes.net/Subaru/ (All CEL's)
DO YOUR HOMEWORK. Find the right sensor for the right price. But know what you're getting.
There's no reason to spend $100 or $200 more than you have to.
Feel free to add info, but if you plan to say something negative, have nothing to contribute, or try to thread jack, PM me first, or just don't be a jerk.
I hope this helps!
Feel Free to share your experience with the sensors in the poll, as to which brand you prefer.
Timmy_M2000 is offline   Reply With Quote
Old 04-05-2012, 12:55 PM   #2
van_dutch
Member#: 198633
2004 WRX
There is only 1 front O2 sensor you should be using and that is the Denso OE replacement (234-9011) (2 sensors if you include the Subaru one which is the same thing). These cars are known to be picky and can have issues with other ones..
van_dutch is offline   Reply With Quote
Old 04-05-2012, 05:49 PM   #3
Timmy_M2000
Member#: 289514
2003 WRX Sedan
Ralley Blue
Very true, I went with the Bosch since it was the best I found for the price, and its made by Denso as well (for our applications). Like I said before, not all sensors are created equal, so its imperative to do the research. This serves only as a guide to eliminate search time for DIY guys. That's also why I added the poll to see where people are at with the sensors they used and what kind of performance they've seen with them, to inform future purchasers of what to expect or anticipate.
Old 04-05-2012, 05:55 PM   #4
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
I like NTK, I get them for free.
Bacon117 is offline   Reply With Quote
Old 04-05-2012, 06:24 PM   #5
WeldingHank
Member#: 98645
2002 WRX Wagon
I had a bosch once, and only once. I didn't get a CEL but my fuel trims were forever more than 5% off (tuned the car myself before replacing) and my fuel milage seemed to suffer slightly. Got a Denso unit, milage came back, and back to 3% +/- on my fuel trims.
I could even see a difference on my wideband. When cruising with an oem/denso unit it would only bounce back/forth between 14.9 and 15.1 (target 15.07) and with the bosch would bounch between 14.6-15.3!
WeldingHank is offline   Reply With Quote
Old 04-07-2012, 11:55 PM   #6
Timmy_M2000
Member#: 289514
2003 WRX Sedan
Ralley Blue
Still open, let us know what you think, this is to help everyone. The more we contribute the more it helps!
Old 04-20-2012, 12:22 AM   #7
Timmy_M2000
Member#: 289514
2003 WRX Sedan
Ralley Blue
Running a Bosch Wideband, no issues. Runs great.
Old 04-20-2012, 12:43 PM   #8
Sharpjeff6
Member#: 301579
2003 Wrx
I replaced my o2 sensor bank one and I've done more research than ever trying to figure out why my CEL wont clear and pops up with the same Code P0031 but i replaced it with direct OEM parts....
Confused
Sharpjeff6 is offline   Reply With Quote
Old 04-30-2012, 12:35 AM   #9
Timmy_M2000
Member#: 289514
2003 WRX Sedan
Ralley Blue
Confused
Have you checked the wiring? Perhaps its a bad plug or maybe a defective sensor? Is it the correct AFR sensor for the car, sometimes the front and rear o2 sensors can be mixed up by parts guys, not saying that's the case, but if you know someone who can run a voltage check, give that a whack and see what comes up. Or try returning the sensor to eliminate that as a possibility. 3rd, or 1st if you have the means or a friend who does, run some logs and talk to a tuner to see where the issue is taking place. That'd be a great way to figure it out without burning more money.
Old 06-08-2012, 10:32 PM   #10
Timmy_M2000
Member#: 289514
2003 WRX Sedan
Ralley Blue
Update *** running the Bosch AFR sensor, tuned great and AFR's are spot on (tuned by a PROFESSIONAL tuner), car runs great. No issues with the sensor at all.
Old 04-25-2013, 03:09 AM   #11
throttlehappy
Member#: 313497
2016 STi FA20DiT
Yellow
Confused
Check that the O2 Sensor Heater Circuit Fuse has not blown Know a few cars that had the heater circuit fuse blow and since it is near the ECU and not in the engine bay or interior fuse box, they do not realise there is a 3rd fuse box for the Front and Rear O2 sensors
throttlehappy is offline   Reply With Quote
Old 05-02-2013, 04:40 PM   #12
adecan
Member#: 277425
02 WRX
Where exactly is this 3rd fuse box located? Iíve also tried almost everything but the p0031 code still on.
adecan is offline   Reply With Quote
Old 06-03-2013, 12:06 PM   #13
Telemachus
Member#: 187747
2003 Impreza WRX
I'm having the same issue. Replaced with Bosch unit, disconnected the battery to clear the code...CEL came back on and won't go off now. I've driven around 100 miles since replacing the sensor.
Am I missing something?
Telemachus is offline   Reply With Quote
Old 06-03-2013, 12:31 PM   #14
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
i still don't know why folks pick the Bosch unit, sure some will work, some won't.. IMO its a gamble putting on a Euro company part on a Japanese car, regardless of price its a big waste of time when you get the one that doesnt work right.
You can find and trust a Denso unit and it will work 99.9% of the time at installation since they are OEM Subaru suppliers.
fastnoypi is offline   Reply With Quote
Old 06-03-2013, 01:21 PM   #15
Telemachus
Member#: 187747
2003 Impreza WRX
I'm guessing because it's readily available at Auto zone..etc.
Can you find Denso units locally?
And, is the CEL supposed to turn off pretty quickly after the new unit goes in?
Old 06-03-2013, 02:45 PM   #16
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
None except the local dealership have them locally to me, but all of them can get them 1-3 days out. Its worth the wait.
And yes, an O2 associated CEL will turn off instantly once the new unit goes in.
2011 WRX Rear O2 Sensor part number? Jaker Private 'Wanted' Classifieds 7 04-11-2011 05:59 PM
FS : 2002 WRX Front O2 Sensor CHEAP! Stock Uppipe w/ex temp sensor and OEM spare tire stlspeed Engine/Power/Exhaust 22 07-25-2010 03:18 AM
rear o2 sensor part number? xtuffycorex New England Impreza Club Forum -- NESIC 0 09-29-2005 10:25 AM
why do 02 and 03 wrx's have different rear O2 sensor part numbers? Homemade WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-13-2004 09:53 PM
OEM Front O2 Sensor- Part Number? dug-e-fresh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-10-2002 09:41 AM
