Old 04-05-2012, 01:58 PM   #1
hellosubaru86
Member#: 305795
2005 WRX STi
Default Engine Bay Rust Correction/Repair?
I just purchased a 2005 STi that came from Michigan. All-in-all, the car is in pretty good shape, but the engine bay has some rust/corrosion on some things:
Coolant Res
WG
There's also rust on a lot of bolts, and various brackets.
What is the best way to clean this up?
Thanks.
hellosubaru86 is offline   Reply With Quote
Old 04-05-2012, 02:51 PM   #2
ruckus racing
Member#: 196844
1997 Impreza L
flat black/green
replacement parts... or grinding
ruckus racing is offline   Reply With Quote
Old 04-05-2012, 03:19 PM   #3
MeltedOutback
Member#: 215653
2004 vf34 FXT 5MT
aspen white
+paint to protect it!
I can't remember the last time i saw a subaru coolant tank that was rusty...
MeltedOutback is offline   Reply With Quote
Old 04-10-2012, 09:13 AM   #4
The Duke
Member#: 264877
Try hitting it with steel wool depending on how corroded it is. my coolant tank has some surface rust as well. Then again I'm in Cleveland Ohio...
The Duke is offline   Reply With Quote
Old 04-10-2012, 09:25 AM   #5
zombor
Member#: 246220
2004 WRX
San Remo Red!
It's gonna happen on a car that old. You can try CLR+an angle grinder on the res tank...you've got rust by the neck, that's where mine was when it sprang a pinhole leak!
You must not see many metal ones
zombor is offline   Reply With Quote
Old 04-10-2012, 11:45 AM   #6
hellosubaru86
Member#: 305795
2005 WRX STi
Thanks guys, I think I'm just going to purchase a new coolant res and wg actuator, and replace most of the nuts/bolts. For the rest of the brackets, I'll try cleaning them up with steel wool, grinding and paint.
Thanks for all of the suggestions!
Old 04-10-2012, 12:18 PM   #7
Dreamwrx
Member#: 220819
2009 WRX
Satin White Pearl
How about a rust converter?
Dreamwrx is offline   Reply With Quote
Old 04-10-2012, 02:57 PM   #8
hellosubaru86
Member#: 305795
2005 WRX STi
I've thought about this, but I think the rust is pretty bad, almost all the way through in some places. In my experience, rust converter just turns the rust into primer, but I don't really want to paint.
-Jason
Rust in engine bay = bad? 0x444A Newbies & FAQs 11 02-01-2011 05:28 PM
FS:NY: Several Engine/ Engine Bay Parts dibblejr Engine/Power/Exhaust 7 08-08-2008 12:00 AM
Engine coolant gone and all over engine bay junkboxer Service & Maintenance 3 02-23-2008 07:15 PM
rusted bolts in engine bay M3sum Newbies & FAQs 2 08-01-2002 11:22 AM
Bay Area Wheel Repair? DeliciouSpeed Bay Area Impreza Club Forum -- BAIC 20 05-19-2002 11:48 AM
