Old 08-22-2002, 05:18 AM   #1
Diversion
Member#: 18651
2009 370Z 6MT
Brilliant Silver
Default Is there any higher performing injectors for the WRX besides the STi?
Is there a reason people use the STi injectors? Are there no other injectors out in the aftermarket that exceed the performance of 565cc of flow? How much WHP can be made from the STi injectors? When is it necessary to need higher than 565cc injectors?
Jay
Diversion is offline   Reply With Quote
Old 08-22-2002, 08:23 AM   #2
Pavlo
Member#: 23015
95-> GC8
Black, blue and blue
565cc per minute should be okay for about 400 crank (break) HP, on standard fuel pressure, which is 3 bar above manifold pressure. However the duty cycles will probably be higher than 85%, which is a nice number to stay below.
You can up the fuel pressure using an adjustable regulator to 4 bar above manifold, provided your fuel pump can keep up, which I doubt an sti one can. The 4 bar will give you another 15% flow, so they will flow like 650cc injectors, which should be enough for any power you are likely to get from 2litre with a VF series turbo.
If you find you want bigger injectors, you can use 740cc secondaries out of the twin turbo Mazda RX-7, which should fit straight into your current fuel rails. You can also fit injectors compatible with the later Nissan Skylines, you can get Nismo uprated ones in sizes up to about 1000cc per minute.
If you want wheel HP, take .75 of the crank hp for a reasoble estimate.
Paul
Pavlo is offline   Reply With Quote
Old 08-22-2002, 08:40 AM   #3
STi_Pete
Member#: 14576
2002 WRX Sedan
lil easier than the last suggestion.....
Power Enterprises 650 drop in injectors...
STi_Pete is offline   Reply With Quote
Old 08-22-2002, 09:04 AM   #4
morphgabbin
Member#: 15466
2002 wrx
denzo makes 800cc for the WRX, but I think you need a stand alone to run them.
morphgabbin is offline   Reply With Quote
Old 08-22-2002, 09:10 AM   #5
Pavlo
Member#: 23015
95-> GC8
Well, I don't know what's hard about fitting skyline or rx-7 injectors, they drop straight in.
Might be harder to find some in the US. Here a set of injectors costs upwards of about £400 ($600 ish) new, whereas i can get RX-7 injectors for about £40 each from a Japanese car breakers yard.
I think the easiest thing would be a an adjustable fuel pressure regulator, and raise the fuel pressure to 4 bar above manifold pressure. Probably set you back about $120 US.
But as said above, you will need a different ECU. A S-AFC or something will sort of do it, but if you fool the ECU into think the airflow is different you will also advance the ignition. As the ECU uses airflow as a load measurement for the fuel and ignition maps, and as you would have to lean it out, it would think there was less load, so put on more advance. If you have already raised the boost you might be screwed.
Paul
Old 08-22-2002, 09:28 AM   #6
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
I'm working with PS right now to come up with some of the 650 injectors that have the spray turned 90 degrees so that you can use the stock WRX injector plug placement - critical for GDB's - but not so critical on GDA's
Anyway - in a few days I will have pricing and will post info on a gruop buy
alfriedesq is offline   Reply With Quote
Old 08-22-2002, 12:54 PM   #7
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
Several people have made 400+whp on the stock STi injectors. Cobb said they were finished at 420awhp (GDA too).
TypeC is offline   Reply With Quote
Old 08-22-2002, 01:55 PM   #8
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Well - looking at some of my approx 360 - 380 wheel hp data logs I can see 130 % and 140 % duty cycles on the sti injectors at higher fuel pressure with Perrin rails
While this may actually work of c16 race fuel - - I'd say its less that ideal
My estimate is that the max safe hp for stock injectors si about 265 - 270 wheel hp
and 330 - 340 with sti injectors
Don't forget that on street fuel the WRX likes fairly rich a.f ratios which are hard to maintain at higher boost points without serious fuel supply
Old 08-22-2002, 02:18 PM   #9
Tuning Factory Inc.
Vendor
Member#: 3600
Power Enterprise has 650 and 800cc injectors depending on your needs.
Tuning Factory Inc. is offline   Reply With Quote
Old 08-22-2002, 07:45 PM   #10
Diversion
Member#: 18651
2009 370Z 6MT
Brilliant Silver
If you had a 500 horsepower turbo, what injectors would you want? I just want some injectors that will be good with any huge turbo and allow room for tons of power.. I'd hate to spend $400+ on STi injectors and not be able to use the full potential of any of the massive turbos.
Jay
Old 08-22-2002, 09:53 PM   #11
rayder
Member#: 14535
02 Impreza WRX
Blitz will be releasing adapters that will fit their injectors to the WRX very shortly.
rayder is offline   Reply With Quote
Is there any way to post an embedded video using the html code from the website? Neek Off-Topic 7 08-21-2009 04:14 PM
are there any difference in us and canadian sti's besides the tac? andrewfraser310 Newbies & FAQs 13 04-20-2005 07:40 PM
Is there any ride height control for WRX GregUnd Texas Impreza Club Forum -- TXIC 26 11-13-2002 08:54 AM
Are there any good body kits for the wrx besides the c-west kit. faceplate Interior & Exterior Modification 1 06-08-2002 01:34 AM
is there a titanuim body kit for 2002 WRX STI? heheyama Interior & Exterior Modification 31 05-17-2002 02:52 AM
Message Board Statistics All times are GMT -4. The time now is 08:31 AM.
