Old 04-05-2012, 08:58 PM   #1
wagonryan
Member#: 163756
1996 R/RA
Default Stalls coming to stop
Engine is EJ20g. If I put the car in neutral and coast to a stop, the RPMs drop low for a second or two and if I press the brakes it causes the engine to die. This started when I installed a catless downpipe and 4/2 pots....would either of these cause this?
wagonryan is offline   Reply With Quote
Old 04-05-2012, 10:38 PM   #2
richy_21
Member#: 58670
2005 got muuuuu?
Tuned?
richy_21 is offline   Reply With Quote
Old 04-06-2012, 12:48 AM   #3
amroof
Member#: 211224
2005 Saabaru
Who knows
look for any pre turbo leaks. also my car did this wen the alternator was dying.
amroof is offline   Reply With Quote
Old 04-06-2012, 01:01 PM   #4
wagonryan
Member#: 163756
1996 R/RA
Solved: speedo cable was unplugged. The ECM controls idle based on vehicle speed from the mechanical speedo cable via the gauge cluster.
My 04 STi stalls when coming to a stop sign, or coming to stop. bbailey17 Newbies & FAQs 22 04-07-2011 11:59 AM
Car is stalling under decel and coming to stop, help. bboy Commercial ECU Reflashes 5 11-28-2007 11:10 AM
Noise when come to stop or turn??? wrxdragger Brakes, Steering & Suspension 0 12-04-2006 01:57 PM
when coming to stop pedal drops a little bit... any fix? i102spd Brakes, Steering & Suspension 9 08-03-2005 09:02 AM
Stalling coming to a stop w link Midwayman Engine Management & Tuning 1 09-21-2002 08:08 PM
