Old 04-06-2012, 10:32 AM   #1
JDMFLCL
Member#: 180513
Baby Baby C'mon!
Looka Bomba! 99 JDM GM8
Default Will this shortblock fit?
So I'm throwing together a "just in case"/better shortblock for my ej20g. I'm trying to do calculations right now in order to determine which headgasket I need to procure to make this work.
EJ20G V2 WRX Heads (44cc) w/ EJ20G Electronics/Powerfc
Shortblock
2002 WRX EJ205
2001 JDM V7 STI Pistons
2001 JDM V7 STI Rods
2002 WRX Crankshaft
ACL Race Bearings
ARP Studs
Subaru Gasket refresh kit
Headgaskets of undetermined thickness.
reuse brand new timing belt/pulley/old style ej20g piston tensioner (everything has less than 2k on it)
Will this work?
JDMFLCL is offline   Reply With Quote
Old 04-06-2012, 01:24 PM   #2
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
according the Marnix's chart, it would be 8.3 compression ratio with gasket 11044AA483 (.8mm) or probably 8.6 with 11044AA650 (.56mm) (but that might not be enough clearance for the piston). it might be cheaper to use USDM EJ257 rods since they are also forged
elislider is offline   Reply With Quote
Old 04-06-2012, 01:55 PM   #3
JDMFLCL
Member#: 180513
Baby Baby C'mon!
I was planning on ej257 as a backup.
I think 8.6:1 is more attractive to me since I'm also looking for increased driveability.
Old 04-06-2012, 04:00 PM   #4
johnny p
Member#: 141232
02 v7sti wagon
signal green
i have had a similar set up .
you should use the late belt tensioner (for properly tensioning the belt).
johnny p is offline   Reply With Quote
Old 04-08-2012, 10:18 AM   #5
x777
Member#: 189319
Do you have a link to this?
x777 is offline   Reply With Quote
Old 04-08-2012, 01:40 PM   #6
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Marnix is offline   Reply With Quote
Old 04-08-2012, 07:41 PM   #7
elislider
Member#: 133923
03 Legacy GT wagon
Marnix you're my hero. You updated the chart!
Old 04-09-2012, 08:19 AM   #8
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
I started. I have to do all the newer stuff still
Will a Shortblock Fit in my trunk? Legba Built Motor Discussion 14 02-22-2009 06:24 PM
Will this tire fit this rim? pio!pio! Brakes, Steering & Suspension 2 06-13-2002 07:13 PM
Will this exhaust fit my car? bluekazoo Normally Aspirated Powertrain 6 05-12-2001 07:08 AM
Will this wheel fit on MY00 RS? raptor Brakes, Steering & Suspension 1 02-17-2001 04:15 PM
Will this wheel fit a WRX Wagon? Neil Wallerstein WRX Forum Archive 12 02-14-2001 11:28 AM
