Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Suspension/Brakes/Handling
Notices
Old 04-06-2012, 12:08 PM   #1
jal723
Member Sales Rating: (7)
Member#: 76133
2004 WRB STi *sold*
#319/555 WRB S203
Impreza WRX STi S203 4-way Adjustable Suspension
Sold!!
Selling is a set of the S203 4-way adjustable suspension.
These will go on your 05-07 STi.
All struts have been re-greased so you won't get the infamous "clunking" from these.
This set of suspension has only been on the car for 15000kms.
Sold!!
Thank you,
Jackson Lam
jal723 is offline   Reply With Quote
Old 04-06-2012, 08:25 PM   #2
jal723
Member#: 76133
2004 WRB STi *sold*
#319/555 WRB S203
Bump!
Old 04-07-2012, 09:22 PM   #3
jal723
Member#: 76133
2004 WRB STi *sold*
#319/555 WRB S203
Bump!
Old 04-08-2012, 12:28 PM   #4
jal723
Member#: 76133
2004 WRB STi *sold*
#319/555 WRB S203
Bump!
Old 04-09-2012, 11:18 AM   #5
jal723
Member#: 76133
2004 WRB STi *sold*
#319/555 WRB S203
Bump!
Old 04-09-2012, 11:25 AM   #6
kbaldi_29
Member Sales Rating: (2)
Member#: 222707
2003 WRX EJ207
SD Carberry....
Cool
You might need to consider brand new coilovers with damper and height adjustment go cheaper than that!
kbaldi_29 is offline   Reply With Quote
Old 04-09-2012, 07:58 PM   #7
jal723
Member#: 76133
2004 WRB STi *sold*
#319/555 WRB S203
Bump!
Old 04-10-2012, 09:03 AM   #8
jal723
Member#: 76133
2004 WRB STi *sold*
#319/555 WRB S203
Bump!
Old 04-10-2012, 07:29 PM   #9
jal723
Member#: 76133
2004 WRB STi *sold*
#319/555 WRB S203
Bump!
Open to offer.
Old 04-11-2012, 12:00 PM   #10
jal723
Member#: 76133
2004 WRB STi *sold*
#319/555 WRB S203
Bump!
Old 04-11-2012, 04:29 PM   #11
dilAY571
Member Sales Rating: (1)
Member#: 300837
willing to sell just the rear ones?
dilAY571 is offline   Reply With Quote
Old 04-11-2012, 07:43 PM   #12
jal723
Member#: 76133
2004 WRB STi *sold*
#319/555 WRB S203
Please check your PM.
Thank you!
Old 04-11-2012, 10:16 PM   #13
jjasonn
Member#: 208653
2004 V-Limited
Spec C
these go for so much? I have the same suspension from stock..
jjasonn is offline   Reply With Quote
Old 04-11-2012, 11:48 PM   #14
jal723
Member#: 76133
2004 WRB STi *sold*
#319/555 WRB S203
To my knowledge, this 4-way adjustable suspension for 5x114.3 bolt pattern only come stock on the JDM 2005 STi Type-RA and S203. (Please correct me if I am wrong)
Unless you have a JDM STi Type-RA or S203, I doubt you have the same suspension from stock.
Old 04-12-2012, 03:20 AM   #15
joe r
Member Sales Rating: (273)
Member#: 53412
2003 Outback
Black and Gold.
As a heads up, look in the new 2012 STi/SPT Subaru catalog. These are now sold in the USA with pink springs...
joe r
joe r is offline   Reply With Quote
Old 04-12-2012, 07:48 AM   #16
jal723
Member#: 76133
2004 WRB STi *sold*
#319/555 WRB S203
joe r
I suspect that the "STI Adj Strut/Spring Suspension Kit" may be different from the S203's original suspension as they have different part numbers.
SPT's "STI Adj Strut/Spring Suspension Kit": (http://www.subaru.com/subaru-perform...nce-parts.html)
203004S220 / 203004S230 / 203004S240 / 203004S250
S203 suspension: (http://www.sti.jp/parts/gdcd_impreza/partslist_e.pdf) (Second section on the first page, #5 - #8 item)
ST203104S160 / ST203104S170 / ST203604S160 / ST203604S170
Old 04-12-2012, 07:47 PM   #17
jal723
Member#: 76133
2004 WRB STi *sold*
#319/555 WRB S203
Bump!
Old 04-13-2012, 12:43 AM   #18
jjasonn
Member#: 208653
2004 V-Limited
Spec C
i have the v-limited spec c and it's a arai tuned suspension and it comes the same. totally the same. and they come in 5x100 too. not only 5x114.3.
read this. http://forums.nasioc.com/forums/showthread.php?t=692365 and this, http://www.perth-wrx.com/vb/sale/137...le-struts.html
and note that it says V-LIMITED. this strut was first produced for my car because of a win. and my car is only produced on a limited amount of 555. and they decided to use these struts on the S203, Type-RA.
this is what i have. lol. u doubt it? so dont jump to conclusion so fast my man. and i forgot to tell you. i am living in the land of JDM and im a japanese. so these are nowhere rare to me. at all. at least.
Old 04-13-2012, 03:57 AM   #19
jal723
Member#: 76133
2004 WRB STi *sold*
#319/555 WRB S203
Just so you know, I am not arguing with you nor doubting your knowledge toward Subaru.
However, your Arai tuned adjustable suspension is indeed different from the one on the S203, even though they do look the same on the outside.
Arai tuned adjustable suspension for 5 x100 bolt pattern: (http://www.sti.jp/parts/gdcd_impreza/partslist_d.pdf) (Second section on the first page, #5 - #8 item)
ST203104S080 / ST203104S090 / ST203604S080 / ST203604S090
S203 adjustable suspension for 5x114.3 bolt pattern: (http://www.sti.jp/parts/gdcd_impreza/partslist_e.pdf) (Second section on the first page, #5 - #8 item)
Please notice that the damping force of your Arai tuned adjustable suspension is between 1400/780 ~ 1920/940 for the front and 1050/580 ~ 1350/680 for the rear.
The damping force of my S203 adjustable suspension is between 1550/850 ~ 1800/1000 for the front and 1150/650 ~ 1300/750 for the rear.
The spring rate of them is also different:
Spring rate on the Arai tuned suspension is 5.8kgf/mm for the front and 4.9kgf/mm for the rear.
Spring rate on the S203 suspension is 6.1kgf/mm for the front and 5.1kgf/mm for the rear.
Please continue this discussion in a peaceful manner
Old 04-13-2012, 01:05 PM   #20
jal723
Member#: 76133
2004 WRB STi *sold*
#319/555 WRB S203
Bump!
Old 04-13-2012, 08:35 PM   #21
jal723
Member#: 76133
2004 WRB STi *sold*
#319/555 WRB S203
Bump!
Old 04-14-2012, 08:48 PM   #22
jal723
Member#: 76133
2004 WRB STi *sold*
#319/555 WRB S203
Bump!
Old 04-15-2012, 10:53 AM   #23
jal723
Member#: 76133
2004 WRB STi *sold*
#319/555 WRB S203
Bump!
Old 04-15-2012, 08:13 PM   #24
jal723
Member#: 76133
2004 WRB STi *sold*
#319/555 WRB S203
Bump!
Old 04-15-2012, 09:27 PM   #25
Dannys06wrx888
Member#: 316455
Bump !
Dannys06wrx888 is offline   Reply With Quote
FS : RARE JDM V5? STI Forester 4/8 Way Adjustable Suspension (Complete) w/17K Miles-$350 Audioexcels Suspension/Brakes/Handling 0 09-04-2011 06:13 PM
FS : RARE JDM V5? STI Forester 4/8 Way Adjustable Suspension (Complete) w/17K Miles-$350 Audioexcels 1993 - 2001 Impreza Specific Parts 0 09-04-2011 12:49 PM
FS : RARE JDM V5? STI Forester 4/8 Way Adjustable Suspension (Complete) w/17K Miles-$400 Audioexcels NWIC Private Classifieds 6 09-03-2011 10:42 PM
(MD) Spec-C Type-RA/S20x suspension (Tarmac/Arai springs, 4 way adjustable struts) kts262 Suspension/Brakes/Handling 6 08-19-2008 12:13 PM
$650 JDM sti version 5 GC8 GAB 5 way adjustable suspension COMPLETE 4 corners supermoose Private 'For Sale' Classifieds 11 10-07-2005 08:53 AM
