Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2015
Old 04-06-2012, 01:10 PM   #1
jnich69
Member#: 242484
2003 18g'ed wrx
sunset orange metallic
Default Data log review help
Can someone tell me why I'm not hitting full boost until 5500rpm from these logs? And if they see anything else wrong, besides the little bit of FLKC. Thanks. I was tuned on 93 pump on a mustang dyno around 4 months ago. If you guys need anything else let me know.
My mods are
Blouch 18g 7cm
gimmick turbo inlet
full catless tbe
TurboXS fmic, bov recirculated back to turbo inlet, and their sri with a K&N fiter
Deatschwerks 1000cc injectors
Walbro 255
Grimmspeed TGV deletes and 3port EBCS
https://docs.google.com/spreadsheet/...yZ01TSVE#gid=0
https://docs.google.com/spreadsheet/...xQmFNN2c#gid=0
https://docs.google.com/spreadsheet/...uNjVuSEE#gid=0
jnich69 is offline   Reply With Quote
Old 04-06-2012, 06:26 PM   #2
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
You need permission to access this item.
You are signed in as *******, but you don't have permission to access this item. You can request access from the owner or choose a different account. Learn more
Choose a different account
fix your permissions
Black94Snake is online now   Reply With Quote
Old 04-06-2012, 07:29 PM   #3
jnich69
Member#: 242484
2003 18g'ed wrx
Fixed, sorry about that. I guess I forgot to save them after I made them public before posting them.
Old 04-06-2012, 08:06 PM   #4
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
post your tune.
Old 04-06-2012, 08:37 PM   #5
jnich69
Member#: 242484
2003 18g'ed wrx
^ Sent you a PM.
Old 04-06-2012, 08:49 PM   #6
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
your WGDC table is terrible... whoever tuned that needs a boot to the face.
Gimmie an hour or so and I'll toss together something for you to try.
Old 04-06-2012, 10:24 PM   #7
jnich69
Member#: 242484
2003 18g'ed wrx
Here are two more logs with the revised map that blacksnake provided me with. Spool is 10x better, but fluctuates from 18 down to 14 between 4000-4500. Also I'm leaning out up top which is causing the FBKC I'm assuming.
https://docs.google.com/spreadsheet/...mVzd3Q2c#gid=0
https://docs.google.com/spreadsheet/...3THpCeWc#gid=0
Old 04-07-2012, 12:36 AM   #8
Dartholomew
Member#: 208771
2009 WRX
You're logging the wrong variable for boost. "Manifold relative pressure (psi)" tops out at 18.43. You could be significantly overboosting and wouldn't know (and since you're still maxed out at 18.43@redline, it seems like your boost target is probably significantly higher).
What you want to log is "Manifold relative pressure (corrected) (psi)."
Dartholomew is offline   Reply With Quote
Old 04-07-2012, 12:48 AM   #9
jnich69
Member#: 242484
2003 18g'ed wrx
Thank you for pointing that out. Idk how that got unchecked since the logs in the past I've done all had that checked off. I'll post a couple more logs tomorrow with the correct boost.
Old 04-07-2012, 06:39 AM   #10
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
It seems you may have unchecked boost target as well.
That fluctuating could be a result of your computer trying to correct for the overboosting. It seems like the WGDC dropped pretty sharply. Get another log with the right parameters (same as your first post) and ill make some changes to the map.
Another edit: Your FBKC is probably because you are running lean up top. I will review this issue in the map, but you should start checking for mechanical problems with the car. Like checking the FPRs vac/boost ref hose.
Old 04-07-2012, 11:36 AM   #11
jnich69
Member#: 242484
2003 18g'ed wrx
Here are two more logs with correct boost and target boost. The first is a good pull up to 6700rpm, but the second one I guess I lifted around 5800rpm and didn't realize. It looks like I'm still leaning out up top but there is no FBKC in either log. Also it looks like my boost is every where after I spool up. I really appreciate all the help black snake!
https://docs.google.com/spreadsheet/...zak5hNFE#gid=0
https://docs.google.com/spreadsheet/...Ga0wxSlE#gid=0
Old 04-07-2012, 12:37 PM   #12
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Yep, you definitely have a good amount of boost oscillation going on. I'll edit the map when I leave the shop. We should be able to get it perfect in the next 2-3 flashes. Sadly since im not tuning the car myself, I don't want to make huge changes.
Old 04-07-2012, 12:50 PM   #13
jnich69
Member#: 242484
2003 18g'ed wrx
Yeah, I understand about not making huge changes to the map at once. I'll have it flashed and logged probably within a half hr of you sending the next revision since I'm free all day.
Old 04-07-2012, 01:32 PM   #14
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
I'm out at 4 est. I'll have something up by 5ish
Data Log help jmustico4 AccessPort 7 08-01-2011 06:23 PM
Data log help! forfun Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 12-06-2010 06:49 PM
Data Logging Help NC bmwmotorsports South East Region Forum 3 07-11-2009 04:33 AM
Data Log help? Rice & Gravy Mid Atlantic Impreza Club -- MAIC 6 03-14-2009 12:51 PM
need data logging help Jerry Seagreaves Southern California Impreza Club Forum -- SCIC 2 01-31-2003 01:19 AM
