Old 04-07-2012, 01:00 AM   #1
joker11
Member#: 77572
Default Rotella T6, German Castrol, or Mobil 1
Im trying to decide between the Rotella T6 5W-40, German Castrol 0W-30, and the Mobil 1 0W-40. These three seem to be the popular ones around here, play well with subies, and produce good UOA results. All three are readily available to me, with the Rotella being the cheapest, the GC about $15 more per oil change and the Mobil 1 costing about right in between the two.
I had a WRX for three years and always used the GC and had good results...didn't use it up too much, and the car ran fine. Although, I never got a UOA so I guess I don't really know how good it really was. I just recently bought a newer WRX with a lot less miles and I want to take as good of care for this car as I can.
I was thinking about going to a more "heavy duty" 40W oil. But I've never had any problems with the GC, and also I'm a little nervous that the Rotella doesn't have the proper API service rating for our subies and is more of a diesel oil....but I read that doesn't matter I guess.
I'm sure I'm just being anal or paranoid about this because any three of these oils will do a great job from what I have read...just looking for some advice, thanks!
joker11 is offline   Reply With Quote
Old 04-07-2012, 02:05 AM   #2
subi400
Member#: 216984
1996 Impreza outback
Green
You had to choose these three to decide between... The M1 0w40 is the on the lower end of these 3 oils but still good. Since you want to use a good oil and get good protection, then I would suggest going with the shell T-6 5w40 because it is cheaper and easy to get. I am over in CDA and I run the T-6 5w40 in my 96 impreza 2.2 and it loves it so I do have some experience with it The shell T-6 cleans the engine quite well because of the extra additives which is good, but the oil analysis's that have been posted and the great results people are seeing out weigh any problem about this oil not being certified and being used in a gasoline engine.
If you want to meet up sometime and talk that would be fine as well
subi400 is offline   Reply With Quote
Old 04-07-2012, 10:10 AM   #3
bluesubie
Member#: 767
04 FXT
If you're comparing API specs, GC is API SL, RT6 is API SM, and M1 0W-40 is API SN. The operating temp the M1 is a little thicker than GC and RT6 is the thickest between the three. M1 has a bit more anti wear additives than GC and has a lot of calcium for a detergent/dispersant whereas RT6 and GC use less calcium and more magnesium as a detergent. Any one of them would be a good choice IMO but none are "API SM/SN 5W-30".
RT6.
M1 0W-40.
GC.
-Dennis
Old 04-07-2012, 11:23 AM   #4
joker11
Member#: 77572
RT6.
M1 0W-40.
GC.
-Dennis
Awesome! Thanks for the info. So I'm guessing that the two additives, calcium and magnesium are two different ways of doing the same thing, and no reason to pick one over the other. And the most current API service rating is SN, and the only one of the three that supports that is the Mobil 1, so I wouldn't say it's the best oil but the most "up to date", correct?
I see that the Mobil 1 has a higher TBN...does that just mean it has more additives then the other two? That must be the anit-wear additives that your talking about. Ive got about 87K miles on my car, maybe the M1 would be a good choice for a higher milage car like mine? As far as the operating thickness goes, you say (or Blackstone says) that the RT6 is the thickest of the three, is there is there any pros or cons with going to a thicker operating oil? I guess you would want a thicker oil (RT6) for a daily driver, and a thinner oil (GC) for a race car?
Also is cold weather start-up something to be concerned about? Like on those 20-30 degree mornings would the RT6 force my Subaru oil filter into bypass mode until the oil gets up to temp?
Thanks for your help with my obsession with this subject. This is something I like to do with my car..."over research" the stuff I do to it, and it's nice to find some people with some knowledge on what ever mod or maintenance I am focused on. Like you said I'm sure any three of these oils is a good choice and will do an excellent job!
Old 04-07-2012, 04:43 PM   #5
bluesubie
Member#: 767
04 FXT
TBN gives you an indication of an oil's ability to continue to neutralize acids over the interval.
http://www.blackstone-labs.com/do-i-need-a-tbn.php
High TBN's are good but that doesn't automatically mean that a high TBN will be retained throughout the interval. Some may start high and drop quickly while others start low and drop slowly.
The first numbers are measured at -30C and -35C.
http://www.pqiamerica.com/coldcrank.htm
If you want to compare actual thickness at a given temperature, look up the viscosity at 100C and 40C and plug them into a viscosity calculator.
http://www.widman.biz/English/Calculators/Graph.html
-Dennis
Old 04-07-2012, 04:46 PM   #6
lavid2002
Member#: 226864
I go with the rotella, my car eats Mobil 1
lavid2002 is offline   Reply With Quote
Old 04-07-2012, 04:51 PM   #7
spec_bg
Member#: 226517
04 FXT dom1.5xtr
psm
i was using rotella in my vf forester xt and i would have to add oil in between changes.i switched to amsoil and havent had to add yet. rotella is cheap though.
spec_bg is offline   Reply With Quote
Old 04-07-2012, 04:52 PM   #8
bluesubie
Member#: 767
04 FXT
You've tried Mobil1 0W-40?
-Dennis
Old 04-07-2012, 05:03 PM   #9
bluesubie
Member#: 767
04 FXT
Which Amsoil? DEO 5W-40?
-Dennis
Old 04-07-2012, 11:39 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
did we REALLY need another bloody bleeding oil thread?
i mean...there are already thousands of these here that have all the necessary information in them already.....wtf is so wrong here???
ALL of this has been discussed, here, weekly or more frequently, for the last several years
thousands of threads.....already.....
Old 04-07-2012, 11:49 PM   #11
kingme
Member#: 280943
'11 WRX
OP asked a coherent (that counts for something BIG on NASIOC), well thought-out question about 5W-40 oils that lead to a discussion I've learned from.
What's the problem?
kingme is offline   Reply With Quote
Old 04-08-2012, 12:55 AM   #12
subi400
Member#: 216984
Green
At least the OP had 3 great oils to choose from...haha...
Old 04-08-2012, 02:17 AM   #13
ManualOverAuto
Member#: 304662
2001 Impreza L coupe
Sedona red Pearl
I was told numerous times it shouldn't be a problem, but I am also thinking it could get a little thick on those super cold mornings.
I'm talking about temperatures of 15 degrees Fahrenheit and below. PA is wild!
ManualOverAuto is offline   Reply With Quote
Old 04-08-2012, 03:49 AM   #14
subi400
Member#: 216984
Green
The shell T-6 5w40 is good to at least -40 degrees so you should be fine.
Old 04-08-2012, 09:09 AM   #15
CRAZYHAWK
Member#: 198067
2009 IMPREZA 2.5i 4d
WHITE Premium
I've used it in my 2001 Audi A4 1.8t with good results.
-Dennis
CRAZYHAWK is offline   Reply With Quote
Old 04-08-2012, 05:59 PM   #16
bluesubie
Member#: 767
04 FXT
I've used it as well. If the OP has questions about a particular viscosity, replies are a bit more helpful if they have to do with the same viscosity and not just the same brand.
-Dennis
Old 04-08-2012, 06:17 PM   #17
joker11
Member#: 77572
-Dennis
Agreed. Previous to looking into oils and the info in this thread, I thought a brand had the same quality across all different viscosity's....but a Mobil 1 5W-30 is very different from a Mobil 1 0W-40 apparently.
Old 04-08-2012, 11:16 PM   #18
bluesubie
Member#: 767
04 FXT
Specifications and Approvals
Mobil 1 0W-40 meets or exceeds the requirements of:
API SN/SM/SL/SJ
ACEA A3/B3, A3/B4
Nissan GT-R
Mobil 1 0W-40 has the following builder approvals:
MB-Approval 229.3
MB-Approval 229.5
BMW LONGLIFE OIL 01
VW 502 00/505 00
PORSCHE A40
Mobil 1 5W-30 meets or exceeds the requirements of:
ACEA A1/B1, A5/B5
API SN, SM, SL,SJ
ILSAC GF-5
Ford WSS-M2C946-A
Mobil 1 5W-30 has the following builder approvals:
General Motors Service Fill dexos1™ (license number GB1A0915015)
Honda / Acura
GC
API SL/SJ
ACEA A3
BMW Longlife 01
Mercedes-Benz 229.1
Mercedes-Benz 229.3
Mercedes-Benz 229.5
VW 505.00
VW 502.00
RT6
API : CJ-4, CI-4 Plus, CI-4, CH-4, CG-4, CF-4, CF
API : SM, SL, SJ, SH
ACEA : E9
Caterpillar: ECF-3, ECF-2
Cummins; CES 20081
DDC: 93K218
Ford : WSS-M2C171-E
JASO: DH2, MA
MACK: EO-O Premium Plus
MB Approval: 228.31
Volvo VDS-4
Old 04-08-2012, 11:36 PM   #19
Uncle Scotty
Member#: 16200
OK buy Nates beans
d000000000000d...you...like thousands and millions of others out there have NO IDEA WHAT SO EVER about what those funny little oil numbers mean
this is one of the BIGGEST issues that I see here...yet is it quite simple, really
even grade school children can comprehend it......
why do so many here not even think of just looking these simple things up so that it does not cause them so much confusion
bloody hell.....do I buy crisco or wesson??
I think I need a shot of canola
Old 04-09-2012, 12:52 AM   #20
n2oiroc
Member#: 141952
15 legacy 16 wrx
the search results are full of threads with you screaming "search noob!" as the first post in them. quit pissing on every thread if you have nothing but a bad attitude to bring to the table. if you see a stupid thread, dont click moron.
n2oiroc is offline   Reply With Quote
Old 04-09-2012, 01:37 AM   #21
Uncle Scotty
Member#: 16200
OK buy Nates beans
d000000000d...i'll say it one more ****ing time.....
use the search function and READ for a few minutes...or an hour
at SOME point the spoon feeding HAS to stop
so shut it and put the spoon down
Old 04-09-2012, 06:09 AM   #22
Coreycarlile911
Member#: 282614
2006 Wrx sti
Black pearl
This dude is the reason I am starting to hate the people of nasioc this thred was going fine till you chimed it beat it bro you have nothing useful to say. They should start a troll section and you can all go nuts and troll together. Haha
Coreycarlile911 is offline   Reply With Quote
Old 04-09-2012, 09:12 AM   #23
joker11
Member#: 77572
Thanks for the info BlueSubie! Looks like the only certification that can be directly tied to Subaru vehicles is the API service classification correct? Which would be anything with am SM rating. If someone chose an oil with a newer SN rating would that be considered a better oil? According to this description it sound like it might be something good.
"API SN Introduced in October 2010 for 2011 and older vehicles, designed to provide improved high temperature deposit protection for pistons, more stringent sludge control, and seal compatibility. API SN with Resource
Conserving matches ILSAC GF-5 by combining API SN performance with improved fuel economy, turbocharger protection, emission control system compatibility, and protection of engines operating on ethanol-containing
fuels up to E85.
Or just have a broader range of vehicles that it could be classified for? I see all of he European manufacture approvals in there (ACEA, BMW, MB, VW, Porche). Also the heavy duty ones like Cummins and Caterpillar, are these any indication of a quality oil?
Old 04-09-2012, 11:07 AM   #24
bluesubie
Member#: 767
04 FXT
fuels up to E85.
Yes, the only thing tied to Subaru's is the API classification but the owner's manual is also tied to 5W-30. IMO, these are recommendations but dealer and SoA interpretations may vary (my disclaimer).
With all of the focus the past year on GF-5 the past year, I don't recall all of the changes to API SN alone. The changes for SN were probably similar to GF5 but SN doesn't put limits on phosphorus (part of ZDDP). I do know that M1 0W-40 was tweaked a bit when it was reformulated to SN. Viscosity at 100C lowered but HTHS was increased, IIRC. The good thing about 40 grades, IMO, is that they are not GF5. Yes, your turbo may be cleaner using GF5 but there were no changes for wear control. http://www.gf-5.com/the_story/performance/ So your turbo will be clean when you spin a bearing. j/k.
The good thing IMO about Euro oils is that in addition to ACEA A3 requirements to shear stability, the manufacture specs are also pretty stringent. No GF5 oil will meet Euro requirements because GF5 oils are pretty much designed to shear after use for fuel economy. Although it's not meant to be taken to literally (see disclaimer on the first page) is tool is pretty interesting to compare different specs.
http://www.lubrizol.com/EngineOilAdd...l/default.html
-Dennis
Old 04-09-2012, 01:19 PM   #25
WRXinpa
Member#: 306708
2012 WRX Hatch SWP
TP Stage 2
The self-proclaimed Uncle Scotty is nothing more than a forum troll loser with nothing better to do than flame people for asking reasonable questions about topics that aren't always returned in google or forum searches. He's a great example of why NASIOC gets a bad rap for flaming.
WRXinpa is offline   Reply With Quote
Rotella T vs German Castrol happs subi Newbies & FAQs 45 08-15-2009 03:10 AM
GL-5 or Mobil 1 ForesterXT04 Service & Maintenance 2 07-07-2004 05:05 PM
Amsoil, Royal Purple, or Mobile 1? Irishman STi Forum Archive 25 07-28-2003 03:02 PM
Motul or Mobil 1 Super Syn? Vinnie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 47 06-04-2002 01:37 AM
Redline or Mobile 1..where do I buy them?? Speedwei Southern California Impreza Club Forum -- SCIC 1 04-27-2001 02:50 PM
